Old 07-19-2013, 11:44 PM   #1
jacob.elder22
Member#: 353830
06 Impreza STI
Default I want my car flush
I recently saw a real clean looking black STI in Tuner Sport and saw that the wheels and tires make it look flush, or maybe a hair bigger on the offset. I have an 06 STI and I was wondering which set of 57D Gram Light Volks I need to buy to make it look like this....so basically the wheels come out to be flush with the outside of the fender.....does someone know what i am talking about? And if so, can someone help me get in the right direction?
jacob.elder22 is offline   Reply With Quote
Old 07-20-2013, 11:09 AM   #2
JonnyV2889
Member#: 197384
2006 WRX Ltd
JonnyV2889 is offline   Reply With Quote
Old 07-20-2013, 01:49 PM   #3
sc00by4life
Member#: 97135
if you are this clueless, you have absolutely no business attempting aggressive fitments. it isn't for you. its one of those things, that if you want that look, and know how to get that look - do it. if you don't, it is VERY easy to cause irreversible PERMANENT damage to your car.
if you can't figure out how to make a certain fitment work by searching through the stickies at the top, you have absolutely no business attempting aggressive fitments. it isn't for you.
move on.
Old 07-27-2013, 09:56 AM   #4
garn
Member#: 56939
Almost flush isn't hard.. As long as you don't get into fender rolling, large amounts of neg camber, tire stretching, etc..
Just look at some of the large threads with people's fitments to see what seems to usually fit without the above mess.. Different tires of the same size still vary so that can also make a difference..
garn is offline   Reply With Quote
Old 07-27-2013, 01:44 PM   #5
Mr. Lin
Member#: 344988
2013 WRX STi
ISM
wide wheels, low offset (for scoobies), stretched tires and camber is how u get that look. the numbers are up to u to figure out
Mr. Lin is offline   Reply With Quote
