Old 06-24-2013, 06:22 PM   #1
rustyg23
Member#: 277681
05 sti
graphite metallic black
Default cam seal oil leak ?
I have a wrx done fun swap with 05 sti heads just got back from shop, new valves and springs. Iv put motor in with New seals oil builds up and pours out timing cover. so today I put new seal in, start car without the cover on the sides still have oil sling out like a stead mist I guess is the best way to put it. Iv check pcv valve seems good I even left dipstick and oil filler off to see if its from crank case psi but no change what else could it be ? It's the right intake cam gear what could cause this help please
rustyg23 is offline   Reply With Quote
Old 06-25-2013, 09:34 AM   #2
rustyg23
Member#: 277681
05 sti
To the top really need help I'm woundering if its possible that I May have got bound on the oil journals or sonthing ??
Old 06-25-2013, 11:07 AM   #3
dpenn
Member#: 141201
2008 WRX
did you use fujibond sealant on the cam caps / avcs girdle? did you make sure not to clog the small passages for draining oil off the cam seals?
dpenn is offline   Reply With Quote
Old 06-25-2013, 11:21 AM   #4
rustyg23
Member#: 277681
05 sti
You have a phone number I send u a pic of my cap I just pulled it off
Old 06-25-2013, 04:59 PM   #5
rustyg23
Member#: 277681
05 sti
Anyone have any other ideas
Old 06-25-2013, 07:50 PM   #6
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Did you use wrx or sti cams? Did you use the right cam seals the intakes are different sti/wrx. If you used sti cams which gears did you use and did you weld or tap and plug the oiling holes on the end of the cam to go to the avcs gear?
cowboy_Rob is offline   Reply With Quote
Old 06-25-2013, 08:09 PM   #7
rustyg23
Member#: 277681
05 sti
I'm running sti cams with the avcs and I have the right seals the thin walls on the intake iv unhooked the avcs and it still leaks
Old 06-25-2013, 09:58 PM   #8
rustyg23
Member#: 277681
05 sti
Old 06-25-2013, 11:25 PM   #9
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Video is private. If you have sti cams you need to plug the oil holes at the gear or use sti gears. But if you use sti gears your timing will be retarded on the intakes. Don't run it with the avcs lines unhooked though because they feed oil to the front journal of the cam.
Old 06-26-2013, 07:20 AM   #10
rustyg23
Member#: 277681
05 sti
Om running the sti gears and avcs I in plugled it just to see if it was pumping to much oil but didn't seem to change it everything is sti motor and trans wise
Old 06-26-2013, 11:19 AM   #11
al_s14
Member#: 168077
are you sure the seals are correct? while back i had a customer put exhaust seals on intake cams, then forced the avcs gear on, mushroomed the cam seal
dpen made a very good point about clogging up passages. people seem to pack the hell out of it with rtv...and those are precision mated surfaces, it takes almost no rtv to create a leak free seal
also, these are 6mm pipe plugs on front of heads for the oil gallery. if they were removed at machine shop ...
but really, pull the covers off and get a better look
al_s14 is offline   Reply With Quote
Old 06-26-2013, 12:15 PM   #12
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
How are you installing the cam seals? Are you lubing them up with motor oil first and making sure you don't damage the inner lip? A little ding on install will make them leak.
Old 06-26-2013, 01:48 PM   #13
rustyg23
Member#: 277681
05 sti
Yes I'm putting them in right this isn't my first motor just first time with this problem. I checked the caps it has a little etc in it but I cleaned that out and resealed it but thay hasn't changed anything so far I put a air in the cam bolt to blow it out that didn't change anything also have tryed unhooking avcs no change. No leaking oilline or anything ethier
Old 06-26-2013, 04:53 PM   #14
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Check for any nicks or scratches on the cam gear emerge the seal rides and make sure the seal feels snug if you slide it into the cam gear off of the engine
Old 06-26-2013, 06:41 PM   #15
rustyg23
Member#: 277681
05 sti
I have done all that I feel like iv got a pluged oil journal I guess I'm pulling motor back out
Old 06-27-2013, 06:34 PM   #16
al_s14
Member#: 168077
This is why i remove pipe plugs and blow out/brake clean out all passages on all block/head jobs. Both block and head, a must. But one plugged passage at the end of the line wouldn't cause that kind of pressure build up that it would blow past seals, oil would just bleed out the other orifices in the head, its not a completely one way street. There is something else
Still this sounds odd, get pictures. Why are you so sure its coming from the cam seal?? Did you take timing covers off and watch for spray/drip as you crank or run the engine? There is avcs line behind the timing cover too
Old 06-28-2013, 08:20 AM   #17
rustyg23
Member#: 277681
05 sti
Yes I have the side covers off the just pouring out from around the back of the right intake cam. Think is it didnt do they befor I have the new valves and springs put in. So has to be trash in there somewhere right ? I might try to take vcover off and see what I can see but probly be easyer with motor out
Old 06-28-2013, 08:21 AM   #18
rustyg23
Member#: 277681
05 sti
On these motors dose it push some air out of the oil fill tube I know some cars do some don't
Old 06-28-2013, 11:06 AM   #19
al_s14
Member#: 168077
what if you remove t belt and cam gears, get the back plastic cover off, put cam and belt back on and then you should be able to see exactly if oil is coming from cam seal or surrounding area. pull everything off and take pics
Old 06-28-2013, 02:58 PM   #20
rustyg23
Member#: 277681
05 sti
I think I'm.gunna try that and then pull motor I fell very sure its passing by seal how could I see any more that way tho ?
Old 06-29-2013, 10:47 AM   #21
rustyg23
Member#: 277681
05 sti
Well just pulled motor anyone have any ideas on where they would start looking ? I'm gunna check the valve covers to make sure its breathing good and cam/cam caps for cracks or anything
Old 06-29-2013, 12:33 PM   #22
rustyg23
Member#: 277681
05 sti
bump help please
Old 06-29-2013, 06:42 PM   #23
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
You took a step backwards pulling the motor, now you can't build pressure against the seals.
mechatricity is offline   Reply With Quote
Old 06-30-2013, 11:31 AM   #24
rustyg23
Member#: 277681
05 sti
Well u tell me what's wrong or how to find some way everyone else hasn't and ill glady out it back
Old 06-30-2013, 01:40 PM   #25
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Well we told you to host the video somewhere we could see it. Did you check the galley plugs behind the inside timing cover? Post pics of the front of the engine and of the cams/gears. Checked for cracks at the oil holes on the end of the cams? Is it definitely coming from the cam seal and not anything else getting slung up there?
