Old 06-26-2013, 05:49 PM   #1
Paidfor
Member#: 267815
Be in awe
dont hate .)
Default WTF Tactrix!!!!!!!!!!
Alrighty..............my laptop crashed so i got a new one. Now i installed tactrix and both sets of newest definitions and cant for the life of me get it to "see" the ROM. I can read it from the ecu but cant see any data. Any suggestions?
Paidfor is offline   Reply With Quote
Old 06-26-2013, 08:09 PM   #2
Paidfor
Member#: 267815
Be in awe
dont hate .)
It continues to try and search the web for a program to read the particular type of file. Ive never had an issue reading or writing .bin and .hex and whatever else type of files romraider , ecuflash and tactrix all supported till I broke my laptop. Ive got everything installed like I had before.....I think
Old 06-26-2013, 09:14 PM   #3
Okrsowner
Member#: 339285
Are you using windows 7 or 8? The newer windows does some tricky things with the def files.
Okrsowner is offline   Reply With Quote
Old 06-26-2013, 11:52 PM   #4
JonnyV2889
Member#: 197384
2006 WRX Ltd
Can you see the map in ecuflash once read? If so try putting ".hex" at the end of the file name when you save the ROM.
I have that issue in XP if I go to save a ROM, but don't put the extension it to won't open in romraider but the file is there in win explorer. You can simply rename the file from win explorer and just add ".hex" to the end and file type will change.
JonnyV2889 is offline   Reply With Quote
Old 06-28-2013, 10:18 AM   #5
Paidfor
Member#: 267815
Be in awe
dont hate .)
ok finally got a few bugs worked out. I am using windows 7.....my original issue was that i could read the rom but couldnt open it per the .hex extension.With ecuflash opened and tactrix 2.0 plugged in i could read the rom from the ecu, just couldnt view it. Got that solved by opening the correct romdata file for ecuflash. Problem is now i cant read from the ecu but i can download stock maps from romraider and open them just fine with ecuflash. I hook up to the obd port...and when i prompt ecuflash to read.....it pulls up a empty box that used to be full of different car models. Theres no model for me to choose from. Anybody had this issue before?
Old 06-28-2013, 12:15 PM   #6
JonnyV2889
Member#: 197384
2006 WRX Ltd
Try reinstalling ecuflash. Sounds like the definitions got lost somewhere.
Old 06-28-2013, 01:08 PM   #7
Paidfor
Member#: 267815
Be in awe
dont hate .)
^^^^^^^^^^^^Reinstalled Ecuflash and all is well
Im almost thinkin about a cobb tuner just because of the way tactrix does thing...having to manually move around files and unzippin**** back to back lol....so un user friendly...for me anyways
Thanks for the insight Jonny
Old 06-28-2013, 01:20 PM   #8
JonnyV2889
Member#: 197384
2006 WRX Ltd
You shouldn't have to unzip anything? I just have a tuning folder on the desktop with sub folders for maps, tools, logs, etc. Have romraider setup to save logs there. Pretty simple and everything is together.
You'll have a lot more freedom with the tactrix. And the AP is 3x the price.
Old 06-28-2013, 02:14 PM   #9
Paidfor
Member#: 267815
Be in awe
dont hate .)
^^^Thats what everyone keeps sayin lol
i agree....once its installed.....works perfect....i just always have a hell of a time installing it for the first time. If i could keep a working laptop, i wouldnt have been in this situation lol
Old 06-28-2013, 09:27 PM   #10
mikeyPSF
Member#: 236475
Jonny is right, you shouldn't have to unzip anything unless you're adding some definitions because yours isn't included. Can you try one more time and this time copy everything (top to bottom) that is in the right side 'Task Info' window and paste that in your reply here?
mikeyPSF is offline   Reply With Quote
Old 07-03-2013, 04:44 PM   #11
Paidfor
Member#: 267815
Be in awe
dont hate .)
im not computer savy so I don't know what any of the above means. Like I said...I dunno what was wrong but a second install fixed all my issues. I have a problem finding the file after downloading it.
Old 07-07-2013, 05:20 PM   #12
Andrewxxcarlson
Member#: 316415
2006 WRX
I had this issue, even I thought (being tech savvy) my romdata file was directed to the right file. And it ended up not. Double check cuz that's where they pull the ecu data file template from.
Andrewxxcarlson is offline   Reply With Quote
