Old 07-19-2013, 11:30 PM   #1
tims5377
Member#: 355739
2013 WRX
CBS
Default Powdercoat durability
Sooooooo I want everything to be black. Windows, lights, tails, chrome, wheels. Black.
I want to have winter wheels and summer wheels. I was planning on buying black summer wheels (probably 18 x 9.5) sometime next summer. For the winter I was thinking of using the stock wheels and powdercoating them black. Is this a good plan if I am going to be using them in the winter? I have never powercoated anything so I have no idea how it holds up. I live in Upstate NY so in the winter we have a ton of slushy salty goo that gets all over the car and wheels. Will the salt destroy it?
tims5377 is offline   Reply With Quote
Old 07-19-2013, 11:41 PM   #2
slayer44wagon
Member#: 300834
03 wrx wagon
Should be good but the rest of your car... Yea that will rust
slayer44wagon is offline   Reply With Quote
Old 07-22-2013, 12:18 AM   #3
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Forged rims don't hold up to the high heat very well. Sometimes you can do single stage powder coating but if you have a 2 stage like a candy powder coating. Then they likely will crack.
Rims that are not forged don't have the same problem but if over heated cracking can still happen.
Powder coating can also be done DIY. I have done several parts now. Like 05 sti axles that had far amount of rust on the inner cv. I did them and it turned out good.
Old 07-24-2013, 01:04 AM   #4
tuner92
Member#: 235750
2008 sti
I've had two sets of rims powder coated and they have held up great threw the winter months and summers. I've had no chipping or peeling of any kind and have had no problems with salt sitting on them.
tuner92 is offline   Reply With Quote
Old 07-24-2013, 01:39 AM   #5
amagana
Member#: 320578
2003 WRX
PSM Stage 2
Plasti dip! $5 for a can and you can redo it every year. Idk how much it would cost to plasti dip in your area but definitely a cheaper option.
Or go with steelies
amagana is offline   Reply With Quote
Old 07-24-2013, 01:21 PM   #6
timerbob
Member#: 353528
If you're planning on getting them powdercoated, make sure you go to a reputable shop that knows what they're doing. Like some have said above, overheating will weaken the wheel.
timerbob is offline   Reply With Quote
Old 07-24-2013, 02:20 PM   #7
stisubaru07
Member#: 363132
2007 Impreza STI
I bought an STI with black wheels, and they have chipped pretty badly. How can I tell if they are stock black or powdercoated?
http://postimg.org/image/coyaltzpl/
stisubaru07 is offline   Reply With Quote
Old 07-24-2013, 02:21 PM   #8
stisubaru07
Member#: 363132
2007 Impreza STI
Old 07-24-2013, 02:35 PM   #9
sc00by4life
Member#: 97135
well first thing is that stock wheels aren't black.
judging by the fading and scratching, most definitely rattle canned.
Old 07-24-2013, 02:56 PM   #10
2.5L Monster
Member#: 307177
2k4 WRX/WRB
Shuckin' & Drivin'
+1 for plasti-dipping winter wheels
2.5L Monster is offline   Reply With Quote
Old 07-26-2013, 03:32 PM   #11
tims5377
Member#: 355739
2013 WRX
CBS
Alrighty, that settles that! Different dip colored wheels for every winter!
Im gonna get it under sprayed with anti rust oil goo disgusting stuff that I really dont want on my car at all! But if it gives me more years before it gets rusty then it was worth iit.
Thanks all!
Old 03-28-2014, 08:23 AM   #12
AvaNick1
Member#: 375646
2011 Subaru WRX
I've heard about issues with the salt/ice melting mix they put on the roads now in New England as well. If they spray a layer of clear coat on the wheels after powder coating, would that stop the corrosion?
AvaNick1 is offline   Reply With Quote
Old 03-28-2014, 09:37 AM   #13
dingobite
Member#: 82391
08 OBP Sti
td06SL2, 20g 299hp 300tq
You should always get a clear unless your doing a flat no shine color theres even a clear coat that make the paint look like a flat color. A 40%-60% clear should help with any salts just have to watch out for what cleaners you use to clean the wheels that can degrade the clear on the wheels.
dingobite is offline   Reply With Quote
Old 03-28-2014, 01:50 PM   #14
pDubs
Member#: 149317
'95 BMW M3 (E36)
'05 Kawi ZX6R, '73 CB350F
^Not true. There are powders, especially Powderbuythepound's "Super Durable" colors that are a high gloss without clearcoat and extremely durable.
https://www.powderbuythepound.com/Super-Durable-Colors/
I've powdered with several of these colors and they're great.
He is talking about powder coat, not paint.
pDubs is offline   Reply With Quote
Old 03-29-2014, 01:20 PM   #15
dingobite
Member#: 82391
08 OBP Sti
I guess your right ive done some reading just not enough to start powder coating for myself.
Some of those colors still come with no UV protection where the powder would just fade over time, this i was probably thinking of since those powders still need a gloss, which some people still dont care about.
Old 03-29-2014, 02:58 PM   #16
Web Foot STi
Member#: 39086
2004 STi
Just for the record wheels that are heat treated don't do well with a long powder coat cure. The factory aging temperature is in the same range. Artificially aging hardens the aluminum and gives it strength. Over aging make aluminum stronger, but brittle. You want to just flash the powder coat to cure and not get the whole wheel up to temp. Think of it like a steak. Seared on the outside and rare/raw in the inside vs well done with a nice brown color all the way through.
Think of it this way. In a rally would you rather bend a wheel had have it hold air until the end of the stage, or crack/break it and be doa? Heat treating is an art and a science.
Web Foot STi is offline   Reply With Quote
