Vancouver Impreza Club
Old 06-28-2013, 05:54 PM   #1
jagan323
Member#: 282909
2006 WRX STI
Default Exhaust Silencer removal
Hey guys,
I just got an Invidia G200 Exhaust, and it came with the silencer installed. Anyone ever deal with one of these? I removed this little bolt, and tried removing the silencer and it seemed pretty stuck. Any ideas on how to remove it? =p
Thanks
jagan323 is offline   Reply With Quote
Old 06-28-2013, 06:01 PM   #2
jchretien
Member#: 217235
1999 FoLEsTa EsTe-Ai
Canyon Red
Last time we removed a silencer from a invidia N1, we shoved the scissor jack handle inside and 2 guys pulled on it to get it out.
jchretien is offline   Reply With Quote
Old 06-28-2013, 06:09 PM   #3
RE3Rotor
Member#: 162465
04 Forester XT
12 Outback 2.5i
Get a threaded rod and some hardware and build a puller. MacGyver style.
RE3Rotor is offline   Reply With Quote
Old 06-28-2013, 06:15 PM   #4
Ctogo
Member#: 338399
2002 Impreza WRX
If you don't want it.. :-)
Ctogo is offline   Reply With Quote
Old 06-28-2013, 06:47 PM   #5
jagan323
Member#: 282909
2006 WRX STI
Wow, that hard to remove huh? Okay, I guess I'll have to use a bit of force then!
Old 06-28-2013, 07:48 PM   #6
belaud
Member#: 224449
2012 Kit B STI
Midnight ???
And my scissor jack handle was never the same again...
belaud is offline   Reply With Quote
Old 06-28-2013, 08:32 PM   #7
rs420
the cone killer
Member#: 157784
02 swapped bugeye
anthricite
You could try some taps with a hammer to loosen it up
then some good biting vice grips and man strength.
rs420 is offline   Reply With Quote
Old 06-28-2013, 09:50 PM   #8
DIGGYGV8
Member#: 313558
2011 STi Sedan
err... that wasn't an Invidia N1.. that was Kenni's exhaust no? Either way, bent one scissor jack twisty bar thingie and took two people to yank it out
DIGGYGV8 is offline   Reply With Quote
Old 06-28-2013, 10:07 PM   #9
Ricewagon
Member#: 59703
2004 STi
always wrb
Try removing it after the exhaust is hot. Wear gloves.
Ricewagon is offline   Reply With Quote
Old 06-29-2013, 02:25 AM   #10
2010 WRX Limited
Member#: 217458
1989 Mazda Miata
Classic Red
Rev the car up and it will pop out.
2010 WRX Limited is offline   Reply With Quote
Old 06-29-2013, 02:56 AM   #11
jagan323
Member#: 282909
2006 WRX STI
Thanks guys for the advice and help. I'll see what I can do... =/
Old 06-29-2013, 03:17 AM   #12
LilDragon
Member#: 203913
1999 2.5 RS
WRBlue & Rally Tattoo
Have you tried to spray some THUNDERBOLT/WD-40, and apply some heat? Such as a little torch?
LilDragon is online now   Reply With Quote
Old 06-29-2013, 01:41 PM   #13
jagan323
Member#: 282909
2006 WRX STI
No, I haven't tried yet. I've only tried moving it with my hands so far, and no budge. I thought I had perhaps a defective one, but since so many of you guys are saying it's a pain to remove, I know that this is normal lol.
I get that heat expands, but how hot should I get it? I don't know if I feel comfortable with a torch @_@. Could a hair dryer or heat gun work?
Logically, the force of pulling is much harder. The force generated from ramming on the other hand would be sufficient I think. I wish I could just ram something into the pipes from the other side, and knock it out.
Old 06-29-2013, 05:01 PM   #14
DIGGYGV8
Member#: 313558
2011 STi Sedan
It's just a matter of how seized it is in there. Cheap metal, esp some grades of stainless like to mingle under consistent heat and cooldown.
I've personally see many silencers which took an insane amount of force to come out (not recommended on the car as it would even go so far as to bend your hangers), and some that will never come out again and have been fused inside the exhaust.
Do what LilDragon said, and soak it in some "liquid wrench" or something and yes, you will need to heat the outside like crazy so that it can hopefully spread apart from the inner silencer. Again, do it off the car if you're worried.
Old 06-29-2013, 05:05 PM   #15
RX Renesis
Member#: 108624
'06 SlowBaLow
MEISTER
get a long metal pipe into the hole, push the pipe left right up down, ull see the silencer start to wiggle its way out, easiest way ive used, dont bother with soaking it
RX Renesis is offline   Reply With Quote
Old 06-29-2013, 07:46 PM   #16
RE3Rotor
Member#: 162465
04 Forester XT
12 Outback 2.5i
Up, Up, Down, Down, Left, Right, Left, Right, B, A, Start
Sorry, I had to.
Old 06-29-2013, 09:28 PM   #17
on9
Member#: 237527
Plug the "silencer hole" up with a pineapple - rev it and shoot it out?
on9 is offline   Reply With Quote
Old 06-29-2013, 09:35 PM   #18
Drakar
Member#: 68402
Sorry, I had to.
Select start for 2 player
Drakar is offline   Reply With Quote
Old 06-30-2013, 06:32 AM   #19
DIGGYGV8
Member#: 313558
2011 STi Sedan
your name plays very well with your reply
Old 06-30-2013, 07:24 PM   #20
jagan323
Member#: 282909
2006 WRX STI
I actually thought about it that, using the force from the torque. Thanks for letting me know that's how you did it. I think I may try this method first.
Thanks so much for everyones input. Can't wait to get the exhaust on. But I got an appointment with aircare, since my car is 2006. Once I pass it, I'll get to the install =D.
Is it actually true that Aircare is no more after 2014? Hoping.
Old 07-01-2013, 01:05 PM   #21
Imprezala
Member#: 160274
2000 ITR
PY
don't hold your breath
but I too hope it ends in 2014
Imprezala is offline   Reply With Quote
Old 07-01-2013, 02:30 PM   #22
Ctogo
Member#: 338399
2002 Impreza WRX
I was @ a Sussex the other day and the guy mentioned that it's already been pushed to 2015..?
Old 07-01-2013, 05:15 PM   #23
Drakar
Member#: 68402
Contract is up in 2014. Renewal would happen after that and there would be notice.
Old 07-01-2013, 05:51 PM   #24
jagan323
Member#: 282909
2006 WRX STI
Thank you guys for all the help! The metal bar trick did the job. Took me 5 minutes to knock that silencer out. Man, was it a tight fit, I can't even re-install it even if i wanted to! o_o
