Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Notices
Old 07-10-2013, 08:25 AM   #1
egorka
Member#: 34290
2003 WRX
Sonic Yellow
Default Installer in Scranton / Wilkes-Barre, PA (Turbo Back Exhaust)
Are there any reputable installers in the Scranton / Wilkes-Barre area?
I have a 2003 WRX and I need to install a Cobb Turbo Back Exhaust. I'll provide all the parts and gaskets, new bushings, etc.
I'm installing out of necessity, as my muffler and cat have holes in them... So might as well 'upgrade'.
Any help would be appreciated.
Thanks,
Eric
egorka is offline   Reply With Quote
Old 07-10-2013, 12:27 PM   #2
PA-Outback2000
Member#: 161832
2000 Outback Limited
Dell 'Aglio Automotive on Rte. 307 near Lakw Winola - 378-2996
Conyhnham Auto Service on 297 Main St, Conyngham - 788-4893
Do it yourself..?
PA-Outback2000 is offline   Reply With Quote
Old 07-10-2013, 06:06 PM   #3
devs05wrx
Member#: 128259
2013 Rex
darkest of the grey
Drive a few extra miles and go to conygham auto in sugarloaf, ask for mark
devs05wrx is offline   Reply With Quote
Old 07-10-2013, 09:20 PM   #4
egorka
Member#: 34290
2003 WRX
Sonic Yellow
Thanks guys. Two recommendations for Conyngham Auto, and it's only 23 minutes away.
Old 07-11-2013, 10:22 AM   #5
DisrupTer911
Member#: 352071
2013 Impreza WRX
Dark Grey Pearl
why not have a BBQ install day and get some ppl over to help? probably save you a ton of money doing it that way
DisrupTer911 is offline   Reply With Quote
Old 07-11-2013, 11:40 AM   #6
RemlapaN
Member#: 58251
2004 Sti
GT35R 530whp @ 27psi
Keep in mind,
At minimum you will need a Cobb AccessPort to accompany your TBE. Ideally, you'd get a tune to go with the exhaust.
Just bolting on an exhaust without touching the ECU won't make for a very happy car in the long term.
RemlapaN is offline   Reply With Quote
Old 07-11-2013, 12:03 PM   #7
PA-Outback2000
Member#: 161832
not sure if mark will tune though. you can probably just do that with the accessport after the install. i'd also think about a header, up-pipe, and maybe an intercooler.
egorka... what are you doing july 27?
Old 07-11-2013, 01:12 PM   #8
egorka
Member#: 34290
2003 WRX
Sonic Yellow
Default Exhaust
I ordered the full Cobb stage 2 kit, including Accessport yesterday. Its going to be about 1-1/2 to 2 weeks before the exhaust gets here from what I am told. It's actually the first modification I'm going to have to my 2003 Sonic Yellow WRX (except for a K&N Air Filter and an STI hood scoop).
From what I understand, I probably also need to get a new donut gasket, turbo to downpipe gasket, and I should probably also invest in some new exhaust hangar bushings?
PA-Outback2000- I'm not doing anything in particular on the 27th.
Old 07-12-2013, 08:03 AM   #9
PA-Outback2000
Member#: 161832
there's a BBQ in nj at paul miller subaru. it is part of the "monthly tri-state drive" group's monthly events. as of now, pushnpounds and i are meeting, either in blooming grove or milford to cruise to the steakhouse, then meeting up with the group there to go to the event.
http://forums.nasioc.com/forums/show....php?t=2314349
Old 07-12-2013, 08:05 AM   #10
PA-Outback2000
Member#: 161832
where are you located?
Old 07-12-2013, 09:38 AM   #11
my name is joe
Member#: 171412
Why would you need a new donut gasket if you bought a full turboback new? Or did you buy a cat back.. This is something REALLY simple to do. Grab a friend and spend some time on it. It takes me less than 10 minutes to swap an exhaust out.
my name is joe is offline   Reply With Quote
Old 07-12-2013, 10:18 AM   #12
egorka
Member#: 34290
2003 WRX
Sonic Yellow
Located in Mountaintop, between Wilkes Barre and Hazleton.
Old 07-12-2013, 10:19 AM   #13
egorka
Member#: 34290
2003 WRX
Sonic Yellow
I didn't know if the turbo back included those gaskets- wouldn't I need at least a turbo to downpipe gasket? Or is that included?
Old 07-12-2013, 10:31 AM   #14
my name is joe
Member#: 171412
Call where you bought it from and ask what it comes with
Old 07-12-2013, 12:07 PM   #15
PA-Outback2000
Member#: 161832
will you be joining our caravan?
we can meet up at tigue st. if that works. i was planning to leave my house around 8:45am or so.
Old 07-12-2013, 07:33 PM   #16
pushnpounds
Member#: 207683
02 bugeye
wrb
egorka I can install that for you. I have done a lot of exhausts as well as many other things.
pushnpounds is offline   Reply With Quote
Old 07-12-2013, 09:17 PM   #17
egorka
Member#: 34290
2003 WRX
Sonic Yellow
Thanks guys. I appreciate it. I'll let you know once the exhaust arrives, should be a week or two. Apparently the turbo back is back ordered and does not come with turbo to dp gasket or donut gasket. It does come with the mid pipe gasket though.
My accessport is coming early though, so maybe I can play around with that.
Not sure about the caravan though. I'll know better when the time gets closer. Usually I work on the weekends, but I can pretty much make my own hours depending on the workload.
Eric
Old 07-12-2013, 09:48 PM   #18
DisrupTer911
Member#: 352071
2013 Impreza WRX
Dark Grey Pearl
Originally Posted by RemlapaN View Post
Keep in mind,
curious as to why a tune is needed for an exhaust swap
Old 07-13-2013, 09:48 AM   #19
RemlapaN
Member#: 58251
2004 Sti
It's not needed if you are just doing a cat back exhaust and retaining the stock down pipe. But it you swap downpipes, most cars will over boost due to the reduced back pressure. So you end up needing a tune or just a stage 2 access port to keep everything in check.
Especially in the northeast. You'll have issues in January when the temps drop.
Old 07-13-2013, 12:14 PM   #20
egorka
Member#: 34290
2003 WRX
Sonic Yellow
I believe the 02-03 ECUs are pretty forgiving, but anything 04- needs a tune.
(At least that's what I've been reading.)
I purchased the accessport just to be safe.
Eric
Old 07-13-2013, 05:49 PM   #21
DisrupTer911
Member#: 352071
2013 Impreza WRX
Dark Grey Pearl
Ahh okay Thanks for the clarification!
Old 07-14-2013, 12:05 PM   #22
crxgator
Member#: 39017
2000 Audi S4, 323iT
You might as well do an uppipe while you're in there.
crxgator is offline   Reply With Quote
Old 07-14-2013, 12:58 PM   #23
pushnpounds
Member#: 207683
02 bugeye
wrb
an uppipe takes several hours to install. doing the tbe doesn't really make it much easier to do the uppipe.
Old 07-14-2013, 01:17 PM   #24
crxgator
Member#: 39017
2000 Audi S4, 323iT
Yeah it does make it easier. You have to take th downpipe off to begin with. An uppipe will take an extra 30 mins to an hour. You must not work on your own cars.
Old 07-14-2013, 01:27 PM   #25
jthatch12
Member#: 321715
03 Big 16G WRX
If you can do an uppipe in 30 mins to an hour I would be shocked. At MINIMUM its a 3.5 hr job and that's the record. On average it takes 5 hours
jthatch12 is offline   Reply With Quote
