Old 07-02-2013, 11:57 AM   #26
al_s14
Member#: 168077
....what rob said....
plus my christal ball seems to be malfunctioning, must be all the nasioc traffic
al_s14 is offline   Reply With Quote
Old 07-09-2013, 11:56 AM   #27
rustyg23
Member#: 277681
05 sti
graphite metallic black
Originally Posted by rustyg23 View Post
This should work now sorry been so busy at work havnt had time to get on here
rustyg23 is offline   Reply With Quote
Old 07-10-2013, 03:20 PM   #28
rustyg23
Member#: 277681
05 sti
Any ideas would be great thanks
Old 07-11-2013, 03:12 PM   #29
rustyg23
Member#: 277681
05 sti
Ttt please help. Thanks in advance
Old 07-11-2013, 05:22 PM   #30
cowboy_Rob
Member#: 194062
2003 Impreza WRX
Post a closeup pic of the end of the cam with the gear removed, a pic showing the whole front of the cylinder head with the inside timing cover removed, and a pic of the back side of the cam gear. And when you take the inner cover off is the oil in between the head and inner cover or mostly on the front side of the inner cover
cowboy_Rob is offline   Reply With Quote
Old 07-12-2013, 08:06 PM   #31
rustyg23
Member#: 277681
05 sti
I found that the dailpin hole in my cam gear is oblonged Idk how it happend cam gear was tight as piss but I'm wounding if that could be the problem some how ? Anyone that wants a pic of it or anything else text me 540-239-4183 my phone won't add pics on here
Old 07-12-2013, 08:14 PM   #32
cowboy_Rob
Member#: 194062
2003 Impreza WRX
This is his damaged dowel pin hole in the cam gear
Old 07-13-2013, 06:43 PM   #33
rustyg23
Member#: 277681
05 sti
Thank you rob. Bout to put head back on if any one have any more suggestions
Old 07-15-2013, 11:37 PM   #34
rustyg23
Member#: 277681
05 sti
Bumpp to the top .. thinking maybe the oil passages aren't lineing up bc of the worn dowlpin hole
Old 07-23-2013, 10:25 AM   #35
al_s14
Member#: 168077
Forgot about this post so may be too late, but my recomendation is to replace the gear. Reason being is that if wear is significant then being off center(from the dowel) may cause you to throw a cam gear advance code, that looks like a few degrees to me.
Second is that because its mangled up like that it may prevent the cam gear from going on all the wayand being flush with the cam butt. in which case you will have oil pressure bleed back around the cam back to the head. if too much flow cam seal may not be handling it.
Now this is super critical, Feed of oil from cam gear is returned back through one of those 3 holes. If holes are not flush it MAY bleed back around cam and leak at cam seal because those two small gaps by cam seal are and/ or plugged but more importantly not designed to handle that much oil colume and thus build up pressure behind cam seal and spray
Old 07-23-2013, 03:09 PM   #36
Half Crazed
Member#: 321842
2008 STi
I second this. when I saw the video i thought there's no way that much oil could be coming out of the cam seal.. if you don't align the dowel of the cam shaft to the avcs cam gear, then there won't be any sort of seal.. and you'll possibly damage your cam gear when tightening down the cam gear (as it'll either warp the dowel or warp the mating surface of the back of the gear).. considering the cam gear is about 70-80 ft-lbs of torque. (22 + 45deg). Cam gear replacement definitely a good choice for the best seal.
Half Crazed is offline   Reply With Quote
Old 07-24-2013, 10:20 AM   #37
rustyg23
Member#: 277681
05 sti
Thanks everyone I belive that was my problem.and have got it fidgured out now.. its been fun. Now time to finish breaking n my engine so I can go play
