Old 07-10-2013, 01:16 AM   #1
Speedwagon
Member#: 19681
1998 Legacy Wagon GT
Green
Default I have a rusty problem
1998 Legacy: Today, I was going to swap out my rear diff and rear lateral links. But I encountered a bit of an issue doing this.
When I tried to get the long bolt out of the lateral links to hub, they seem to be frozen in place and won't turn, despite getting the nut off(off one side at least). As well, the alignment bolt that connects the lateral link to the cross member is frozen to the inner sleeve on the bushing.
Any advice on how to get them off? I have replacement bolts that aren't rusty from the junkyard car.
Speedwagon is offline   Reply With Quote
Old 07-10-2013, 08:48 AM   #2
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
spray a lot of liquid penetrant at the head of the bolt and every joint the entire length. let stand and apply lots more, let stand. and apply more. try turning the bolt with an impact wrench. you can try to hammer out to loosen. As a last resort you may need to cut the bolt and punch out in sections. you can't heat the bolt as you'll burn bushings. apply anti seize liberally on the new bolt and threads.
mhoerath is offline   Reply With Quote
Old 07-10-2013, 09:15 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
get a sawsall and start cutting
they arent gonna come off...you will need all new lateral links and replace the trailing link too...and ALL the hardware
no sense ****ing around....just cut and replace
Old 07-10-2013, 10:46 AM   #4
Speedwagon
Member#: 19681
Green
Argh. I was afraid of such a thing. Don't want to replace everything, but at least I can find non-rusty parts at the junkyards out here. Guess I'll have to dedicate a whole day to doing this in the near future.
Old 07-11-2013, 01:42 PM   #5
yosemitemtb
Member#: 23437
'02 WRX Wagon
Original owner blue pearl
If you have a compressor, I've had luck freeing rusty stuff with an air hammer. A nice, long, well-fitting wrench to turn stuff while you or someone else applies the bra-a-a-a-ap to the bolt with the hammer with a blunt tip.
yosemitemtb is offline   Reply With Quote
