Old 07-13-2013, 10:30 AM   #1
wrxnova1
Member#: 112854
2009 IS-F
2014 Forester XT
Default 2004 sti, protuned, not hitting target boost, defective gs ebcs? Datalogs included
I have a 2004 sti that was protuned a year ago. No issues until recently where the car will not hit target boost. Im thinking my grimmspeed boost controller died. All vacuum lines attached to wastegate and ebcs are in good shape and connected the same as when it was tuned.
Mod list includes :
accessport v2
hta68 8cm
dw 850cc injectors
walbro 255
grimmspeed ext wg uppipe
tial 44 mvr ext wg
gms fmic
gms inlet + maf hose
1 step colder plugs
tgv deletes
cobb catted turboback
cobb sf intake
grimmspeed ebcs
Both datalogs recorded in 3rd gear from 2-6k rpms under WOT
wrxnova1 is offline   Reply With Quote
Old 07-15-2013, 05:52 PM   #2
wrxnova1
Member#: 112854
2009 IS-F
2014 Forester XT
Well its not my EBCS. I called Grimmspeed and they walked me through testing it with a 9v battery. Solenoid clicks so problems gotta be elsewhere.
My external wastegate has a 10 psi spring in it and thats all it will boost.
I've contacted my tuner but any additional help would be appreciated.
Old 07-15-2013, 05:54 PM   #3
tuzzio
Member#: 292532
05 STI
I know you said that your lines are hooked up properly, but just to make sure, I'd replace them. One may have a pin hole and only be boosting waste gate pressure
tuzzio is offline   Reply With Quote
Old 07-15-2013, 08:06 PM   #4
wrxnova1
Member#: 112854
2009 IS-F
2014 Forester XT
Good idea, I'm thinking its a boost leak now. Ill report back once I have it tested.
Old 07-19-2013, 07:08 PM   #5
wrxnova1
Member#: 112854
2009 IS-F
2014 Forester XT
Cars fixed. Turned out that the grimmspeed boost controller was hooked up in a way that overwhelmed the solenoid. I rerouted all the vacuum lines the way that grimmspeed recommends and problem solved. Not sure why my tuner hooked the lines up how they did (nothing on middle vacuum hookup and no connection to turbo inlet hose).
Old 07-19-2013, 07:26 PM   #6
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Since the pressure in the BCS lines is what opens the wastegate, a leak would make him overboost, not underboost.
Old 07-19-2013, 07:26 PM   #7
Member#: 51961
2005 STi
2012 WRX
Good to hear you found the problem.
Old 07-20-2013, 12:32 AM   #8
VinceCarter
Member#: 284694
2006 WRX 6 Speed
277/323 @ EFI Logics
I'd LOVE to see a dyno graph of your set up! I was highly contemplating the HTA68 8 cm.
VinceCarter is offline   Reply With Quote
Old 07-20-2013, 11:58 AM   #9
wrxnova1
Member#: 112854
2009 IS-F
2014 Forester XT
Ill look for my dyno sheet, I made 304 whp / 349 wtq on a dynojet 424. If I were doing it over a different intake and catless dp would have gotten me another 15 or 20 hp apparently.
