Old 07-01-2013, 02:32 AM   #1
Karce.
Member#: 323452
2012 WRX Limited
Dark Grey Metallic
Default Solution to stock radio quality - Amp or Headunit?
Hey all,
I'm looking for a solution to the sub-par quality of the stock sound system of a 2012 WRX. After much research, I have boiled down to two options:
1. New head unit (something like AVHS5500, costing around $400 plus harness, bypass, steering wheel module, dongle to keep center console USB/aux, etc)
2. Amp after the stock head unit to increase power to stock speakers. (Any recommendations?)
What is the most bang for the buck solution? I am not looking for anything amazing but just want an average sound system that should have came stock. New head unit is nice due to the screen and all, but if its double or triple the cost without a justified increase in result then the amp may be a more economical solution. I have no plans for better speakers or a sub in the future. I may do some sound deadening but that's mainly for road noise.
Any thoughts or recommendations would be much appreciated!
Karce. is offline   Reply With Quote
Old 07-01-2013, 12:39 PM   #2
locozildjiangodx
Member#: 355323
2013 WRX Limited HB
WR Blue
I am not sure about the amp, but I just did a new HU (Pioneer DEH 9500BHS) and it sounds 100x better to me on stock speakers.
locozildjiangodx is offline   Reply With Quote
Old 07-01-2013, 12:43 PM   #3
G-Sep
Member#: 346983
2013 13 WRX rolling
on oranges
I think even having an amp with the stock head unit won't be good. I remember my stock hu switching from radio to usb, there was a huge volume increase. I don't think an amp will remedy that.
I could be wrong, but I am happy with my z140bh from pioneer.
G-Sep is offline   Reply With Quote
Old 07-01-2013, 02:03 PM   #4
klarowe
Member#: 284753
2004 WRX STI
World Rally Blue
The best thing you can do to start with upgrading the sound quality is new speakers. Yes the amp will allow you to go louder without having to turn the head unit up as high (higher volume levels = more distortion) but you will still be limited by the factory speakers. Yes a head unit will also increase sound quality slightly by providing slightly more power to the speakers as well as giving you more control of the sound, but speakers have the greatest impact on sound.
Start with the speakers, then a 4 channel amp (and amp & sub if you need additional bass), and work from there.
klarowe is offline   Reply With Quote
Old 07-01-2013, 02:09 PM   #5
Captdonno
Member#: 358459
2013 WRX
WR Blue Pearl Sedan
^ Above is correct. Start with speakers and go from there. You'll immediately notice a large difference in sound clarity and loudness with speakers. After that go head unit to drive more power to those speakers. If you do it right, you can get 4 speakers and a decent head unit for under $300. If you must have a touch screen or navi though, you may as well finish with a sub and amp for the hundreds you'll be spending. Just my buck o' five worth of sense.
EDIT: I'm a pioneer fan personally, hit up crutchfield and check out some prices.
Captdonno is offline   Reply With Quote
Old 07-01-2013, 03:13 PM   #6
mrkyle3
Member#: 272675
2011 WRX
2004 Miata
Upgrade the head unit first. I upgraded and immediately had an amazing increase in quality. The OEM speakers aren't half bad but the head unit is horrendous. I also put in an underseat sub at the same time.
My head unit is the clarion cx501. You can change the colors and the red is a perfect match for our red. All my steering wheel controls work except for hanging up a phone call but that's not a big deal. I got a steering wheel control module.
mrkyle3 is offline   Reply With Quote
Old 07-01-2013, 03:26 PM   #7
locozildjiangodx
Member#: 355323
2013 WRX Limited HB
WR Blue
I highly disagree with switching speakers first. Step 1 is head unit. The stock head unit is REALLY underpowered which is why they sound like crap. New headunit should power them far better AND give you a better EQ setup which = much better sound.
Old 07-01-2013, 03:33 PM   #8
klarowe
Member#: 284753
2004 WRX STI
World Rally Blue
It depends on what you are looking for. For function and added features then yes, head unit first. But for sound quality, speakers are always the go to first upgrade. New head units do not give THAT much power over factory. Most aftermarket head units are usually 15-20 watts (maybe 25 watts) RMS per channel. The factory head units are typically (this is on average, not sure what the actual Subaru power rating is) 10-15 watts RMS per channel. This slight difference is not that great. It may sound it, but that is just because there are more controls of the sound. Most factory speakers are also power matched to the head unit so you will actually be over-powering them. The factory speakers are also made of poor quality material (usually paper and foam surrounds). Where-as a decent aftermarket speaker is usually poly and rubber (depending on the speaker). This allows easier movement of the speaker and better sound.
My advice is coming from 10+ years in the car electronics industry including currently owning my own mobile electronics install shop (part time).
Old 07-01-2013, 03:36 PM   #9
mrkyle3
Member#: 272675
2011 WRX
2004 Miata
Speakers are first for sound quality usually but in these cars head unit first. That's just the way it is.
Old 07-01-2013, 04:57 PM   #10
Karce.
Member#: 323452
2012 WRX Limited
Dark Grey Metallic
Interesting debate going on!
I do hear that speakers are a first for most cases but I have read on here somewhere that the stock speakers aren't that bad. Its just that the stock head unit doesn't output enough power to them, hence the new head unit/amp solution that I was originally thinking of.
If I were to change HU, I'd probably go double din for the screen and added aesthetics of a higher class looking unit. This drives the price to over $500 or more.
Versus an amp (maybe 150-200?) Is it worth it in terms of quality of sound? The screen is nice for navigating files and more lines for texts but that's about it.
Also what are the chances of overpowering the stock speakers?
Old 07-01-2013, 07:21 PM   #11
blzr25x
Member#: 337689
2013 Impreza Premium
DGM Sedan
Change the HU first, it makes the sound so much better with the stock speakers. Then I uograded the speakers. I put my stock HU back in after selling my previous HU and waiting for my new one to come, and then sound is awful even with upgraded speakers. Definitely go with a new HU first.
blzr25x is offline   Reply With Quote
Old 07-01-2013, 07:53 PM   #12
CRAZYHAWK
Member#: 198067
2009 IMPREZA 2.5i 4d
WHITE Premium
If you're happy with the OEM HU features, go with an Amp. and
separates. Separates sound better than coaxials and require an amp.
CRAZYHAWK is offline   Reply With Quote
Old 07-01-2013, 09:34 PM   #13
Mike 01Hawk
Member#: 219162
2011 WRX Sedan Base
NO AND NO!!!
The GR Silver weave 20w fronts are DAM good for stockers.
Mike 01Hawk is offline   Reply With Quote
Old 07-01-2013, 09:41 PM   #14
Mike 01Hawk
Member#: 219162
2011 WRX Sedan Base
Mat the doors. The mid bass improvement is phenomenal.
$80 for 25sq/ft will be more than enough to do the inner/outer front door skin with let overs to do spot applications down the road
http://www.ebay.com/itm/Mega-Mat-25-...-/190709871430
Power doesn't blow speakers, distortion does. I've run 125w to stock speakers before. No problem at all. They get dam loud too
Amp recommendations
Something in the Class D range. Cool, small, and cheap. Something like a PPI 600.2 for $140 or a PPI 900.4 for $180
Yummy
Old 07-01-2013, 09:48 PM   #15
klarowe
Member#: 284753
2004 WRX STI
World Rally Blue
Ahh... I wasn't aware the new Subarus had a higher quality speaker. What materials are they made out of? I have yet to see a standard OEM audio system (non Bose, etc) that came with quality speakers...
Old 07-01-2013, 09:50 PM   #16
dsn112
Member#: 332561
2016 ChargerScatPack
I went amp, speakers, processor, small sub, $650 or so with all wiring and matted the doors and hatch, looks stock and sounds amazing.
dsn112 is offline   Reply With Quote
Old 07-01-2013, 10:02 PM   #17
Mike 01Hawk
Member#: 219162
2011 WRX Sedan Base
I replaced my stock fronts with some CTX65cs components just cause I had them laying around. Honestly it was a huge waste of my time, labor, and $.
Old 07-01-2013, 10:52 PM   #18
klarowe
Member#: 284753
2004 WRX STI
World Rally Blue
Those actually are quite better than normal. I'm still not a huge fan of the surround (I prefer a rubber surround for smooth sound) but the cones do look solid.
Old 07-01-2013, 10:58 PM   #19
mejifair
Member#: 11356
2012 WRX STi Hatch
Don't really agree with this. I put an Alpine 5 channel in my car with the stock head unit. Even with the stock speakers it made a world of difference. The Alpine has the high level inputs, so you don't need a line converter in between.
I was shocked at how much better it sounded, and I did not have to worry about what to do with the steering wheel controls, mic and USB/AUX ports in the armrest.
I did end up upgrading the speakers and putting in a sub, but the quality was very good after putting in the amp.
mejifair is offline   Reply With Quote
Old 07-01-2013, 11:14 PM   #20
Karce.
Member#: 323452
2012 WRX Limited
Dark Grey Metallic
Did the amp remedy the crappy radio issue? Or is that a problem with the actual feed from the head unit?
Old 07-01-2013, 11:15 PM   #21
Karce.
Member#: 323452
2012 WRX Limited
Dark Grey Metallic
How do these compare to other ones such as dynamat or raamat? Actual quality difference or just brand?
Thanks for all the help and input everyone!
Old 07-01-2013, 11:25 PM   #22
tilegend
Member#: 295565
I was surprised when i popped the door panels and didn't find the the usual paper cone speakers.
tilegend is offline   Reply With Quote
Old 07-03-2013, 02:51 AM   #23
Mike 01Hawk
Member#: 219162
2011 WRX Sedan Base
Butyl is butyl. Mass is mass. What I linked worked great for me for 2 cars and is cheap
Old 07-03-2013, 08:36 AM   #24
dsn112
Member#: 332561
I used that roll of duct insulator from the depot and did my whole car for like $40
Old 07-03-2013, 09:36 AM   #25
nightdown fox
Member#: 309636
2015 STI LE
WRB on Gold!
I am too...! Z140BH, stock speakers, and a Rockford Fosgate 2 channel amp powering a 12 inch sub in the trunk gives ample sound for me.
Sidenote: If you get a late model Pioneer head unit, MAKE SURE YOU GET THE OPTIONAL MICROPHONE AND DO THE AUTO EQ!!! Makes a HUGE difference in sound... The stock Z140BH setup wasn't accurately using the tweeters. Auto EQ on a Pioneer system is a night and day difference in sound quality.
nightdown fox is offline   Reply With Quote
