Old 07-15-2013, 09:26 PM   #1
CamaroSS
Member#: 30626
2015 BRZ Limited
1999 Miata Track Car
Default 2012 WRX CEL, AP wont pull code?
CEL light came on today. I borrowed an access port to check the code and it said there were no codes? So... now what? Car has no mods and seems to drive normally. I have noticed a rough idle a few times in the last couple of months, but it has been sporadic and always goes away. I will be taking it to the dealer, but thought I would get some board feedback as well.
Thanks
CamaroSS is offline   Reply With Quote
Old 07-15-2013, 09:38 PM   #2
diablo0730
Member#: 362438
The AP is married to an ECU which since it was borrowed it may not work on yours because its married to the owners ECU. Or it may not be updated also if it was uninstalled properly.
diablo0730 is offline   Reply With Quote
Old 07-15-2013, 10:18 PM   #3
CamaroSS
Member#: 30626
2015 BRZ Limited
It was an unmarried AP if that makes a difference.
Old 07-15-2013, 10:18 PM   #4
CamaroSS
Member#: 30626
2015 BRZ Limited
Or unmarried at the time.
Old 07-15-2013, 10:21 PM   #5
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
Aps read codes from any. I just used my married 2012 to read code from an 02 wagon. Reads codes, logs, ect, just cant flash when married.
Cathexis is online now   Reply With Quote
Old 07-16-2013, 09:27 AM   #6
CamaroSS
Member#: 30626
2015 BRZ Limited
Dealer said it is a bad MAP sensor. New one is on the way. The first 2012 that they have had to replace.
Old 07-23-2013, 04:25 PM   #7
CamaroSS
Member#: 30626
2015 BRZ Limited
Sensor was replaced. CEL was back within 20 miles. Dealer is now stumped. Thoughts? After the service I noticed some stumble/misfire at idle and while cruising at 40 mph. Stayed out of boost as best I could on the way back to dealer.
Old 07-23-2013, 05:19 PM   #8
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
sub'd for results. gotta love how the dealer cant fix the problem
BigRob74 is offline   Reply With Quote
Old 07-23-2013, 05:38 PM   #9
CamaroSS
Member#: 30626
2015 BRZ Limited
Im not mad at the dealer. Regional tech is going to look at it tomorrow, hopefully he can diagnose it. I just want my car back
Old 07-25-2013, 04:11 PM   #10
CamaroSS
Member#: 30626
2015 BRZ Limited
Dealer called this afternoon. They think they have identified the problem. It is not the MAP sensor itself, but they harness that connects to the MAP sensor. Somehow, there is a kink in the ground wire for the sensor. They think this is causing the sensor to malfunction. They have ordered a new part, which I assume is a new harness. Probably won't get the car back till Monday, but perhaps tomorrow...
