Old 06-30-2013, 08:04 PM   #1
SaskSuby
Member#: 243362
2004 Impreza WRX
Default First Log. Fine Knock Feedback
2004 Wrx with 107,000km.
Turboback exhaust
Previous owner told me he had an "off the shelf map" flashed. Would like to look into a more specific tune for my car.
First Log
Second Log
Edit: Oh, I'm also wondering what kind of maps are erased when the battery is unplugged. I've had my battery unplugged a couple times while doing some work on my car.
SaskSuby is offline   Reply With Quote
Old 06-30-2013, 09:20 PM   #2
mikeydrives1
Member#: 262117
2001 Forester
STi II type M
Well, reseting the ECU will reset the learned Knock (fine knock) and all your learning values (A, B, C, D) as well as the general idling of the car.
Yeah, that feedback knock is not learned stuff, thats happening in realtime. Its pulling timing due to it (-2.11 degrees) . Think of it as a safety feature of these cars. It will reduce timing until it sees the knock event go away. If knock doesnt go away, it will then resort to reducing the IAM / DAM value to reduce timing globally.
Looking at the logs, it seems pretty consistent from about 5800+ for both pulls. I dont see any timing logged on there, but if i had to guess, it may have to be trimmed back a little. The boost looks relatively stable and tapers off, not being too far from its desired target.
What kind of local weather conditions are occuring during these pulls? Keep in mind, hot weather has a tendency to heatsoak our Top-mounts, and if you go to do a pull after sitting, even just for a little, its possible to generate a little knock from the excess heat.
mikeydrives1 is offline   Reply With Quote
Old 06-30-2013, 09:53 PM   #3
SaskSuby
Member#: 243362
2004 Impreza WRX
Yeah, it was around 30 degrees Celsius. Car was sitting for about 3 hours. Drove around for 10 minutes and did two pulls.
Old 06-30-2013, 10:10 PM   #4
mikeydrives1
Member#: 262117
2001 Forester
STi II type M
well, 30 * C is fairly warm if my conversion to degrees F isnt too rusty. Heres the thing though, once you get a few moments of airflow through the intercooler, its nearly back down to normal temps. Hot weather in general can be the cause of knock. This is something that has to be addressed by a tuner generally by adding a little more fuel in the affected areas, as well as reducing boost and/or timing as well, and seeing if that alleviates the knocking.
Next question. What octane fuel is available out there?
Old 06-30-2013, 10:13 PM   #5
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
You might be maxing out your injectors. Add injector duty cycle to your logged parameters. You might also consider getting a wideband to check your AFR's.
nmlittlebigman is offline   Reply With Quote
Old 06-30-2013, 10:24 PM   #6
SaskSuby
Member#: 243362
2004 Impreza WRX
Octane that is available is 94,92,91
Old 07-03-2013, 11:59 PM   #7
SaskSuby
Member#: 243362
2004 Impreza WRX
Did a few more logs today. Was way cooler.
Log 3
Log 4
Log 5
Old 07-05-2013, 09:14 PM   #8
Speedy Claxton
Member#: 256284
07 stage 2 STi
ewg & Phatron tuned
you have something going on. Your FLKC is .35 through all the pulls and your IAM is at 15 now.
Speedy Claxton is offline   Reply With Quote
Old 07-06-2013, 10:23 AM   #9
nmlittlebigman
Member#: 321409
2003 Big Effing Van
Your wastegate duty cycle immediately goes to 100% and stays there. Find a tuner.
Old 07-07-2013, 12:34 AM   #10
SaskSuby
Member#: 243362
2004 Impreza WRX
Getting dux10 to look at it/tune
