Old 06-29-2013, 02:19 AM   #1
Redlights bro
Member#: 319237
2005 WRX STi
Default Problem with my Cobb Accessport
I have a 2005 sti with some mods Cobb up pipe, stock box, invidia downpipe and invidia n1 CBE. I recently got my Accessport and I installed the stage 2 91oct acn map on my car. And the car didn't run well at all my rpm needle would bounce around at idle and sound like it was about to die. I called cobb and they said that was normal and just drive around a little and it will go away. I did and the needle bounce was gone but the car didn't feel any better it didnt feel stage 2 at all. The engine sounded weird and whenever I would try to give it some gas after 3000 the car wouldn't reallt move I would just hear the turbo make sounds and my exhaust would crackle a bit. Like id push on the gas but my car was like no i'm not going. So I went back to stock and the car runs somewhat normal again, i'm just wondering if this is normal or whats going on here??....I am also getting it pro tuned on tuesday will that fix this issue? Thanks!
Redlights bro is offline   Reply With Quote
Old 06-29-2013, 04:20 AM   #2
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
Sounds like a problem with your car, not your AP.
Have your tuner check out your car before he tries to tune it.
jebjkey is offline   Reply With Quote
Old 06-29-2013, 01:22 PM   #3
Redlights bro
Member#: 319237
2005 WRX STi
But the car was running fine before with the the tune I had. I will have them check it out though.
Old 06-29-2013, 05:42 PM   #4
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
Are you positive it's not flashed with the vallet map? Similar things happen as you describe.
Did you happen to log this happening?
Cathexis is offline   Reply With Quote
