Welcome to the North American Subaru Impreza Owners Club Friday August 1, 2014
Old 09-16-2013, 12:48 PM   #1
qtr_wrx
Member#: 109567
Default extremely hot cabin... 07 sti
I'm not sure whats wrong with my car!
Short story its a low mileage 07 sti that I got few months back and I'm not driving it every day as I have another dd car.
Anyway it only has I/h/e and since day 1 I noticed the engine bay is so #!@&ing hot to the point that I can't keep my finger more than 2 sec if I wanted to open the engine hood. Temp gauge is normal and fans are running too.
Now I'm suffering inside too, even when ac att full I can feel so much heat coming under me. I at the beginning thought maybe its only me, but also gf and friends noticed it
Any suggestions? Whould heat warps helps and a lower temp thermostat help???
qtr_wrx is offline   Reply With Quote
Old 09-16-2013, 01:56 PM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
check to make sure the exhaust shields are still attached under the car.
PARANOID56 is online now   Reply With Quote
Old 09-16-2013, 10:21 PM   #3
wadowrx
Member#: 343621
2012 Impreza WRX
Dark Metallic Gray
I second this thought.....can't see why anyone would ever remove them except for weight savings...even though they don't weigh much
wadowrx is offline   Reply With Quote
Old 09-17-2013, 12:26 AM   #4
EnderDragoon
Member#: 300176
A WRX I'm working on right now has some seriously rusted shields/shrouds around exhaust. I can see why someone would remove them for working on other such things and left unable to reinstall the parts (grinder required to remove them). If one felt like it was an unimportant component they would just leave them off.
EnderDragoon is offline   Reply With Quote
Old 09-17-2013, 02:10 AM   #5
Uncle Scotty
OK Houston
we have an Uncle
did the car get flooded??
are there rodents living in it???
is the heat on
Old 09-17-2013, 02:43 AM   #6
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
i have no heatshields except for a cobb one covering my turbo and my car does not get hot like that unless i have the heat on. The hood has the heat blanket removed from it which, at least on my previous hood, seemed to keep the hood temps down a decent amount as the material would just trap the heat from the engine bay. Your info says your location is Qatar?? If that's the case have you ever considered that it gets really really REALLY hot in the desert??
brew02wrx is offline   Reply With Quote
Old 09-17-2013, 02:43 AM   #7
Dat8687
Member#: 243261
2004 WRX
Java black pearl
Is it hot outside.. MY friend made the mistake of leaning the hood prop against his neck.
BURNT him.. And my car runs at normal operating temps
Dat8687 is offline   Reply With Quote
Old 09-17-2013, 02:56 AM   #8
Uncle Scotty
OK Houston
we have an Uncle
yeah....it does get a lil warm underhood in texis in the summer
i put a ptp terbo blanket on my terbo and it tamed the underhood heat a bit...but that prop rod will put a mark on ya if ya let it
Old 09-17-2013, 12:41 PM   #9
Big-E
Member#: 123843
2006 WRX Sedan SGM
Let LED's light your way!
OP, you are in a country where the ambient temperature has been around at least 100-degrees Fahrenheit.
The WRX/STI is not very well insulated to begin with; its effectively a performance car with minimal insulation.
The exhaust will of course get hot and that heat will come into the passenger compartment vis-a-vis the transmission / prop-shaft tunnel. Then add the outside ambient heat and voila, its hot inside as well.
You can and probably should have the cooling system inspected and/or serviced as well as for doing the same with the a/c system
