Old 07-01-2013, 06:22 PM   #1
gallandof
Member#: 285698
2013 BRZ
Galaxy Blue
Default h9 bulb melted harness
so tried the H9 bulb conversion on my 2011 WRX, and on my passenger side the actual wire harness got melted. Before I jump into this I just want to make sure that I can buy a h9 wiring harness and just cut the existing one out.
I'm thinking the cause was because I was stuck in traffic for about 3 hours in 90+ degree's and usually just leave my lights on auto.
gallandof is offline   Reply With Quote
Old 07-01-2013, 06:38 PM   #2
Notch 8
Member#: 355254
Wattage of bulb too high.
Please post pictures of your car when it catches on fire.
Thanks.
Notch 8 is online now   Reply With Quote
Old 07-01-2013, 06:42 PM   #3
gallandof
Member#: 285698
2013 BRZ
Galaxy Blue
I figured it was too high, but since there's a good amount of people who have done it (here on nasioc and on other forums [http://forums.nasioc.com/forums/show...83911&page=13]) might as well give it a shot since my bulbs randomly blew the other night. But i'm not here to bitch about the fact that I apparently goofed up somewhere. I'm just looking to see if a simple wire harness swap is fine or if there's something more to worry about.
Old 07-01-2013, 07:34 PM   #4
04ScoobyWtf
Member#: 287974
You shoukd be able to buy the harness from the dealer and its not hard to replace.
04ScoobyWtf is offline   Reply With Quote
Old 07-01-2013, 08:35 PM   #5
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
No, do not buy or attempt to buy a harness from the dealer. They don't sell just the ends and the harness is expensive.
Replace the connector, lengths of wire, and either solder and shrink-wrap or use butt-connectors with shrink-wrap tubing built-in.
Connector: http://www.rallylights.com/all/elect...terminals.html
If you want to go beyond the OEM wattage, which is not necessarily recommended, then you would have to consider building or buying a headlamp wiring harness that uses heavier gauge wiring, ceramic connectors, and external relays. The OEM harness is barely good enough for the 55/65 watt bulbs in the car as it is.
Old 07-01-2013, 09:10 PM   #6
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
That's interesting, the H9 is technically more wattage, 55 vs 65, so many have done this conversion and there are little reported problems. I had H9s in my WRX for a few years. But I guess you do take a risk even with slightly more wattage.
Power6 is offline   Reply With Quote
Old 07-02-2013, 02:42 AM   #7
ChillinAussie
Member#: 288157
2004 WRX
Grab some HID's, the wattage can be lower with a better result
ChillinAussie is offline   Reply With Quote
Old 07-02-2013, 08:31 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
ive been running the osram h7 rallye 65w bulbs---which is the h9 burner on the h7 base... in my 06 since it was new....never melted anything
sometimes it not pushing the connector onto the bulb hard/far enough causes water to enter and corrode the contacts causing increased resistance and THAT causes the issue with melting
Old 07-02-2013, 08:32 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
Old 07-02-2013, 01:40 PM   #10
gallandof
Member#: 285698
2013 BRZ
Galaxy Blue
trust me if I could do a full retrofit setup I would, but as of now it's not in the budget.(and crappy HID in the stock housing is just down right dumb)
Scotty, i'm thinking thats what it is. Probably didnt file the extra nub down far enough and the light probably popped out from the resistance.
also thank Big-E, i'll check that out.
Thanks for the helpful responses as well!
Old 07-03-2013, 01:37 AM   #11
smiley9k
Member#: 182485
... posted wrong
smiley9k is offline   Reply With Quote
Old 07-03-2013, 08:02 AM   #12
fistv
Member#: 350063
2013 Impreza sport
When I went to 130/90 H4's in my Cherokee I built an auxiliary harness and used the old one to trigger the new one. Even the 90w lows were too bright hot for the Hella ecodes so I moved it over to my wrangler with it's CIBIE 7" round old school glass/steel housings, wranglers headlights sit way high so I had to do some serious adjusting down. Aux harness is easy to build, two relays, 10ga wire, shrink tubing, two bulb sockets and one male plug to plug into one of your old headlight sockets and some split tube to keep it neater.
fistv is offline   Reply With Quote
Old 07-03-2013, 08:14 PM   #13
2subiesinyard
Member#: 139562
2015 Launch Edition
WRBoo
So the other night you popped both bulbs? At the same time? If this is true, than I think there is some other underlying problem. Frayed wire, water or poor contacts that increase the resistance. I've been running the H9's for almost a year now, and leave them on almost all the time, even during the day. Never had an issue.
2subiesinyard is offline   Reply With Quote
Old 07-04-2013, 08:34 AM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
yer a real ashole runnin 130/90's on the street...blinding oncomming traffic...real ashole
Old 07-04-2013, 11:59 AM   #15
2subiesinyard
Member#: 139562
2015 Launch Edition
WRBoo
I'd have to agree with Scottie on this one. A good friend of mine ran his motorcycle into a hill because someone turned the corner at him and had about 6 (90+) watt lights over the cab of his truck, and the high beams on. All my friend could do was scrub off speed before he hit the hill. Asswipe in the truck just kept driving away.
Old 07-05-2013, 08:10 AM   #16
fistv
Member#: 350063
2013 Impreza sport
The TJ was an off roader, not even close to being street legal. One other comment, an aux harness will improve quite a bit on the light, the 14 ga that is used in most stock wiring has to travel quite a way from the bulbs to the power source, adding a aux harness with it's own relays and 10 ga wire only travels a short distance.
Old 07-06-2013, 08:44 AM   #17
2subiesinyard
Member#: 139562
2015 Launch Edition
WRBoo
Then our apologies
