Old 12-22-2013, 01:17 PM   #1
GarbageDay
Member#: 371213
2013 Imp Spt Lmtd
Ice Silver Metallic
Default Foglights went out
My fog lights won't turn on for me and the fog light illumination on the dash board does not turn on either. I have a 2013 Subaru Impreza Sport Limited Hatchback and I've only got about 1,700 miles on it. I was 2 hours into a road trip when I pulled over to get gas. Had my headlights and fog lights on. When I pulled out after getting gas, the fog lights went out and did not turn back on. Has this happened any one else? Is it possible there was a short in the circuit or I need to replace the fuse?
GarbageDay is offline   Reply With Quote
Old 12-22-2013, 02:43 PM   #2
G2Spfld
Member#: 354284
2013 Imp Sport CVT
I bet its a fuse.
G2Spfld is offline   Reply With Quote
Old 12-23-2013, 02:48 AM   #3
xtasi
Member#: 376709
2012 Impreza
Check your fuses. Underneath the dash on driver + hood
xtasi is offline   Reply With Quote
Old 12-23-2013, 03:01 AM   #4
GarbageDay
Member#: 371213
2013 Imp Spt Lmtd
Ice Silver Metallic
Thanks for the replies guys! How would I know if there was a fuse issue? If there was an issue, do I just replace it? Also it may have just been overheating? The car sat for about 10 hours while I was at work and when I came out afterwards, the fog lights were working again, as well as the dash board fog light illumination light.
Old 12-23-2013, 06:48 AM   #5
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Well, if the fogs working again, then it's not a fuse issue.
Old 12-23-2013, 09:10 AM   #6
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
Were your lights on High Beam If so the fogs are disabled.
G-Omaha is offline   Reply With Quote
Old 12-23-2013, 11:12 AM   #7
GarbageDay
Member#: 371213
2013 Imp Spt Lmtd
Ice Silver Metallic
Yeah I think the lights may have overheated? The high beams were not on. In the situation though if there was a fuse issue, how would I know a fuse blew? I'm a noob at this!
Old 12-23-2013, 11:18 AM   #8
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
Pull the fuse out and look at it. There is a metal strip inside that connects the two ends. If too much current runs through the strip, it breaks. This prevents your electronics on the circuit with the fuse from blowing up.
foghelmut is offline   Reply With Quote
Old 12-23-2013, 12:53 PM   #9
Zeeper
Member#: 299286
2015 WRX CVT
a bad fuse can look like a good fuse, so the best way to test if it is the fuse is to swap with a new one. Sometimes a bad fuse if obvious, but I learned a long time ago that one may look good, and not be... sometimes the contacts break/not burn and visually checking it misses the failure.
Old 12-23-2013, 01:14 PM   #10
GarbageDay
Member#: 371213
2013 Imp Spt Lmtd
Ice Silver Metallic
Got it, thanks for the help everyone!
Old 12-23-2013, 04:28 PM   #11
fistv
Member#: 350063
2013 Impreza sport
Fuses are not self repairing nor are they circuit breakers that will reset. At 1700 miles I'd report it to the dealer to get it on record.
fistv is offline   Reply With Quote
Old 12-23-2013, 05:58 PM   #12
G2Spfld
Member#: 354284
2013 Imp Sport CVT
Yip- I've seen fuses even test ok, but after long run they act like a blown fuse. Not sure if it was a defect in fuse or not, but heat does crazy things. Could be a fluke ground issue as well. Electronics can do weird things sometimes.
Old 12-23-2013, 06:20 PM   #13
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Also, any cheap ohmmeter would confirm that a fuse is good or bad.
Old 12-24-2013, 01:35 AM   #14
GarbageDay
Member#: 371213
2013 Imp Spt Lmtd
Ice Silver Metallic
When I left for work today, the fog lights were out again, same with the illumination on the dashboard. When I left work about 9 hours later, they came back on, same with the illumination. I don't get it!
Old 12-24-2013, 06:37 AM   #15
Tha Chakal
Member#: 372100
2013 Premium 5dr CVT
Definitely take it to the dealership.
Tha Chakal is offline   Reply With Quote
Old 12-24-2013, 11:44 AM   #16
Zeeper
Member#: 299286
2015 WRX CVT
probably a loose connection in the wiring harness, I would bring it to the dealer also
Old 12-25-2013, 01:28 AM   #17
GarbageDay
Member#: 371213
2013 Imp Spt Lmtd
Ice Silver Metallic
I feel really stupid but didn't know this.
The reason my fog lights wouldn't turn on was because I always leave my headlights set to auto. Because the amount of daylight was enough to not have the headlights on except for the daytime running lights, the fog lights won't turn on. The fog lights only seem to turn on if my headlights are on.
This is why the fog lights work when I leave work. It's night time when I get off. There's enough day light when I go to work so the fog lights don't turn on. Sigh. The reason why my fog lights went out during the trip was because there was enough daylight for my lights to go to day time running.
Well, at least it isn't an issue. I'm so relieved! Thanks everyone!
Old 12-25-2013, 06:16 AM   #18
Zeeper
Member#: 299286
2015 WRX CVT
wow, glad you figured that out, I don't have the auto headlight feature, so I never would have thought of that...
Old 12-25-2013, 07:32 AM   #19
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Same here. I knew where the OP was going as soon as he mentioned having his headlights in AUTO because my wife's Toyota Highlander works like that. But my Impreza doesn't have AUTO headlights, so it never occurred to me in this context.
Old 12-25-2013, 08:41 AM   #20
Tha Chakal
Member#: 372100
Case closed, Collective NASIOC SMH...
Merry Christmas everybody!!
Old 12-25-2013, 08:57 AM   #21
G2Spfld
Member#: 354284
2013 Imp Sport CVT
Merry Christmas guys and gals!!
