Old 06-30-2013, 09:55 PM   #1
05stage2
Member#: 307545
2005 wrx
2.1 stroker on e85
Default jdm ej205 wrx engine HELP
So I spun a rod bearing in my 2005 wrx. I can buy a jdm wrx motor on ebay for about $1600 shipped to my door. Are the motors the same? Would it work with my ecu? Please help. Thanks! Here is a link: http://www.ebay.com/itm/171057163097?redirect=mobile
05stage2 is offline   Reply With Quote
Old 06-30-2013, 10:39 PM   #2
zandander
Member#: 281895
2005 Impreza WRX
the engines are different. Lookup EJ207
zandander is offline   Reply With Quote
Old 07-01-2013, 12:14 AM   #3
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
New ej205 Short Block is around 1800. That's the easier way to go.
Fierysun is offline   Reply With Quote
Old 07-01-2013, 11:15 PM   #4
05stage2
Member#: 307545
2005 wrx
2.1 stroker on e85
It can add up quickly with short block, gaskets, head bolts, timing belt, etc. The seller said that you have to use your usdm intake manifold, crank sprocket, crank sensor, and I think that's it.
Old 07-02-2013, 06:44 PM   #5
Fierysun
Member#: 82745
2005 Subaru STI
You'll have to replace the timing belt etc anyways on the used motor. The only thing you need to buy differently is the HG with the new SB and it's brand new and not some questionable condition used engine which you have to swap a bunch of stuff over to try and get working. Your call, time, and money.
Old 07-02-2013, 07:32 PM   #6
05stage2
Member#: 307545
2005 wrx
2.1 stroker on e85
I will do the shortblock thanks foe the help bud!
Old 07-03-2013, 04:41 PM   #7
OkobojiClassicCars
Member#: 338524
2003 WRX
http://www.jdmracingmotors.com/engin...or_AVCS_model_
This is the company i used and this is actually the motor i bought back in january. At the time I had a company in Minnesota install it and it was $1200 total, but put on tbe no cats, up pipe, short throw, pitch stop, gates racing timing belt, tomei timing belt guide, cobb ap, perrin intake, and a few other smaller mods. We left the avcs unplugged for the time being. But Im ordering a JDM ecu to run the avcs and had the jdm IM tgvs deleted and those are going in soon. This motor runs great when it gets good premium fuel, if all you have in yur area is 91 they dont like it. I run 93+ and soon will run e85 and a vf22.
I dont regret not getting a new short block, it would have been way more expensive in my opinion.
OkobojiClassicCars is offline   Reply With Quote
Old 07-03-2013, 04:52 PM   #8
Masta Splint
Member#: 189211
2005 18g WRX wagon
Your better off sticking with the same 1 you have if you wanna keep cost down. Youll have to change quite a bit to make the JDM work. Why not buold a hybrid and use a STi shortblock and re-machine your WRX heads, youll get more displacement and be able to make more power but not spend as much as a full sti longblock.
Masta Splint is offline   Reply With Quote
Old 07-03-2013, 05:04 PM   #9
Fierysun
Member#: 82745
2005 Subaru STI
If you ever plan on reselling the car, it'll be an easier sale without the jdm or hybrid motor setup.
Old 07-03-2013, 09:36 PM   #10
05stage2
Member#: 307545
2005 wrx
2.1 stroker on e85
And my 5-speed cant handle a hybrid setup. Im currently running a blouch 16gxt, DW 650's, walbro fuel pump, grimmspeed EBCS, spt air intake, sti intercooler, catless uppipe, invidia catted downpipe, and blitz nur spec catback. Tuned at 20-21 psi
Old 07-06-2013, 03:32 PM   #11
05stage2
Member#: 307545
2005 wrx
2.1 stroker on e85
Any other suggestions?
Old 07-11-2013, 12:06 AM   #12
igoiks
Member#: 326692
2004 sti
wrb
JDM engines are crap i had one it spun a bearing within 2,000miles. no one knows what the mileage is.
igoiks is offline   Reply With Quote
Old 07-11-2013, 12:48 AM   #13
projectQWKSLVR
Member#: 285270
03 WRX
I agree with the mileage being possibly fudged, but to say JDM engines are crap? Dude really? lol lol lol
Now, would I buy a 8 to 10 year old engine that's been sitting in a warehouse or worse for god knows how long? Oh hell no!
When my 205 poops, I will build a hybrid from a new 257 block. They are dirt cheap! If done right, you get WAY more torque down low, and it will be just as reliable as any stock(ish) setup. It's all in the math kids! Don't be fooled by the idiots that try to cut corners on the hybrid engines. :-)
projectQWKSLVR is offline   Reply With Quote
Old 07-11-2013, 08:47 AM   #14
Dr. octagon
Member#: 171127
2015 Subaru
Says who....is that what you think or what you have been told on nasioc?
I question anyones sanity or reality when they purchase a used jdm engine slap it in and expect it to run.......especially when they dont tear it down first for inspection. You did not know the aproximate milage when you bought it.
Dude in the vendor for sale did that exactly what is mentioned above.........he is out over 3g's. Joint looked all pretty and **** on the outside.............but had rust all over the inside of the heads. Yea, he failed to inspect his **** too.
What is the facination with JDM EJ205
What is the kick lately with newbs wanting a JDM EJ205, not a 207 but a 205.
Why do people not figure out WHY THEY SPUN A BEARING BEFORE MOVING ON TO ANOTHER MOTOR TO BLOW UP.
Are the motors the same:rolleyes
Old 07-11-2013, 09:26 AM   #15
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
I know the usdm is the 205 and the jdm motor is the 207......but what car in japan did the "ej205" come in?
shamrock 05 is offline   Reply With Quote
Old 07-11-2013, 10:11 AM   #16
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
A Jdm ej205 sells for less than half the going price of an ej207 and that is a huge factor. Many will want a little taste of that Jdm goodness at a price they can afford. Problem is that once they get the motors they are slapping them on without properly inspecting them. Then come the complications not having a proper ecu, no idea what to do about avcs, etc.
I purchased an ej207 and have 10,000 miles on it since the swap a little less than a year ago. Obviously Jdm engines aren't all crap but one must know what we are getting into before going forward
D-Rodman is offline   Reply With Quote
Old 07-11-2013, 05:23 PM   #17
05stage2
Member#: 307545
2005 wrx
2.1 stroker on e85
I just want a reliable motor that can handle my current mods. I am on a budget of about $2300. I found a brand new short block for $1650 shipped to my door. I believe the reason for the spun rod bearing was the stock oil pan. I decided to be stupid and do flat spins in the car, which im guessing made the oil go sideways in the pan and starve for oil. It didn't start knocking until after that, but my guess is that's what was the cause. I learned from my mistake and really just want the car to be a quick yet reliable car.
Old 07-11-2013, 05:26 PM   #18
05stage2
Member#: 307545
2005 wrx
2.1 stroker on e85
I have seen this discussed so many times on here.
Old 07-11-2013, 09:04 PM   #19
Dr. octagon
Member#: 171127
2015 Subaru
Dont make it true, as most cases those who blow up their 5mt do so before they even touch more displacement.
Bad driving, but good on ya for the research.
my 5mt has seen stock turbo, 18g, fp green and now 6266. It depends on how you drive.
Old 07-11-2013, 10:44 PM   #20
05stage2
Member#: 307545
2005 wrx
2.1 stroker on e85
Do you think I should be fine with stock internals if I get a new short block?
Old 07-11-2013, 11:21 PM   #21
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
Should yes, will idk.
Old 07-12-2013, 01:44 AM   #22
D-Rodman
Member#: 110078
05 saabaru artc gr
You should be fine up to 300 whp on stock internals on an ej205 and so should be the 5 speed trans. No clutch drops, never ever and shift like its made out of glass. I've been running my stock 5 speed with my stage 2 ej207. At a little over300 wheel torque it's been reliable, I'm civilized to it.
Is that a 205 short block you can get a deal on ?
Old 07-12-2013, 08:32 AM   #23
05stage2
Member#: 307545
2005 wrx
2.1 stroker on e85
Yes, new 205 short block.
Old 07-12-2013, 08:55 AM   #24
Dr. octagon
Member#: 171127
2015 Subaru
Would the cost not be close if you sourced a used (good condition) 205 or 205 case halves...........grabed some sti rods, forged pistons, 79mm crank, acl bearings, etc......and not just go to 2.1l stroker?
The cost if you do it right should be pretty close to what a new shortblock is, the problem is you must account for the following (which is necessary anyway if a new sb goes in)
a. gaskets (full gasket kit)
b. spark plugs (depending on milage)
c. timing kit (depending on milage)
d. fluids
etc.........that **** adds up quick, along with whatever part breaks upon uninstall (sensors and ****)
If you just want to get back on the road new sb and done.......but you still need to account for the items listed above.
Old 07-12-2013, 09:55 AM   #25
D-Rodman
Member#: 110078
05 saabaru artc gr
d. fluids
Don't forget head work is expensive, you don't slap on your tired cylinder heads on a fresh short block.
