Old 07-18-2013, 08:42 PM   #1
trentsize
Member#: 355537
2005 Impreza WRX
Red
Default Oil leaking around and above filter
What would be causing this oil leak above the filter?
05 WRX, no mods.
trentsize is offline   Reply With Quote
Old 07-18-2013, 10:39 PM   #2
pebelz
Member#: 268632
2015 XV
oil-cooler gasket
pebelz is online now   Reply With Quote
Old 07-18-2013, 11:01 PM   #3
trentsize
Member#: 355537
2005 Impreza WRX
Red
Easy fix on the next oil change?
Old 07-19-2013, 07:11 AM   #4
02nismokiller
Member#: 322963
04 wrx
psm
It's not a hard fix but it's not the easiest lol maybe an hour to do
02nismokiller is offline   Reply With Quote
Old 07-19-2013, 02:04 PM   #5
Member#: 301037
2004 Forester XT
It is a large nut though. I am thinking it is a 24mm
art@grimmspeed is offline   Reply With Quote
Old 07-22-2013, 01:18 PM   #6
jonno
Member#: 283263
Yes, 24mm and you need a deep-socket to get it.
It's not a difficult job. Make sure you get the new one seated correctly before you tighten it down.
jonno is offline   Reply With Quote
Old 07-22-2013, 03:18 PM   #7
oaklandish_WRX
Member#: 267339
2002 0[[XXXXoXXXX]]0
MBP LongRoof
And not have large hands...
you can loosen a bolt on the coolant hardline at the front of the block to make the rotation easier.
oaklandish_WRX is offline   Reply With Quote
Old 07-22-2013, 03:34 PM   #8
trentsize
Member#: 355537
2005 Impreza WRX
Red
I assume the coolant should be drained before removing the two coolant lines?
Old 07-22-2013, 03:56 PM   #9
oaklandish_WRX
Member#: 267339
MBP LongRoof
I'm told that it won't drain out that fast if the rest of the system is still sealed, so others claim they have jammed either spark plugs or sharpie pens in each hose as they remove them, then drop the oil cooler assembly as a whole. You'll still have some left dribbling out of the cooler, etc.
given our cars age, I have stockpiled the hoses and clamps for a total re-do when I replace my O/C gasket; will do a nearly full drain and put-back. I can get you the ID of the hoses so you can plan ahead with some sort of plug - PM me if ya want.
bugeyes FTW
Old 09-01-2013, 06:32 PM   #10
jmgladden
Member#: 268403
Anyone know the part number, or where you purchased this gasket? Mine is dripping like crazy, would like to get it fixed asap.
jmgladden is offline   Reply With Quote
Old 09-01-2013, 08:51 PM   #11
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Purchase at a dealer.
Old 09-01-2013, 11:48 PM   #12
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
You can do this job without removing the coolant lines.
Old 09-24-2013, 04:44 PM   #13
TBone7281
Member#: 148501
2004 WRX
blue
Gah, this is EXACTLY my problem... been getting progressively worse over the last year or so. Unfortunately, I just changed my oil 2 weeks ago... went through a total of 8.75 extra quarts of T6 in 7,650 miles. The local stealership has been telling me on and off a year or two that my "oil filter isn't on right and is leaking" even though I've been telling them that isn't the problem.
What do you need to do to replace the gasket? Obviously it's between the oil cooler and block... just held on by one big bolt?
TBone7281 is offline   Reply With Quote
Old 09-24-2013, 07:30 PM   #14
oaklandish_WRX
Member#: 267339
MBP LongRoof
~14 quarts in 7650 miles . You sure it's only leaking at the cooler?
There are some write-ups around here...
Short answer: get a new gasket from SOA for a few bucks, drain oil, remove filter, get a 24mm(?) deep socket and remove the oil tube the filter screws onto, flip the oil cooler over* and remove old gasket, install new one, flip cooler back and re-install oil tube, torque to ~40lbft, replace filter. Rock it.
* May have to loosen a coolant hard-line mount to allow enough rotation AND have hands like a 10 YO.
<----------does not have hands like a 10 YO.
Old 09-24-2013, 07:48 PM   #15
TBone7281
Member#: 148501
2004 WRX
blue
No, but after years of searching the forums/troubleshooting I've given up looking for other "culprits". With this recent leakage though it has become downright ridiculous.
Perhaps after I take care of this I'll try to figure it out again. I've had my oil tested by Blackstone who haven't found anything abnormal. Last year I swapped out the turbo, thinking the seals might be bad. I've had it to the dealership to try and see if any of the engine seals/head gaskets/etc. were leaking. No dice on all of that.
Before I noticed the leaking at the oil cooler I was averaging around a quart probably every 1000 miles, which according to various NASIOC threads, is considered "normal". I find that to be ludicrous. My wife's 2006 Saab 9-3 Aero (2.8L V6 turbo) doesn't lose a drop of oil between changes and I've never experienced anything like this prior to me owning this car either.
**Edit - And thanks for the reply. That's about what I figured but wanted to be relatively sure before I started on it.
Old 09-25-2013, 05:38 AM   #16
pebelz
Member#: 268632
2015 XV
Make sure that new gasket is seated. It will pop out easy.
Old 09-30-2013, 02:41 PM   #17
Kevisking
Member#: 369388
03 wrx
Easy fix took me 30 min good luck
Kevisking is offline   Reply With Quote
Old 09-30-2013, 09:19 PM   #18
Zane
Member#: 292786
2003 WRX
Sonic Yellow
You have to have a seal leaking somewhere. One of the cam seals or the main seal not seated 100% properly. No way you're burning a quart every 1000 miles.
Zane is offline   Reply With Quote
Old 10-01-2013, 03:18 PM   #19
TBone7281
Member#: 148501
2004 WRX
blue
I read a number of people saying you could do this without unhooking the coolant lines. I also read where some people said you had to take off the exhaust pipe that is down there. I tried to figure out a way to do it without removing any of that for maybe 2 hours or so and eventually just decided that while it may have worked for some people, there was no way I could swap gaskets without doing something other than taking out the big 24mm bolt. I ended up only disconnecting one of the two coolant hoses. (The one that goes from the oil cooler directly to the block, not the intermediary metal piping.) Then I could flip the oil cooler over enough to work on it. Plugged the rubber line with a sharpie marker and used the finger of a rubber glove/rubber band to seal the exposed end of the oil cooler.
I've always kind of assumed so, but the dealership has said they don't see anything wrong more than once. (Though I haven't been back recently.) Inspection is due next month so we'll see if they bring anything up then. It has gone through oil for as long as I've had it though, or pretty close to it anyway... bought in 2006 and it still had some of the warranty left so it was under 36,000 miles. I'm at 157k or so now.
