Old 07-14-2013, 06:07 PM   #1
Ctg1986
Member#: 318895
2009 Impreza
Default Aem wideband o2 sensor
I currently have a po0031 code for a bad afr sensor on a 09 wrx. Would replacing it with this product take care of the cel as well ? Or is it just a gauge?
Ctg1986 is offline   Reply With Quote
Old 07-14-2013, 06:17 PM   #2
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
You need to replace it with a stock sensor.
Old 07-16-2013, 12:48 PM   #3
naCAnItihS
Member#: 259481
2002 WRX STI Wagon
MBP
You NEED the stock O2 sensors. You cannot replace them with anything but OEM replacement parts. The AEM can be added on (welding another bung in the DP) but it runs as its own stand alone unit (just a gauge in your terms).
naCAnItihS is offline   Reply With Quote
Old 07-16-2013, 06:26 PM   #4
Ctg1986
Member#: 318895
2009 Impreza
Ok thanks thats what I was getting at.. It is after all just a gauge. Would having a bad AFR sensor cause what feels like a loss of power / hesitation mostly noticeable at higher rpm (above 4500 per say) ?
Old 07-16-2013, 07:54 PM   #5
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Yeah.. and do it long enough with a bad front 02 and you can kiss your engine good bye.
scby rex is offline   Reply With Quote
