Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 10-01-2002, 01:54 PM   #1
blindclown
Member#: 18955
2005 Impreza WRX STi
Question Looking for some Suggestions for a Boost Controller?
I'm thinkin about getting a boost controller, and I was looking for some good ideas and suggesions.
What Boost controller are you using, and what might be the advantages, and disadvantages of one vs the other. I have an idea of what the advantages\disadvantages may be, but I was looking for some other input.
Also where can I look?
What boost do you run at..etc?
blindclown is offline   Reply With Quote
Old 10-01-2002, 02:03 PM   #2
Thug
Choke Artist
Member#: 603
For overall value, you cant beat the Hallman Manual Boost Controller. Unless you build your own, which will run you about $4 in parts at Home Depot.
If you're thinking about getting an electronic one, all I can say is: Do your homework, about the product as well as the vendor.
Thug is offline   Reply With Quote
Old 10-01-2002, 02:06 PM   #3
jamz
Member#: 8725
2013 Black Company
Annalist
Well, on the cheap side, you can build you own ball-and-spring type controller for about four bucks. On the more expensive side, you can use the Blitz SBC-ID, which is what I have. It's nice, uses twin solenoids for pretty steady boost, and you can adjust it in the cockpit, which was the main attractor for me.
This way, I can use my default setting (13 PSI) for evreyday driving, and turn the boost down under certain conditions (extended highway driving, or when the weather is really hot) to 8 or 10, or I can bump it right up to "emergency war power", or about 15.5 PSI, just by hitting a few buttons. I like it, and it adds a small amount of bling to my otherwise dull cabin.
jamz is offline   Reply With Quote
Old 10-01-2002, 02:10 PM   #4
Thug
Choke Artist
Member#: 603
I thought that was what the duct tape was for?
Old 10-01-2002, 02:39 PM   #5
Davenow
Member#: 23676
Default MBC=best bang for your buck
Halman is the cheapest, and can be built by you for about 4 bucks, OR bought on ebay for 9.95 BUT as it is a ball and spring type boost controler, it will be subject to problems with partial throttle high boost, which is a BAD thing and can lead to engine damage.
There are manual boost controllers that can handle this MUCH better, they are of the ball and springAND bleed type. The TurboXS High Performance Manual Boost OCntroller(HPMBC) is what I use. I got mine for 106.50 shipped from ebay(www.rx4speed.com <<free plug for a nice guy)
Took me all of 5 min to install and AWESOME improvement over stock. Plan about 15min in an empty lot or road to set it up for correct boost pressure. It will still get PTHB but not nearly as bad or as easily, and you can just back off for a sec and it goes away.
Even cheaper than ANY of those is the ever popular and VERY potent 3/16 mod, do a search on how and what to replace for this one, lets just say for less than a can of coke you get 3psi more in 1-2 gear and almost 1 psi more in 3-4-5.
ALSO VERY IMPORTANT
BEFORE
you go screwing with boost pressure, you need to have a boost gauge. I got mine from ebay 55.50 shipped, Autometer 4317 then picked up a mounting cup at a local speed shop for 12 bucks and a couple brass fittings/wire loom to cover the line at a pep boys for about 10 bucks. Install took me about 35 min, but I know my way around a car pretty well, AND did a lot of research on where everything was going to be run and hook up.
First thing you should do is go do the 3/16 mod while you think about which way you wanna go. You dont need a boost gauge for the 3/16 mod since the factory boost controller will keep things in check. Personnaly I cant recommend halman type MBC's because of the PTHB thing, BUT VISHNU includes one in the stage 0 kit so how bad can it be? For the gains that you will get, and not have to worry nearly as much about PTHB, I would say that 106 bucks in NOT a bad investment with that Turboxs hpmbc.
just remember the gauge!!!!!
Old 10-01-2002, 09:25 PM   #6
CastleBravo
Member#: 24322
Be careful with the TurboXS HPMBC. I installed mine and removed it three days later due to wild engine hesitation at partial throttle in 3rd and 4th gear. There are some threads about this, just do a search.
For piece of mind, save your money and get the Blitz SBC-iD or the equivalent Apexi model which, I think, also allows you to program boost at different throttle and RPM. You can control the boost from the cabin and not worry about high EGTs when cruising on the highway.
-Brian
CastleBravo is offline   Reply With Quote
Old 10-01-2002, 09:55 PM   #7
Rattles
Member#: 16486
2006 Jeep
profec b all the way. i had the greddy profec b in my old subaru and it is the best ebc out there. no other ebc can match it. i can also get you a good price if you want one so let me know
Rattles is offline   Reply With Quote
Old 10-02-2002, 08:33 AM   #8
Davenow
Member#: 23676
Default .
I never have any hesitation problems with my HPMBC. Weird. I guess Im lucky? Yeah man if you can afford an electronic boost controller, DO IT, if not than an MBC is the way to go.
Old 10-02-2002, 09:32 AM   #9
02WRX03060
Member#: 19897
No one else has mentioned it yet so I guess I will.
I use a boostvalve MBC with the dawes device.
Any ball and spring type MBC will work, even the homemade one, but I heard there were some problems with the Joe P (maybe fixed by now).
The dawes device is used to connect both the FBC and the MBC to a switch. With the switch off I am using the FBC, with the switch on I am using the MBC. It's just like the Blitz SBC-ID or TurboXS dual stage controller, but cheaper.
I like this because if anything goes wrong with the MBC I can turn the FBC back on and make it home.
Run a search, there is tons of info on it.
02WRX03060 is offline   Reply With Quote
Old 10-02-2002, 10:10 AM   #10
blindclown
Member#: 18955
Thanks guys, I guess I will do some research on the matter a bit more than what I thought I was going to. Thanks for your help.
Looking for some suggestions on what to do VBwrex13 Newbies & FAQs 0 06-04-2009 02:58 PM
Looking for some suggestions surfer5567 Proven Power Bragging 21 12-30-2008 05:25 PM
Money To Spend...looking for some suggestions abqkid Newbies & FAQs 27 04-19-2004 02:44 PM
Money To Spend...looking for some suggestions abqkid Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-12-2004 01:10 AM
Looking for some suggestions for a system hockeyguyRS Car Audio, Video & Security 22 03-02-2000 12:52 AM
