Old 07-13-2013, 06:34 PM   #1
xXOli450Xx
Member#: 362238
Default 93-01 subaru impreza, swap sti question
Hi,
ive searched a bit and found nothing useful
I want to buy a 93-01 impreza and swap it sti v4-5 or 6
wich year is better?
is the motor bolt-on?
do i need the sti differential?
is the sti ecu and wiring harness plug and play in the stock impreza body?
xXOli450Xx is offline   Reply With Quote
Old 07-13-2013, 08:32 PM   #2
rudd
Member#: 164612
2003 wrx
purple
Last time I was thinking about the same thing the wiring harness you will have to get married together if I'm not mistaken and you will need the sti diff if your using the sti trans and you will need the ecu also for the sti motor also
rudd is offline   Reply With Quote
Old 07-13-2013, 10:05 PM   #3
khenglim89
Member#: 361085
This swap is somewhat expensive, but I would suggest a USDM swap if you're in California and to make life a little easier . You have to use the correct diff for the transmission, but I've also read/heard you could use the diff and transmission from what you currently have, but you would have to baby it somewhat.
Wiring is somewhat a pain getting it merged.
Head over to RS25.com
They have plenty of info there.
khenglim89 is offline   Reply With Quote
Old 07-14-2013, 12:14 PM   #4
xXOli450Xx
Member#: 362238
thank you,
expensive? i'm from montreal and a V6 sti engine transmission and ecu are 2100$ and 500$ for sti diff wih axle and driveshaft.
