Old 06-25-2013, 10:34 AM   #1
skep18
Member#: 214971
2014 WRX
Default Driveshaft Proper Seat into 6MT
Odd question here, but I'm messing with my head thinking about it. I am installing an STI 6 speed into an older GC chassis. Then installing the forward portion of the driveshaft into the transmission, it can go all the way forward until it feels like it hits something, preventing any further forward movement. However, when I go to install the carrier bearing on the driveshaft along with the 4 bolts connecting it to the rear half, it recesses aft just a little bit, like 1mm...
This has me primarily concerned about potentially leaking transmission fluid as I believe there may be a seal there that it needs to contact? Possibly less so, if there is some need for full contact on those splines that I'm not getting, thats also in my mind.
Anyone have experience with this? Is there supposed to be some wiggle room there? I have worked on my non-swapped WRX before in reinstalling the driveshaft, but I don't remember if I had the same situation as I just trusted everything fit together since it was all stock.
skep18 is offline   Reply With Quote
Old 06-25-2013, 10:44 AM   #2
skep18
Member#: 214971
2014 WRX
Did some searching and found a few photos that may explain my situation and put me at some ease. Seems like others are having varying depths of driveshaft forward whatever as well...
Granted, this could be due to aftermarket driveshafts, but given the U-joints in the system, I would suspect the configuration should allow some variances of depth during operation. Perhapt the seal is a radial one rather than an axial interface?
EDIT: After looking some more, seems the only/main seal is the radial seal that mates to the smooth portion of the OD on the front of the shaft. Also, 98% of the splines should still be in the same contact, so I don't suppose I should have an issue. I will update when I start up and run it, just for posterity's sake.
Old 07-14-2013, 12:29 PM   #3
fr0st_wrx
Member#: 126717
2006 WRX
Thats normal, you dont want it to sit all the way against the tail end of the trans because it spins. As long as it reaches the splines and isnt leaking fluid you're gtg.
fr0st_wrx is offline   Reply With Quote
