Old 07-25-2013, 02:11 AM   #1
bugeyesubie117
Member#: 293656
Default new tmic...now overboosting bad!?
I just installed a sti tmic on my 03 wrx. Took it for a drive and noticed my boost gauge was reading way high. Looked at my AP and it read 21.9psi. I stopped immediately and drove home staying out of boost. I have a catless up pipe, catless dp, invidia catback and spt intake with a cobb AP ots stage 2 map. Why am I overboosting now after I installed the tmic? What can be done? It was running with no overboost or issues for over 2 months with all the mods except the sti tmic. (Normal boost peaks at 16.8psi) Thanks for the help!
bugeyesubie117 is offline   Reply With Quote
Old 07-25-2013, 02:17 AM   #2
pronghornamerica
Member#: 231666
Is that TMIC clean inside? Spiders and **** moves in when it's been sitting in a garage for 3 years. Perhaps channels are clogged with dirty oil? Dawn soap and pressure washer that thing. Gotta start simple, right?
pronghornamerica is offline   Reply With Quote
Old 07-25-2013, 02:23 AM   #3
WRX_Airman09
Member#: 283814
2009 WRX Premium
Silver Bullett
I'd get a Cobb boost controller (electronic). You prob have a way different flow pattern now that's why you should always tune for a intercooler regardless of tmic or fmic. Stage 2 ap tune is decent but u have a few more mods then exhaust and intake which is what the stage 2 is. just my opinion from experience.
WRX_Airman09 is offline   Reply With Quote
Old 07-25-2013, 03:39 AM   #4
bugeyesubie117
Member#: 293656
The tmic was right off someones STi so it is not dirty. Also if i install a EBCS, a protune is needed, but it would manage boost great. I read on the forums that a STi tmic has no need for a protune if installed...but I may be incorrect.
Old 07-25-2013, 07:42 AM   #5
wrxlaunch
Member#: 181298
Have you tried lwg map?
wrxlaunch is offline   Reply With Quote
Old 07-25-2013, 03:10 PM   #6
bugeyesubie117
Member#: 293656
I don't think my AP has that map, I bought it used. But why all of a sudden I am overboosting? Puzzles me.
Old 07-25-2013, 05:21 PM   #7
Artizle
Member#: 251825
2004 WRX
You can download the map from Cobbs website
Artizle is offline   Reply With Quote
Old 07-25-2013, 05:21 PM   #8
pronghornamerica
Member#: 231666
How is your wastegate controlled? What kind of turbo? Stock TD04?
Old 07-25-2013, 05:22 PM   #9
RockRex
Member#: 261082
I'd recheck all your hoses you loosened/removed to install I/C. Also look around to see if you pulled off any other hoses during install.
RockRex is offline   Reply With Quote
Old 07-25-2013, 05:37 PM   #10
boosted25
Member#: 316107
2002 Wrx sportwagon
Rally blue
Buddy you knocked the hose off the compressor housing that connects to the waste gate and bcs
boosted25 is offline   Reply With Quote
Old 07-25-2013, 06:22 PM   #11
nickch
Member#: 91509
2001 JDM WRX V7
WR Blue Mica
^^^ That is exactly happened to me.
I upgraded my stock WRX intercooler to an STI one.
The added width caused a bit of rubbing with the wastegate hose, which eventually ruptured the hose.
Check that hose and replace it!
nickch is offline   Reply With Quote
Old 07-25-2013, 06:38 PM   #12
pronghornamerica
Member#: 231666
My next call was wastegate hose. Clogged, torn, ruptured, disconnected, damaged.
Old 07-25-2013, 08:24 PM   #13
bugeyesubie117
Member#: 293656
Exactly what happened except it tore in half. Thanks everyone for all the help!
Old 07-27-2013, 07:37 PM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
if yer not tunnin that thing to run 20psi anyway...yer missin all the td04 fun
there is a LOT to be said for a well running 2.0 with the right breathing mods and a td04 @20-21psi
i could spin the tires from a 5mph roll with my 2.0 by just jabbing the throttle WOT
it WILL need bigger than stock injectors and a fuel pump....but
