Welcome to the North American Subaru Impreza Owners Club Friday March 27, 2015
Old 10-01-2002, 11:47 PM   #1
DiMensionX
Member#: 23517
Lightbulb UTEC & DeltaDash logs HERE from tonight
Ok folks, first time trying to post this type of stuff. Made several runs. Some hard, some easy. I did dual logging with one laptop and two serial ports. I don't think I went over 103 MPH this evening:-).
I'm going to post a basline playing around UTEC Data 4 log (Logging option 4 I believe) to start. This is the UTEC logging option I used for all the runs as it seemed most appropriate. I did find some knock, read through the UTEC logs and you'll see it in 1-3 of the runs.
I DID notice that in a 5th gear pull from 45 MPH that I knocked as the boost built and I also had a strange spike to ~20PSI. Odd but it happend.
Here is the first Baseline run, without the DeltaDash side by side as the others are. This wasn't TOO hard of a run, just playing a little. No knock here and I hit it pretty good.
More to follow with Delta Dash simultanous logging to go with...
Shawn
DiMensionX is offline   Reply With Quote
Old 10-01-2002, 11:54 PM   #2
DiMensionX
Member#: 23517
Code:
DeltaLog-af422-Tue Oct 1 2002 20-55.12
TIME      RPM  MAP MAF  TPS MLP Knock O2 IGN#1  INJ#1 IGN    FUEL BOOST
01587354  3303 100 126  51  00    00 117 +36.2   11.0 ECU.   -5.5 ECU.
01587734  3323 103 128  53  00    00 112 +36.1   11.0 ECU.   -5.5 ECU.
01588134  3384  96 128  53  00    00 116 +36.5   11.0 ECU.   -5.5 ECU.
01588534  3418  95 128  53  00    00 114 +36.5   11.0 ECU.   -5.5 ECU.
01588934  3472 101 128  51  00    00 114 +36.2   11.0 ECU.   -5.5 ECU.
01589334  3516  98 130  54  00    00 113 +36.4   11.0 ECU.   -5.5 ECU.
01589734  3549  95 130  53  00    00 115 +36.5   11.0 ECU.   -5.5 ECU.
01590134  3679 105 153  99  00    00 131 +33.0  146.0 ECU.   -5.5 ECU.
01590534  3757 124 156 129  00    00 112 +29.4   21.0 ECU.   -5.5 ECU.
01590934  3844 134 162 139  20    00 104 +28.9  273.0 ECU.   -5.9 ECU.
01591334  4001 138 171 158  20    00 109 +27.1   26.0 ECU.   -5.9  44.50
01591734  4125 156 181 184  40    00  93 +23.2   33.0 ECU.   -5.9  44.50
01592134  4268 159 179 184  50    00  69 +19.3   40.0 ECU.   -5.4  45.90
01592534  4498 175 186 186  60    00  57 +16.6   46.0 ECU.   -5.6  48.60
01592934  4714 185 193 187  70    00  56 +17.4   52.0 +21.0  -5.6  48.60
01593334  4901 179 195 187  70    00  57 +18.7   57.0 +23.0  -5.3  48.00
01593734  5035 197 200 187  80    00  56 +20.4   60.0 +23.0  -5.3  46.00
01594134  5216 182 200 187  70    00  56 +22.2   63.0 +23.0  -5.2  43.50
01594534  5500 177 204 188  60    00  56 +21.4   67.0 ECU.   -5.1  42.50
01594934  5602 196 205 187  80    00  56 +22.5   70.0 +24.0  -5.1  42.50
01595334  5777 198 209 187  90    00  55 +23.0   74.0 +24.0  -5.1  42.50
01595734  6038 171 211 188  60    00  55 +23.7   76.0 ECU.   -5.1  42.50
01596134  6242 172 212 188  60    00  55 +24.3   80.0 ECU.   -5.1  42.50
01596534  6289 178 211 187  70    00  54 +27.3   82.0 +25.0  -5.1  42.50
01596934  6561 185 212 187  70    00  56 +28.4   85.0 +25.0  -5.0  42.50
01597334  6587 195 214 186  80    00  55 +28.1   85.0 +25.0  -5.0  42.50
01597734  6761 212 215 166 100    00  55 +29.1   85.0 +25.0  -5.0  42.50
01598134  6385  97  81  27  00    00  65 +10.2   14.0 ECU.   -5.5 ECU.
01598534  5984  64 100  26  00    00 174 +10.7   14.0 ECU.   -5.5 ECU.
01598934  4585  90 178 142  10    00 176 +21.1   34.0 ECU.   -5.3 ECU.
01599334  4823 138 183 184  20    00  56 +22.6   47.0 ECU.   -5.3  48.00
01599734  4923 165 196 186  50    00  55 +20.4   61.0 ECU.   -5.3  46.00
01600134  5027 185 199 184  70    00  55 +18.8   66.0 +23.0  -5.3  46.00
01600534  5089 195 203 186  80    00  56 +20.7   67.0 +23.0  -5.3  46.00
01600934  5232 197 201 186  80    00  55 +20.6   68.0 +23.0  -5.3  46.00
01601334  5265 179 204 185  70    00  55 +21.1   69.0 +23.0  -5.2  43.50
01601734  5359 194 203 186  80    00  56 +21.8   71.0 +23.0  -5.2  43.50
01602134  5402 181 205 186  70    00  55 +21.8   71.0 +23.0  -5.2  43.50
01602534  5537 173 208 186  60    00  56 +21.4   74.0 ECU.   -5.1  42.50
01602934  5592 183 207 186  70    00  56 +21.9   77.0 +23.0  -5.1  42.50
01603334  5737 183 212 186  70    00  56 +22.4   78.0 +23.0  -5.1  42.50
01603734  5777 177 210 184  60    00  56 +22.9   80.0 ECU.   -5.1  42.50
01604134  5747 179 211 186  70    00  56 +23.2   80.0 +23.0  -5.1  42.50
01604534  5878 180 216 185  70    00  56 +23.4   81.0 +24.0  -5.1  42.50
01604934  6038 189 210 186  80    00  54 +24.0   84.0 +24.0  -5.1  42.50
01605334  6150 192 213 187  80    00  55 +24.1   84.0 +25.0  -5.1  42.50
01605734  6116 177 214 186  60    00  55 +24.1   85.0 ECU.   -5.1  42.50
01606134  6195 204 214 185  90    00  56 +24.0   88.0 +25.0  -5.1  42.50
01606534  5910 181 118  26  00    00  72 +10.6   29.0 ECU.   -5.5 ECU.
01606934  5787  68  93  25  00    00  97 +10.5   29.0 ECU.   -5.5 ECU.
01607334  5241  61 104  26  00    00 177 +10.6   29.0 ECU.   -5.5 ECU.
01607734  4901  66 105  25  00    00 177 +10.6   29.0 ECU.   -5.5 ECU.
01608134  4516  63 106  25  00    00 179 +10.7   29.0 ECU.   -5.5 ECU.
01608534  4140  61 100  26  00    00 179 +11.0   29.0 ECU.   -5.5 ECU.
01608934  3792  63  97  26  00    00 179 +11.0   29.0 ECU.   -5.5 ECU.
01609334  3505  62  93  25  00    00 178 +11.3   29.0 ECU.   -5.5 ECU.
01609734  3202  65  93  26  00    00 178 +11.4   29.0 ECU.   -5.5 ECU.
01610134  2913  65  89  26  00    00 178 +11.6   29.0 ECU.   -5.5 ECU.
01610534  2616  62  85  27  00    00 179 +11.7   29.0 ECU.   -5.5 ECU.
01610934  2370  63  80  25  00    00 178 +12.0   29.0 ECU.   -5.5 ECU.
01611334  2076  61  78  27  00    00 178 +12.0   29.0 ECU.   -5.5 ECU.
01611734  1799  63  75  26  00    00 177 +12.3   29.0 ECU.   -5.5 ECU.
01612134  1542  61  73  26  00    00 178 +12.8   29.0 ECU.   -5.5 ECU.
01612534  1270  64  69  25  00    00 178 +20.9   25.0 ECU.   -9.5 ECU.
01612934  1229  64  68  25  00    00 177 +20.7    1.0 ECU.   -9.5 ECU.
01613334  1139  65  69  27  00    00 176 +20.8    1.0 ECU.   -9.5 ECU.
01613734  1007  64  69  26  00    00 120 +21.1    1.0 ECU.   -9.5 ECU.
01614134   907  67  73  26  00    00 125 +21.4    1.0 ECU.   -9.5 ECU.
01614534   895  70  70  25  00    00 129 +21.3   68.0 ECU.   -9.5 ECU.
01614934   901  73  71  26  00    00 123 +21.2   63.0 ECU.   -9.5 ECU.
01615334   931  71  68  26  00    00 118 +17.4 1094.0 ECU.   -9.5 ECU.
01615734   917  70  68  26  00    00 111 +17.0    1.0 ECU.   -9.5 ECU.
01616134   879  69  66  25  00    00 112 +19.2  165.0 ECU.   -9.5 ECU.
01616534   856  70  68  26  00    00 118 +21.2   23.0 ECU.   -9.5 ECU.
01616934   834  70  69  26  00    00 125 +21.4   18.0 ECU.   -9.5 ECU.
01617334   828  71  67  26  00    00 125 +21.5   15.0 ECU.   -9.5 ECU.
01853761   866  70  69  26  00    00 119 +12.7   35.0 ECU.   -9.5 ECU.
01854134   891  69  70  27  00    00 123 +11.5   47.0 ECU.   -9.5 ECU.
01854534   887  70  73  31  00    00 119 +12.0   40.0 ECU.   -9.5 ECU.
01854934   975  77  94  38  00    00 123  +5.1    5.0 ECU.   -9.5 ECU.
File Type: jpg deltalog-af422-tue oct 1 2002 20-55.12.jpg (47.5 KB, 298 views)
Old 10-01-2002, 11:58 PM   #3
DiMensionX
Member#: 23517
Code:
DeltaLog-af422-Tue Oct 1 2002 20-57.26
01855334  1544  94 101  44  00    00  79  +4.0    3.0 ECU.   -5.5 ECU.
01855734  1855  98 109  48  00    00 129 +11.4    6.0 ECU.   -5.5 ECU.
01856134  2022  98 111  48  00    00 101 +34.6    6.0 ECU.   -5.5 ECU.
01856534  1929  97 111  47  00    00 112 +34.0    6.0 ECU.   -5.5 ECU.
01856934  2052  99 126  80  00    00 109 +12.5    9.0 ECU.   -5.5 ECU.
01857334  2190 116 126 117  00    00 124 +33.1    5.0 ECU.   -5.5 ECU.
01857734  2465 118 131 141  10    00  67 +34.1    9.0 ECU.   -6.1 ECU.
01858134  2677 118 134 155  10    00 137 +32.9   26.0 ECU.   -5.9  95.00
01858534  2886 122 139 160  10    00 121 +32.6   14.0 ECU.   -5.9  95.00
01858934  3195 120 148 160  10    00 119 +30.4   17.0 ECU.   -5.9  50.00
01859334  3479 130 157 163  20    00 117 +29.4   17.0 ECU.   -5.9  43.50
01859734  3835 140 167 180  30    00  96 +28.2   26.0 ECU.   -5.9  43.50
01860134  4192 147 176 182  30    00  91 +23.9   34.0 ECU.   -5.4  45.90
01860534  4681 156 189 183  40    00  51 +18.0   48.0 ECU.   -5.6  48.60
01860934  5144 184 203 182  70    00  35 +21.2   65.0 +23.0  -5.3  46.00
01861334  5574 193 208 180  80    00  46 +22.2   75.0 +24.0  -5.1  42.50
01861734  6195 190 213 181  80    00  54 +24.0   83.0 +25.0  -5.1  42.50
01862134  6535 180 216 180  70    00  54 +26.6   85.0 +25.0  -5.0  42.50
01862534  6830 188 167  25  00    00  56  +9.4   33.0 ECU.   -5.5 ECU.
01862934  6447  73  87  26  00    00 118 +10.0   33.0 ECU.   -5.5 ECU.
01863334  5757  80 186 120  00    00 182 +32.1   41.0 ECU.   -5.5 ECU.
01863734  4610 139 193 183  30    00  42 +17.4   52.0 ECU.   -5.4  45.90
01864134  4559 177 193 185  60    00  55 +15.7   52.0 ECU.   -5.6  48.60
01864534  4604 181 194 186  70    00  55 +16.4   58.0 +21.0  -5.6  48.60
01864934  4755 192 198 185  80    00  56 +17.5   64.0 +23.0  -5.3  48.00
01865334  4930 194 199 186  80    00  55 +19.5   66.0 +23.0  -5.3  46.00
01865734  5120 192 204 187  80    00  55 +21.3   68.0 +23.0  -5.3  46.00
01866134  5367 179 206 187  70    00  54 +21.8   72.0 +23.0  -5.2  43.50
01866534  5527 184 209 188  70    00  55 +22.2   78.0 +23.0  -5.1  42.50
01866934  5649 193 212 188  80    00  54 +22.4   82.0 +23.0  -5.1  42.50
01867334  5878 177 212 186  60    00  54 +23.4   85.0 ECU.   -5.1  42.50
01867734  6006 186 215 189  70    00  54 +24.0   87.0 +24.0  -5.1  42.50
01868134  6161 201 215 186  90    00  54 +24.1   89.0 +25.0  -5.1  42.50
01868534  6410 192 219 187  80    00  56 +25.9   90.0 +25.0  -5.1  42.50
01868934  6422 183 217 187  70    00  54 +26.3   92.0 +25.0  -5.0  42.50
01869334  6693 188 220 188  80    00  56 +26.4   94.0 +25.0  -5.0  42.50
01869734  6761 191 218 187  80    00  55 +26.7   92.0 +25.0  -5.0  42.50
01870134  6574 186 106  26  00    00  70 +10.1   32.0 ECU.   -5.5 ECU.
01870534  6184  66  94  26  00    00 115 +10.4   32.0 ECU.   -5.5 ECU.
01870934  5659  67 143  69  00    00 186 +18.0   23.0 ECU.   -5.5 ECU.
01871334  4844 118 195 172  10    00  58 +19.3   52.0 ECU.   -5.6  48.60
01871734  4761 162 200 186  50    00  41 +16.8   61.0 ECU.   -5.3  48.00
01872134  4945 188 205 187  80    00  55 +18.9   72.0 +23.0  -5.3  46.00
01872534  4975 198 201 186  90    00  53 +19.5   71.0 +23.0  -5.3  46.00
01872934  5012 207 206 188 100    00  54 +20.9   71.0 +23.0  -5.3  46.00
01873334  5151 184 204 188  70    00  56 +21.3   71.0 +23.0  -5.3  46.00
01873734  5208 188 204 187  80    00  56 +22.2   72.0 +23.0  -5.2  43.50
01874134  5282 197 207 186  80    00  55 +22.5   75.0 +23.0  -5.2  43.50
01874534  5393 193 207 188  80    00  55 +22.0   77.0 +23.0  -5.2  43.50
01874934  5402 184 207 186  70    00  55 +21.9   79.0 +23.0  -5.2  43.50
01875334  5491 193 210 187  80    00  54 +22.4   81.0 +23.0  -5.1  42.50
01875734  5678 193 211 188  80    00  55 +22.0   82.0 +23.0  -5.1  42.50
01876134  5668 189 212 189  80    00  55 +22.7   84.0 +23.0  -5.1  42.50
01876534  5747 207 214 188 100    00  55 +22.7   84.0 +23.0  -5.1  42.50
01876934  5868 188 214 188  80    00  55 +23.1   86.0 +24.0  -5.1  42.50
01877334  5963 190 215 188  80    00  55 +23.5   87.0 +24.0  -5.1  42.50
01877734  6060 204 215 189  90    00  56 +24.1   88.0 +25.0  -5.1  42.50
01878134  6016 190 216 188  80    00  56 +24.5   88.0 +25.0  -5.1  42.50
01878534  6195 181 218 187  70    00  56 +24.7   88.0 +25.0  -5.1  42.50
01878934  6138 181 217 188  70    00  55 +24.5   89.0 +25.0  -5.1  42.50
01879334  6265 189 215 186  80    00  56 +26.0   89.0 +25.0  -5.1  42.50
01879734  6313 192 217 188  80    00  56 +25.9   89.0 +25.0  -5.1  42.50
01880134  6349 193 218 187  80    00  56 +26.2   89.0 +25.0  -5.0  42.50
01880534  6600 184 220 188  70    00  56 +26.1   91.0 +25.0  -5.0  42.50
01880934  6944 186 218 188  70    00  56 +26.0   90.0 +25.0  -5.0  42.50
01881334  6626 185 219 188  70    00  57 +26.1   91.0 +25.0  -5.0  42.50
01881734  6666 196 219 128  00    00  57 +28.6   32.0 ECU.   -5.5 ECU.
01882134  6289  91  88  25  00    00  78 +10.4   31.0 ECU.   -5.5 ECU.
01882534  5858  65 102  27  00    00 165 +11.1   56.0 ECU.   -5.5 ECU.
01882934  5437 102 187 138  10    00 171 +21.1   47.0 ECU.   -5.2 ECU.
01883334  4782 144 193 184  30    00  36 +18.8   60.0 ECU.   -5.3  48.00
01883734  4748 182 203 185  70    00  55 +16.6   69.0 +23.0  -5.3  48.00
01884134  4775 193 202 185  80    00  55 +17.5   71.0 +23.0  -5.3  48.00
01884534  4844 195 201 186  80    00  55 +18.1   69.0 +23.0  -5.3  48.00
01884934  4930 192 205 186  80    00  55 +18.5   70.0 +23.0  -5.3  48.00
01885334  4960 200 204 184  90    00  56 +18.7   69.0 +23.0  -5.3  48.00
01885734  4923 187 202 185  70    00  56 +18.5   69.0 +23.0  -5.3  48.00
01886134  5042 195 204 184  80    00  56 +18.9   70.0 +23.0  -5.3  46.00
01886534  5020 183 204 183  70    00  58 +20.0   72.0 +23.0  -5.3  46.00
01886934  5058 202 206 183  90    00  57 +20.7   72.0 +23.0  -5.3  46.00
01887334  5065 189 205 183  80    00  57 +21.3   71.0 +23.0  -5.3  46.00
01887734  5144 184 207 184  70    00  58 +21.3   73.0 +23.0  -5.3  46.00
01888134  5167 190 207 184  80    00  58 +22.0   73.0 +23.0  -5.3  46.00
01888534  5265 206 206 183  90    00  58 +22.2   75.0 +23.0  -5.3  46.00
01888934  5241 183 206 183  70    00  59 +22.1   75.0 +23.0  -5.2  43.50
01889334  5265 202 208 176  90    00  58 +21.7   76.0 +23.0  -5.2  43.50
01889734  5257 172  83  27  00    00  69 +10.7   11.0 ECU.   -5.5 ECU.
01890134  5257  66  93  25  00    00 118 +10.8   11.0 ECU.   -5.5 ECU.
01890534  5081  62 104  27  00    00 178 +10.3   11.0 ECU.   -5.5 ECU.
01890934  5005  66 106  26  00    00 178 +10.6   11.0 ECU.   -5.5 ECU.
01891334  4952  60 107  27  00    00 179 +10.7   11.0 ECU.   -5.5 ECU.
01891734  4789  62 102  27  00    00 178 +10.6   11.0 ECU.   -5.5 ECU.
01892134  4642  57 100  27  00    00 179 +10.9   11.0 ECU.   -5.5 ECU.
01892534  4492  59  96  27  00    00 178 +10.6   11.0 ECU.   -5.5 ECU.
01892934  4385  61  93  26  00    00 178 +10.9   11.0 ECU.   -5.5 ECU.
01893334  4329  57  90  26  00    00 180 +10.8   11.0 ECU.   -5.5 ECU.
01893734  4246  55  86  26  00    00 179 +11.0   11.0 ECU.   -5.5 ECU.
01894134  4135  58  83  26  00    00 179 +10.9   11.0 ECU.   -5.5 ECU.
File Type: jpg deltalog-af422-tue oct 1 2002 20-57.26.jpg (47.0 KB, 290 views)
Old 10-01-2002, 11:59 PM   #4
DiMensionX
Member#: 23517
Code:
DeltaLog-af422-Tue Oct 1 2002 20-58.23
01977361  2295 128 133 141  10    00 114 +30.4   13.0 ECU.   -6.1 ECU.
01977734  2311 132 137 163  20    00  75 +29.7   11.0 ECU.   -6.1  95.00
01978134  2332 131 135 163  20    00 120 +29.7   96.0 ECU.   -6.1  95.00
01978534  2355 133 136 176  20    00  97 +29.7   12.0 ECU.   -6.1  95.00
01978934  2374 135 136 178  20    00 112 +29.7   12.0 ECU.   -6.1  95.00
01979334  2380 134 136 178  20    00 115 +29.7   12.0 ECU.   -6.1  95.00
01979734  2405 136 138 179  20    00 116 +29.7   12.0 ECU.   -6.1  95.00
01980134  2399 135 138 179  20    00 114 +29.5   13.0 ECU.   -6.1  95.00
01980534  2403 136 139 178  20    00 115 +29.4   13.0 ECU.   -6.1  95.00
01980934  2417 136 138 178  20    00 116 +29.5   13.0 ECU.   -6.1  95.00
01981334  2431 137 139 179  20    00 113 +29.4   13.0 ECU.   -6.1  95.00
01981734  2460 137 139 180  20    00 111 +29.4   13.0 ECU.   -6.1  95.00
01982134  2458 138 140 180  20    00 111 +29.1   13.0 ECU.   -6.1  95.00
01982534  2469 137 138 178  20    00 111 +29.2   13.0 ECU.   -6.1  95.00
01982934  2489 141 141 180  30    00 108 +29.1   13.0 ECU.   -6.1  95.00
01983334  2474 139 139 180  30    00 107 +29.1   14.0 ECU.   -6.1  95.00
01983734  2498 141 141 180  30    00 104 +28.8   14.0 ECU.   -5.9  95.00
01984134  2515 141 139 180  30    00 107 +28.7   14.0 ECU.   -5.9  95.00
01984534  2508 140 142 182  30    00 109 +28.8   14.0 ECU.   -5.9  95.00
01984934  2548 141 143 182  30    00 112 +28.0   14.0 ECU.   -5.9  95.00
01985334  2538 144 143 181  30    00 108 +28.4   15.0 ECU.   -5.9  95.00
01985734  2546 143 143 182  30    00 105 +26.7   15.0 ECU.   -5.9  95.00
01986134  2562 144 144 181  30    00 106 +26.6   15.0 ECU.   -5.9  95.00
01986534  2606 144 144 181  30    00 110 +26.6   15.0 ECU.   -5.9  95.00
01986934  2594 145 147 183  30    00 103 +25.2   15.0 ECU.   -5.9  95.00
01987334  2626 146 144 183  30    00 103 +24.8   16.0 ECU.   -5.9  95.00
01987734  2620 147 146 182  30    00 111 +24.1   16.0 ECU.   -5.9  95.00
01988134  2628 147 148 183  30    00 105 +23.8   16.0 ECU.   -5.9  95.00
01988534  2653 149 147 182  40    00 105 +23.7   16.0 ECU.   -5.9  95.00
01988934  2686 149 147 183  40    00 108 +23.8   16.0 ECU.   -5.9  95.00
01989334  2699 149 149 183  40    00 106 +23.3   17.0 ECU.   -5.9  95.00
01989734  2716 151 151 184  40    00 107 +22.8   17.0 ECU.   -5.9  95.00
01990134  2723 150 150 183  40    00  96 +22.4   18.0 ECU.   -5.9  95.00
01990534  2750 152 152 182  40    00  98 +22.1   18.0 ECU.   -5.9  95.00
01990934  2752 155 152 184  40    00  88 +22.1   19.0 ECU.   -5.9  95.00
01991334  2766 152 151 183  40    00  90 +21.5   19.0 ECU.   -5.9  95.00
01991734  2752 156 153 182  40    00  80 +21.2   20.0 ECU.   -5.9  95.00
01992134  2773 158 157 184  40    00  80 +20.7   20.0 ECU.   -5.9  95.00
01992534  2759 156 155 184  40    00  84 +20.2   21.0 ECU.   -5.9  95.00
01992934  2841 164 157 184  50    00  76 +20.5   21.0 ECU.   -5.9  95.00
01993334  2827 163 158 182  50    00  77 +19.6   22.0 ECU.   -5.9  95.00
01993734  2849 163 159 182  50    00  75 +17.7   23.0 ECU.   -5.9  95.00
01994134  2836 160 161 182  50    00  70 +17.0   24.0 ECU.   -5.9  95.00
01994534  2883 167 163 181  50    00 106 +15.9   25.0 ECU.   -5.9  95.00
01994934  2903 172 165 182  60    00  65 +15.1   25.0 ECU.   -5.9  95.00
01995334  2866 174 167 181  60    00  62 +13.8   27.0 ECU.   -5.9  95.00
01995734  2952 182 168 182  70    00  65 +14.7   28.0 +24.0  -5.9  95.00
01996134  2931 181 170 182  70    01  59 +13.2   29.0 +10.0  -5.9  95.00
01996534  2965 185 172 184  70    00  63 +12.8   31.0  +8.0  -5.9  95.00
01996934  2984 192 174 173  80    00  58 +12.1   32.0  +8.0  -5.9  50.00
01997334  2994 189 160  77  00    00  60 +13.4   26.0 ECU.   -5.5 ECU.
01997734  2992 173 154  75  00    00  77 +19.4   22.0 ECU.   -5.5 ECU.
01998134  3013 158 153  73  00    00  57 +23.3   20.0 ECU.   -5.5 ECU.
01998534  3063 141 143  53  00    00  66 +29.2   15.0 ECU.   -5.5 ECU.
01998934  3063 121 138  50  00    00  97 +30.8   12.0 ECU.   -5.5 ECU.
01999334  3060 115 124  42  00    00 114 +32.5   10.0 ECU.   -5.5 ECU.
01999734  3052 100 106  35  00    00 105 +39.0    6.0 ECU.   -5.5 ECU.
02000134  3035  81  98  34  00    00 114 +35.0    5.0 ECU.   -5.5 ECU.
02000534  3016  73  90  30  00    00 117 +33.6    4.0 ECU.   -5.5 ECU.
02000934  2994  65  86  29  00    00 118 +33.3    3.0 ECU.   -5.5 ECU.
02001334  2981  62  81  27  00    00 122 +25.3    3.0 ECU.   -5.5 ECU.
02001734  2970  59  75  26  00    00 151 +16.4    3.0 ECU.   -5.5 ECU.
02002134  2957  57  72  25  00    00 177 +11.6    3.0 ECU.   -5.5 ECU.
02002534  2942  57  72  25  00    00 186 +11.4    3.0 ECU.   -5.5 ECU.
02002934  2942  56  73  26  00    00 178 +11.5    3.0 ECU.   -5.5 ECU.
02003334  2947  54  74  27  00    00 178 +11.4    3.0 ECU.   -5.5 ECU.
02003734  2936  57  73  25  00    00 178 +11.3    3.0 ECU.   -5.5 ECU.
02004134  2921  55  73  25  00    00 178 +11.5    3.0 ECU.   -5.5 ECU.
02004226  2921  55  73  25  00    00 178 +11.4    3.0 ECU.   -5.5 ECU.
02004534  2883  56  74  26  00    00 180 +11.4    3.0 ECU.   -5.5 ECU.
02004934  2901  55  74  27  00    00 179 +11.5    3.0 ECU.   -5.5 ECU.
02005334  2896  56  74  27  00    00 179 +11.5    3.0 ECU.   -5.5 ECU.
02005734  2861  57  72  25  00    00 179 +11.5    3.0 ECU.   -5.5 ECU.
02006134  2873  57  73  26  00    00 179 +11.4    3.0 ECU.   -5.5 ECU.
02006534  2834  54  73  27  00    00 179 +11.6    3.0 ECU.   -5.5 ECU.
02006934  2846  55  74  26  00    00 179 +11.5    3.0 ECU.   -5.5 ECU.
02007334  2822  55  72  25  00    00 177 +11.5    3.0 ECU.   -5.5 ECU.
02007734  2832  57  74  27  00    00 179 +11.5    3.0 ECU.   -5.5 ECU.
02008134  2794  55  73  27  00    00 180 +11.6    3.0 ECU.   -5.5 ECU.
02008534  2812  55  73  26  00    00 179 +11.6    3.0 ECU.   -5.5 ECU.
02008934  2805  57  72  26  00    00 179 +11.6    3.0 ECU.   -5.5 ECU.
02009334  2761  58  74  26  00    00 180 +11.5    3.0 ECU.   -5.5 ECU.
02009734  2773  55  74  27  00    00 180 +11.5    3.0 ECU.   -5.5 ECU.
File Type: jpg deltalog-af422-tue oct 1 2002 20-58.23.jpg (46.5 KB, 286 views)
Old 10-02-2002, 12:02 AM   #5
DiMensionX
Member#: 23517
Code:
DeltaLog-af422-Tue Oct 1 2002 20-59.55
02010134  2734  56  73  26  00    00 179 +11.6    3.0 ECU.   -5.5 ECU.
02010534  2701  55  72  26  00    00 178 +11.5    3.0 ECU.   -5.5 ECU.
02010934  2670  55  72  25  00    00 178 +11.5    3.0 ECU.   -5.5 ECU.
02011334  2639  55  73  27  00    00 178 +11.6    3.0 ECU.   -5.5 ECU.
02011734  2620  56  72  26  00    00 178 +11.7    3.0 ECU.   -5.5 ECU.
02012134  2583  56  73  27  00    00 179 +11.6    3.0 ECU.   -5.5 ECU.
02012534  2577  55  72  25  00    00 178 +11.6    3.0 ECU.   -5.5 ECU.
02012934  2546  57  73  27  00    00 179 +11.7    3.0 ECU.   -5.5 ECU.
02013334  2544  54  72  26  00    00 178 +11.6    3.0 ECU.   -5.5 ECU.
02013734  2357  55  73  26  00    00 178 +11.8    3.0 ECU.   -5.5 ECU.
02014134  2096  57  69  25  00    00 177 +12.2    3.0 ECU.   -5.5 ECU.
02014534  1834  57  68  27  00    00 178 +12.2    3.0 ECU.   -5.5 ECU.
02014934  1603  58  71  27  00    00 178 +12.3    3.0 ECU.   -5.5 ECU.
02015334  1641  58  68  26  00    00 178 +11.9    3.0 ECU.   -5.5 ECU.
02015734  2065  58  67  25  00    00 178 +11.4    3.0 ECU.   -5.5 ECU.
02016134  2560  58  71  27  00    00 178 +11.3    3.0 ECU.   -5.5 ECU.
02016534  3233  58  73  28  00    00 179 +11.1    3.0 ECU.   -5.5 ECU.
02016934  3226  57  79  28  00    00 179 +11.3    3.0 ECU.   -5.5 ECU.
02017334  3150  58  79  28  00    00 178 +25.3    3.0 ECU.   -5.5 ECU.
02017734  3183  58  80  29  00    00 178 +35.4    3.0 ECU.   -5.5 ECU.
02018134  3138  60  87  33  00    00 177 +35.0    4.0 ECU.   -5.5 ECU.
02018534  3144  62  94  36  00    00 155 +34.9    4.0 ECU.   -5.5 ECU.
02018934  3126  65  96  36  00    00 131 +35.1    5.0 ECU.   -5.5 ECU.
02019334  3141  64  96  35  00    00 118 +34.9    5.0 ECU.   -5.5 ECU.
02019734  3124  65  98  37  00    00 110 +34.6    5.0 ECU.   -5.5 ECU.
02020134  3135  67  97  36  00    00 116 +34.7    5.0 ECU.   -5.5 ECU.
02020534  3129  64  98  37  00    00 113 +34.7    5.0 ECU.   -5.5 ECU.
02020934  3112  67  98  36  00    00 118 +35.0    5.0 ECU.   -5.5 ECU.
02021334  3103  69 100  38  00    00 113 +35.4    5.0 ECU.   -5.5 ECU.
02021734  3121  67 103  40  00    00 117 +36.1    6.0 ECU.   -5.5 ECU.
02022134  3089  68 107  41  00    00 112 +37.1    6.0 ECU.   -5.5 ECU.
02022534  3118  73 108  41  00    00 111 +38.5    7.0 ECU.   -5.5 ECU.
02022934  3112  77 110  43  00    00 113 +39.3    7.0 ECU.   -5.5 ECU.
02023334  3124  77 110  43  00    00 113 +39.3    7.0 ECU.   -5.5 ECU.
02023734  3115  78 111  44  00    00 115 +39.5    7.0 ECU.   -5.5 ECU.
02024134  3103  78 111  43  00    00 118 +39.9    7.0 ECU.   -5.5 ECU.
02024534  3109  81 111  43  00    00 111 +40.1    7.0 ECU.   -5.5 ECU.
02024934  3129  80 113  44  00    00 113 +40.3    7.0 ECU.   -5.5 ECU.
02025334  3141  80 112  43  00    00 114 +40.6    7.0 ECU.   -5.5 ECU.
02025734  3138  79 113  44  00    00 114 +40.3    7.0 ECU.   -5.5 ECU.
02026134  3115  82 112  43  00    00 113 +40.7    7.0 ECU.   -5.5 ECU.
02026534  3141  78 113  45  00    00 115 +40.5    7.0 ECU.   -5.5 ECU.
02026934  3126  81 114  45  00    00 116 +40.7    7.0 ECU.   -5.5 ECU.
02027334  3147  84 114  45  00    00 113 +41.1    7.0 ECU.   -5.5 ECU.
02027734  3132  83 113  43  00    00 109 +40.6    7.0 ECU.   -5.5 ECU.
02028134  3156  83 113  44  00    00 111 +40.3    7.0 ECU.   -5.5 ECU.
02028534  3132  81 112  44  00    00 115 +39.5    7.0 ECU.   -5.5 ECU.
02028934  3159  81 111  43  00    00 116 +39.5    7.0 ECU.   -5.5 ECU.
02029334  3132  81 109  41  00    00 111 +39.3    7.0 ECU.   -5.5 ECU.
02029734  3156  79 110  42  00    00 111 +39.3    7.0 ECU.   -5.5 ECU.
02030134  3138  75 108  42  00    00 112 +39.4    7.0 ECU.   -5.5 ECU.
02030312  3168  77 106  41  00    00 111 +38.9    7.0 ECU.   -5.5 ECU.
02030534  3159  75 110  42  00    00 115 +38.9    7.0 ECU.   -5.5 ECU.
02030934  3138  77 108  41  00    00 112 +39.0    7.0 ECU.   -5.5 ECU.
02031334  3159  79 109  42  00    00 113 +39.3    7.0 ECU.   -5.5 ECU.
02031734  3132  80 109  42  00    00 114 +39.3    7.0 ECU.   -5.5 ECU.
02032134  3159  79 109  41  00    00 112 +39.3    7.0 ECU.   -5.5 ECU.
02032534  3174  79 108  41  00    00 115 +39.4    7.0 ECU.   -5.5 ECU.
02032934  3156  76 107  40  00    00 115 +39.3    7.0 ECU.   -5.5 ECU.
02033334  3174  75 109  42  00    00 114 +39.4    7.0 ECU.   -5.5 ECU.
02033734  3150  76 110  42  00    00 114 +39.3    7.0 ECU.   -5.5 ECU.
02034134  3168  77 109  42  00    00 115 +39.2    7.0 ECU.   -5.5 ECU.
02034534  3147  77 108  41  00    00 113 +39.3    7.0 ECU.   -5.5 ECU.
02034934  3121  79 110  42  00    00 111 +39.3    7.0 ECU.   -5.5 ECU.
02035334  3141  79 109  43  00    00 112 +39.4    7.0 ECU.   -5.5 ECU.
02035734  3121  77 110  43  00    00 114 +39.4    7.0 ECU.   -5.5 ECU.
02036134  3144  76 108  41  00    00 114 +39.3    7.0 ECU.   -5.5 ECU.
02036534  3118  75 109  43  00    00 111 +39.0    7.0 ECU.   -5.5 ECU.
02036934  3138  79 110  43  00    00 113 +39.0    7.0 ECU.   -5.5 ECU.
02037334  3141  76 110  43  00    00 115 +38.9    7.0 ECU.   -5.5 ECU.
02037734  3135  76 108  41  00    00 111 +38.9    7.0 ECU.   -5.5 ECU.
02038134  3132  77 110  42  00    00 115 +39.3    7.0 ECU.   -5.5 ECU.
02038534  3097  75 109  42  00    00 115 +39.3    7.0 ECU.   -5.5 ECU.
02038934  3115  79 110  43  00    00 117 +39.3    7.0 ECU.   -5.5 ECU.
02158450  2841  78 109  43  00    00 113 +39.0    6.0 ECU.   -5.5 ECU.
02158534  2858  78 109  43  00    00 113 +39.1    6.0 ECU.   -5.5 ECU.
02158934  2858  80 137  71  00    00  87 +33.4   11.0 ECU.   -5.5 ECU.
02159334  2886 114 144 148  10    00 129 +32.6    6.0 ECU.   -5.9 ECU.
02159734  2886 123 145 175  10    00 100 +30.9   15.0 ECU.   -5.9  95.00
02160134  2913 126 146 183  10    00  89 +28.9   16.0 ECU.   -5.9  95.00
02160534  2936 131 150 185  20    00 100 +26.8   18.0 ECU.   -5.9  95.00
02160934  2989 135 154 186  20    00  98 +24.9   19.0 ECU.   -5.9  50.00
02161334  3024 142 156 184  30    00  96 +23.6   20.0 ECU.   -5.9  50.00
02161734  3046 150 162 185  40    00  95 +21.8   22.0 ECU.   -5.9  50.00
02162134  3097 151 162 184  40    00  87 +20.2   24.0 ECU.   -5.9  50.00
02162534  3115 161 167 182  50    00  84 +16.5   26.0 ECU.   -5.9  50.00
02162934  3135 168 172 170  60    00  87 +15.1   27.0 ECU.   -5.9  50.00
02163334  3192 174 175 166  60    00  84 +13.7   29.0 ECU.   -5.9  50.00
02163734  3233 182 174 166  70    32  73 +12.2   31.0 +12.0  -5.9  46.80
02164134  3280 184 179 166  70    00  77 +10.9   32.0 +10.0  -5.9  46.80
02164534  3340 179 178 163  70    00  65 +10.7   34.0 +10.0  -5.9  46.80
02164934  3422 189 178 146  80    00  64 +10.4   35.0 +10.0  -5.9 ECU.
02165334  3479 192 183 130  00    00  51 +12.2   39.0 ECU.   -5.5 ECU.
02165734  3486 205 182 113  00    00  57 +11.4   39.0 ECU.   -5.5 ECU.
02166134  3561 197 175 107  00    00  59 +15.0   33.0 ECU.   -5.5 ECU.
02166534  3549 177 169  99  00    00  84 +21.8   27.0 ECU.   -5.5 ECU.
02166934  3603 154 166  99  00    00  95 +24.9   26.0 ECU.   -5.5 ECU.
02167334  3631 148 166  99  00    00  88 +24.7   26.0 ECU.   -5.5 ECU.
02167734  3716 153 166 100  00    00  81 +24.3   27.0 ECU.   -5.5 ECU.
02168134  3779 154 167 102  00    00  80 +24.3   28.0 ECU.   -5.5 ECU.
02168534  3792 152 171 107  00    00  77 +23.3   29.0 ECU.   -5.5 ECU.
02168934  3853 156 172 121  00    00  71 +21.4   31.0 ECU.   -5.5 ECU.
02169334  3889 156 175 122  00    00  64 +21.6   31.0 ECU.   -5.5 ECU.
02169734  3921 157 174 125  00    00  70 +21.6  217.0 ECU.   -5.5 ECU.
02170134  3921 158 174 129  00    00  60 +21.4   33.0 ECU.   -5.5 ECU.
02170534  3987 158 179 130  00    00  63 +20.3   35.0 ECU.   -5.5 ECU.
02170934  4001 163 177 130  00    00  56 +18.9   39.0 ECU.   -5.5 ECU.
02171334  4074 169 181 132  00    00  57 +16.0   42.0 ECU.   -5.5 ECU.
02171734  4084 180 184 135  00    00  55 +15.4   46.0 ECU.   -5.5 ECU.
02172134  4192 181 189 142  70    00  56 +15.1   49.0 +17.0  -5.9 ECU.
02172534  4235 184 186 149  70    00  56 +15.6   51.0 +17.0  -5.9 ECU.
02172934  4284 185 192 149  70    00  56 +13.7   56.0 +17.0  -5.4 ECU.
02173334  4317 186 197 151  70    00  54 +13.3   61.0 +19.0  -5.4 ECU.
02173734  4351 193 202 160  80    00  55 +12.6   64.0 +19.0  -5.4  45.90
02174134  4438 209 202 170 100    00  55 +12.5   68.0 +19.0  -5.4  45.90
02174534  4474 188 197 177  80    00  56 +13.0   63.0 +21.0  -5.6  48.60
02174934  4578 199 197 179  90    00  56 +13.8   65.0 +21.0  -5.6  48.60
02175334  4636 204 202 180  90    00  55 +14.3   66.0 +21.0  -5.6  48.60
02175734  4623 201 198 179  90    00  55 +14.7   66.0 +21.0  -5.6  48.60
02176134  4708 198 200 180  90    00  56 +14.9   67.0 +23.0  -5.3  48.00
02176534  4844 199 202 181  90    00  54 +15.5   69.0 +23.0  -5.3  48.00
02176934  4901 189 202 179  80    00  55 +16.1   70.0 +23.0  -5.3  48.00
02177334  4823 188 203 168  80    00  55 +16.6   71.0 +23.0  -5.3  48.00
02177734  4894 202 203 153  90    00  55 +17.5   72.0 +23.0  -5.3 ECU.
02178134  5005 194 206 153  80    00  55 +17.3   77.0 +23.0  -5.3 ECU.
02178534  5104 202 211 140  90    00  56 +16.5   80.0 +23.0  -5.3 ECU.
02178934  5081 202 207 138  90    00  55 +17.8   81.0 +23.0  -5.3 ECU.
02179334  5081 208 208 147 100    00  56 +17.7   78.0 +15.0  -5.3 ECU.
02179734  5291 192 209 153  80    00  56 +18.7   79.0 +15.0  -5.2 ECU.
02180134  5299 189 210 153  80    00  56 +18.4   80.0 +15.0  -5.2 ECU.
02180534  5291 202 210 153  90    00  56 +19.1   79.0 +23.0  -5.2 ECU.
02180934  5316 180 212 153  70    00  58 +19.0   80.0 +23.0  -5.2 ECU.
02181334  5437 198 202  82  00    00  57 +39.2   19.0 ECU.   -5.5 ECU.
02181734  5265  84  80  26  00    00  89 +10.6   20.0 ECU.   -5.5 ECU.
02182134  4830  63 102  25  00    00 138 +10.7   20.0 ECU.   -5.5 ECU.
02182534  4498  65 106  26  00    00 182 +11.1   20.0 ECU.   -5.5 ECU.
02182934  4105  67 105  26  00    00 179 +10.9   20.0 ECU.   -5.5 ECU.
02183334  3849  68 102  26  00    00 178 +11.0   20.0 ECU.   -5.5 ECU.
02183734  3871  66  79  25  00    00 179 +11.1   20.0 ECU.   -5.5 ECU.
02184134  3840  65  95  26  00    00 179 +10.9   20.0 ECU.   -5.5 ECU.
02184534  3779  60  91  26  00    00 179 +11.1   20.0 ECU.   -5.5 ECU.
02184934  3716  63  87  26  00    00 178 +11.2   20.0 ECU.   -5.5 ECU.
02185334  3707  60  82  25  00    00 178 +11.0   20.0 ECU.   -5.5 ECU.
02185734  3623  56  80  27  00    00 178 +11.2   20.0 ECU.   -5.5 ECU.
02186134  3568  56  76  27  00    00 179 +11.2   20.0 ECU.   -5.5 ECU.
02186534  3505  55  76  27  00    00 178 +11.3   20.0 ECU.   -5.5 ECU.
File Type: jpg deltalog-af422-tue oct 1 2002 20-59.55.jpg (47.7 KB, 277 views)
Old 10-02-2002, 12:03 AM   #6
DiMensionX
Member#: 23517
Code:
DeltaLog-af422-Tue Oct 1 2002 21-00.53
02269734  2805  79 110  42  00    00 114 +39.4    7.0 ECU.   -5.5 ECU.
02270134  2827  81 110  42  00    00 113 +39.3    7.0 ECU.   -5.5 ECU.
02270534  2824  81 111  43  00    00 113 +39.9    7.0 ECU.   -5.5 ECU.
02270934  2803  79 111  43  00    00 113 +39.6    7.0 ECU.   -5.5 ECU.
02271334  2808  84 112  44  00    00 116 +39.7    7.0 ECU.   -5.5 ECU.
02271734  2849  83 142  84  00    00 112 +33.0   13.0 ECU.   -5.5 ECU.
02272134  2824 117 143 144  10    00 111 +31.9   13.0 ECU.   -5.9 ECU.
02272534  2876 122 146 172  10    00  84 +30.8   15.0 ECU.   -5.9  95.00
02272934  2873 128 150 175  10    00 104 +28.5   16.0 ECU.   -5.9  95.00
02273334  2893 131 151 174  20    00  97 +26.5   17.0 ECU.   -5.9  95.00
02273734  2952 142 152 168  30    00  97 +24.7   18.0 ECU.   -5.9  95.00
02274134  2942 141 157 163  30    00  99 +23.2   20.0 ECU.   -5.9  95.00
02274534  2981 150 161 165  40    00  97 +21.6   21.0 ECU.   -5.9  50.00
02274934  3016 155 163 178  40    00  73 +18.6   34.0 ECU.   -5.9  50.00
02275334  3058 158 167 182  40    00  76 +16.9   25.0 ECU.   -5.9  50.00
02275734  3092 162 166 182  50    00  74 +15.1   26.0 ECU.   -5.9  50.00
02276134  3097 173 172 183  60    00  74 +11.6   28.0 ECU.   -5.9  50.00
02276534  3171 180 175 183  70    01  69 +11.2   30.0 +18.0  -5.9  50.00
02276934  3198 185 177 184  70    00  66 +13.5   31.0 +14.0  -5.9  50.00
02277334  3255 191 177 182  80    00  69 +13.7   32.0 +14.0  -5.9  46.80
02277734  3297 185 176 184  70    00  59 +13.2   33.0 +10.0  -5.9  46.80
02278134  3350 187 179 183  70    00  63 +13.3   35.0 +10.0  -5.9  46.80
02278534  3384 185 174 182  70    00  56 +13.4   34.0 +18.0  -5.9  46.80
02278934  3415 192 180 177  80    00  60 +13.3   35.0 +10.0  -5.9  46.80
02279334  3490 190 180 177  80    00  59 +12.6   37.0 +10.0  -5.9  46.80
02279734  3512 188 180 177  80    00  56 +12.9   38.0 +10.0  -5.9  43.50
02280134  3572 190 181 177  80    00  56 +13.3   37.0  +7.0  -5.9  43.50
02280534  3591 186 179 173  70    00  56 +13.0   38.0 +13.0  -5.9  43.50
02280934  3619 191 179 172  80    00  56 +13.8   39.0 +15.0  -5.9  43.50
02281334  3671 191 179 168  80    00  56 +16.0   39.0 +15.0  -5.9  43.50
02281734  3650 179 185 167  70    00  56 +16.3   41.0 +15.0  -5.9  43.50
02282134  3753 188 180 167  80    00  56 +15.9   42.0 +15.0  -5.9  43.50
02282534  3792 185 180 167  70    00  57 +16.0   42.0 +15.0  -5.9  43.50
02282934  3800 184 181 167  70    00  57 +16.0   44.0 +15.0  -5.9  43.50
02283334  3858 192 186 167  80    00  55 +16.2   44.0 +15.0  -5.9  43.50
02283734  3894 186 186 167  70    00  57 +16.3   46.0 +15.0  -5.9  43.50
02284134  3889 189 186 168  80    00  56 +16.5   46.0 +15.0  -5.9  43.50
02284534  3954 187 190 168  70    00  57 +17.3   47.0 +15.0  -5.9  43.50
02284934  4001 189 184 169  80    00  57 +16.5   47.0 +17.0  -5.9  44.50
02285334  4084 191 188 168  80    00  57 +19.1   50.0 +17.0  -5.9  44.50
02285734  4110 187 187 168  70    00  57 +18.4   52.0 +17.0  -5.9  44.50
02286134  4135 195 187 170  80    00  57 +18.4   52.0 +17.0  -5.9  44.50
02286534  4208 196 192 169  80    00  57 +18.7   51.0 +17.0  -5.9  44.50
02286934  4278 187 192 170  70    00  57 +18.2   51.0 +17.0  -5.4  45.90
02287334  4290 187 194 170  70    00  57 +17.6   53.0 +19.0  -5.4  45.90
02287734  4290 186 194 170  70    00  55 +17.2   57.0 +19.0  -5.4  45.90
02288134  4380 193 194 171  80    00  56 +17.4   58.0 +19.0  -5.4  45.90
02288534  4438 197 190 172  80    00  56 +16.8   58.0 +19.0  -5.4  45.90
02288934  4415 195 197 172  80    00  55 +16.8   62.0 +19.0  -5.4  45.90
02289334  4432 201 198 172  90    00  56 +16.3   64.0 +21.0  -5.6  48.60
02289734  4409 189 202 175  80    00  56 +17.0   63.0 +21.0  -5.6  48.60
02290134  4480 198 199 174  90    00  56 +17.4   64.0 +21.0  -5.6  48.60
02290534  4610 188 203 174  80    00  57 +18.2   65.0 +21.0  -5.6  48.60
02290934  4649 202 200 174  90    00  55 +18.5   67.0 +21.0  -5.6  48.60
02291334  4694 192 201 174  80    00  56 +19.3   67.0 +21.0  -5.6  48.60
02291734  4741 206 203 175  90    00  57 +20.0   68.0 +21.0  -5.6  48.60
02292134  4668 194 201 174  80    00  56 +19.5   71.0 +23.0  -5.3  48.00
02292534  4823 206 205 175  90    00  56 +20.9   70.0 +23.0  -5.3  48.00
02292934  4852 187 205 175  70    00  56 +21.0   72.0 +23.0  -5.3  48.00
02293334  4916 186 206 175  70    00  57 +21.0   72.0 +23.0  -5.3  48.00
02293734  4837 203 202 174  90    00  57 +22.1   72.0 +23.0  -5.3  48.00
02294134  4997 198 207 176  90    00  58 +22.6   73.0 +23.0  -5.3  48.00
02294534  4997 211 204 175 100    00  56 +22.9   74.0 +23.0  -5.3  46.00
02294934  5073 205 206 175  90    00  57 +21.7   74.0 +23.0  -5.3  46.00
02295334  5005 194 207 176  80    00  58 +23.2   75.0 +23.0  -5.3  46.00
02295734  5089 197 206 175  80    00  57 +22.2   76.0 +23.0  -5.3  46.00
02296134  5104 194 207 175  80    00  58 +22.2   76.0 +23.0  -5.3  46.00
02296534  5167 198 210 175  90    00  57 +24.2   77.0 +23.0  -5.3  46.00
02296934  5159 194 209 175  80    00  58 +24.3   78.0 +23.0  -5.3  46.00
02297334  5159 187 210 166  70    00  58 +23.5   79.0 +23.0  -5.2  43.50
02297734  5282 210 209 132  00    00  58 +23.6   76.0 ECU.   -5.5 ECU.
02298134  5265 206 188  64  00    00  60 +35.8   15.0 ECU.   -5.5 ECU.
02298534  5167  90  82  26  00    00 108 +10.7   13.0 ECU.   -5.5 ECU.
02298934  4782  69 102  26  00    00 172 +10.7   13.0 ECU.   -5.5 ECU.
02299334  4403  64 106  26  00    00 180 +11.0   13.0 ECU.   -5.5 ECU.
02299734  4055  62 105  26  00    00 178 +10.9   13.0 ECU.   -5.5 ECU.
02300134  3779  70 103  26  00    00 179 +11.2   13.0 ECU.   -5.5 ECU.
02300534  3475  64  75  25  00    00 179 +11.4   13.0 ECU.   -5.5 ECU.
02300934  3180  71  97  26  00    00 178 +11.5   13.0 ECU.   -5.5 ECU.
02301334  2901  66  93  26  00    00 178 +11.7   13.0 ECU.   -5.5 ECU.
File Type: jpg deltalog-af422-tue oct 1 2002 21-00.53.jpg (47.0 KB, 272 views)
Old 10-02-2002, 12:05 AM   #7
DiMensionX
Member#: 23517
Code:
DeltaLog-af422-Tue Oct 1 2002 21-06.07
02901137   719  71  66  26  00    00 115 +13.7    6.0 ECU.   -9.5 ECU.
02901334   705  71  68  26  00    00 118 +13.5    6.0 ECU.   -9.5 ECU.
02901734   758  72  90  40  00    00 119 +13.2  147.0 ECU.   -9.5 ECU.
02902134  1184 107 102  62  00    00  84 +19.6    4.0 ECU.   -9.5 ECU.
02902534  1731 108 112  63  00    00 125 +29.0   15.0 ECU.   -5.5 ECU.
02902934  2033 108 119  69  00    00 119 +34.2    8.0 ECU.   -5.5 ECU.
02903334  2065 110 123  84  00    00  85 +34.0    8.0 ECU.   -5.5 ECU.
02903734  1890 113 122  87  00    00 122 +32.5    9.0 ECU.   -5.5 ECU.
02904134  1693 117 116  88  00    00 111 +25.0   15.0 ECU.   -5.5 ECU.
02904534  2115 118 128 126  00    00  92 +32.6    9.0 ECU.   -5.5 ECU.
02904934  2415 120 129 135  00    00 127 +27.2   17.0 ECU.   -5.5 ECU.
02905334  2632 122 138 137  10    00 128 +31.3   13.0 ECU.   -5.9 ECU.
02905734  2973 121 148 138  10    00 126 +29.2   16.0 ECU.   -5.9 ECU.
02906134  3290 128 155 137  10    00 118 +23.8   19.0 ECU.   -5.9 ECU.
02906534  3607 139 161 135  00    00 108 +22.9   23.0 ECU.   -5.5 ECU.
02906934  4055 150 174 136  00    00  84 +16.5   37.0 ECU.   -5.5 ECU.
02907334  4492 159 192 175  50    00  25 +11.5   56.0 ECU.   -5.6  48.60
02907734  5050 176 206 180  60    00  49 +10.1   74.0 ECU.   -5.3  46.00
02908134  5659 187 211 182  70    00  54 +16.3   81.0 +23.0  -5.1  42.50
02908534  6218 207 214 175 100    00  53 +18.7   84.0 +25.0  -5.1  42.50
02908934  6640 182 218 178  70    00  54 +20.9   87.0 +25.0  -5.0  42.50
02909334  7077 179 219  92  00    00  53 +31.1   85.0 ECU.   -5.5 ECU.
02909734  6693  80  78  26  00    00 135  +9.7   85.0 ECU.   -5.5 ECU.
02910134  6093  73 184 106  00    00 178 +35.6   42.0 ECU.   -5.5 ECU.
02910534  4866 135 201 181  20    00  48 +12.1   64.0 ECU.   -5.6  48.60
02910934  4887 178 198 183  70    00  53 +10.1   68.0 +23.0  -5.3  48.00
02911334  4916 178 200 184  70    00  53 +11.6   72.0 +23.0  -5.3  46.00
02911734  5120 200 207 186  90    00  55 +13.7   76.0 +23.0  -5.3  46.00
02912134  5307 185 208 187  70    00  53 +15.8   80.0 +23.0  -5.2  43.50
02912534  5527 203 212 185  90    00  54 +15.7   82.0 +23.0  -5.1  42.50
02912934  5777 195 213 186  80    00  54 +16.3   86.0 +23.0  -5.1  42.50
02913334  5984 180 216 186  70    00  54 +17.9   87.0 +24.0  -5.1  42.50
02913734  6116 199 217 186  90    00  54 +18.4   86.0 +25.0  -5.1  42.50
02914134  6497 184 218 186  70    00  54 +20.8   87.0 +25.0  -5.1  42.50
02914534  6666 199 217 187  90    00  53 +20.8   92.0 +25.0  -5.0  42.50
02914934  6775 192 217 119  00    00  53 +27.4   43.0 ECU.   -5.5 ECU.
02915334  6373  93  79  25  00    00  85 +10.0   32.0 ECU.   -5.5 ECU.
02915734  6027  68 165  88  00    00 181 +38.9   34.0 ECU.   -5.5 ECU.
02916134  4789 134 198 182  20    00  39 +13.3   69.0 ECU.   -5.6  48.60
02916534  4741 174 206 185  60    00  46  +9.3   77.0 ECU.   -5.3  48.00
02916934  5065 192 206 186  80    00  55 +10.9   82.0 +23.0  -5.3  46.00
02917334  5265 203 206 184  90    00  54 +15.8   81.0 +23.0  -5.3  46.00
02917734  5265 209 209 187 100    00  53 +15.4   81.0 +23.0  -5.2  43.50
02918134  5350 198 209 188  90    00  54 +15.5   83.0 +23.0  -5.2  43.50
02918534  5437 193 211 186  80    00  54 +15.4   85.0 +23.0  -5.2  43.50
02918934  5621 192 211 186  80    00  53 +15.6   87.0 +23.0  -5.1  42.50
02919334  5518 199 215 187  90    00  55 +15.5   87.0 +23.0  -5.1  42.50
02919734  5727 181 213 186  70    00  55 +16.0   87.0 +23.0  -5.1  42.50
02920134  5817 182 214 186  70    00  53 +16.8   88.0 +24.0  -5.1  42.50
02920534  5931 184 216 187  70    00  55 +17.5   89.0 +25.0  -5.1  42.50
02920934  6172 205 215 187  90    00  54 +17.4   89.0 +25.0  -5.1  42.50
02921334  6127 193 218 187  80    00  54 +18.1   90.0 +25.0  -5.1  42.50
02921734  6161 189 220 188  80    00  55 +18.1   91.0 +25.0  -5.1  42.50
02922134  6373 203 218 188  90    00  55 +20.3   92.0 +25.0  -5.1  42.50
02922534  6385 192 218 187  80    00  54 +20.5   92.0 +25.0  -5.1  42.50
02922934  6337 186 220 188  70    00  56 +20.7   92.0 +25.0  -5.0  42.50
02923334  6600 192 219 187  80    00  55 +20.7   92.0 +25.0  -5.0  42.50
02923734  6561 196 220 187  80    00  55 +20.6   93.0 +25.0  -5.0  42.50
02924134  6680 186 222 164  70    00  55 +20.8   32.0 +25.0  -5.0  42.50
02924534  6265  92  84  25  00    00  78 +10.4   31.0 ECU.   -5.5 ECU.
02924934  5767  68 177 106  00    00 173 +36.0   33.0 ECU.   -5.5 ECU.
02925334  4694 132 192 181  20    00  38 +11.6   64.0 ECU.   -5.3  48.00
02925734  4810 174 203 185  60    00  51  +9.3   77.0 ECU.   -5.6  48.60
02926134  4866 202 205 178  90    00  54  +8.6   79.0 +23.0  -5.3  48.00
02926534  4852 208 204 151 100    00  55  +9.3   78.0 +23.0  -5.3 ECU.
02926934  4938 199 202 115  00    00  55 +10.9   73.0 ECU.   -5.5 ECU.
02927334  4916 190 197 101  00    00  55 +12.4   71.0 ECU.   -5.5 ECU.
02927734  4990 188 204 156  80    00  55 +12.0   72.0 +23.0  -5.3  46.00
02928134  5012 184 202 182  70    00  54 +13.2   72.0 +23.0  -5.3  48.00
02928534  5027 187 203 183  70    00  55 +13.0   75.0 +23.0  -5.3  46.00
02928934  5012 186 204 185  70    00  56 +13.0   76.0 +23.0  -5.3  46.00
02929334  5128 186 205 185  70    00  56 +13.1   80.0 +23.0  -5.3  46.00
02929734  5159 193 206 186  80    00  55 +13.8   79.0 +23.0  -5.3  46.00
02930134  5200 203 206 186  90    00  55 +14.8   80.0 +23.0  -5.3  46.00
02930534  5216 196 208 186  80    00  55 +14.8   81.0 +23.0  -5.2  43.50
02930934  5159 201 209 186  90    00  56 +15.7   82.0 +23.0  -5.2  43.50
02931334  5282 209 209 186 100    00  57 +15.7   83.0 +23.0  -5.2  43.50
02931734  5291 206 210 187  90    00  56 +15.5   83.0 +23.0  -5.2  43.50
02932134  5385 208 209 186 100    00  56 +15.4   83.0 +23.0  -5.2  43.50
02932534  5420 193 211 188  80    00  56 +15.4   84.0 +23.0  -5.2  43.50
02932934  5411 200 211 186  90    00  57 +15.6   84.0 +23.0  -5.2  43.50
02933334  5402 180 211 188  70    00  58 +15.5   84.0 +23.0  -5.2  43.50
02933734  5464 183 214 186  70    00  57 +15.6   85.0 +23.0  -5.1  42.50
02934134  5491 210 214 187 100    00  57 +14.9   87.0 +23.0  -5.1  42.50
02934534  5537 202 213 186  90    00  56 +15.0   87.0 +23.0  -5.1  42.50
02934934  5592 187 214 186  70    00  57 +15.2   88.0 +23.0  -5.1  42.50
02935334  5649 188 214 186  80    00  58 +14.9   88.0 +23.0  -5.1  42.50
02935734  5649 210 212 187 100    00  57 +15.5   87.0 +23.0  -5.1  42.50
02936134  5727 200 215 187  90    00  57 +15.5   88.0 +23.0  -5.1  42.50
02936534  5678 203 214 186  90    00  57 +15.6   89.0 +23.0  -5.1  42.50
02936934  5727 193 214 188  80    00  58 +16.1   89.0 +23.0  -5.1  42.50
02937334  5817 195 218 188  80    00  58 +16.1   88.0 +23.0  -5.1  42.50
02937734  5757 192 214 186  80    00  58 +16.9   88.0 +23.0  -5.1  42.50
02938134  5827 211 217 188 100    00  59 +17.0   89.0 +24.0  -5.1  42.50
02938534  5837 184 216 188  70    00  58 +16.8   90.0 +24.0  -5.1  42.50
02938934  5807 200 216 180  90    00  58 +17.6   51.0 +24.0  -5.1  42.50
02939334  5807 148  93  26  00    00  67 +10.6   28.0 ECU.   -5.5 ECU.
02939734  5518  67 100  26  00    00 124 +10.4   28.0 ECU.   -5.5 ECU.
02940134  4997  66 106  26  00    00 178 +10.6   28.0 ECU.   -5.5 ECU.
02940534  4642  68 106  25  00    00 180 +10.9   28.0 ECU.   -5.5 ECU.
02940934  4187  66 104  25  00    00 179 +10.8   28.0 ECU.   -5.5 ECU.
02941334  4312  64 101  25  00    00 180 +10.8   28.0 ECU.   -5.5 ECU.
02941734  4187  61  97  25  00    00 180 +10.8   28.0 ECU.   -5.5 ECU.
02942134  4115  59  94  25  00    00 180 +10.8   28.0 ECU.   -5.5 ECU.
02942534  4100  58  87  24  00    00 178 +11.0   28.0 ECU.   -5.5 ECU.
02942934  4045  56  87  25  00    00 178 +10.9   28.0 ECU.   -5.5 ECU.
02943334  3968  55  84  26  00    00 178 +11.1   28.0 ECU.   -5.5 ECU.
02943734  3921  58  81  26  00    00 179 +11.2   28.0 ECU.   -5.5 ECU.
File Type: jpg deltalog-af422-tue oct 1 2002 21-06.07.jpg (47.4 KB, 268 views)
Old 10-02-2002, 12:08 AM   #8
DiMensionX
Member#: 23517
Well, the base UTEC run without the DD readout I did is too large to post, oh well. These should keep folks entertained.
Notice the knock on a couple of occasions, it was only bad once with a count of 32... Most runs were very clean. The car is just incredibly fast now. I'm in awe.
Anyway, I was hoping these might help someone and someone might chime in and give me some advice as well.
Let me know if the pic's of the DD are not clear enough, too big, too small, ect...
Thanks,
Shawn
Old 10-02-2002, 02:01 AM   #9
Steppin Razor
Member#: 24035
2002 GGA 5MT
Seal Gray
Yeah, those are sweet. Kepp em coming. Sorry, Ihave no advice to offer but I really want to learn how all this UTEC equipment works. I don't think you are going to be able to post big enough PICs of the delta dash readouts because there is just too much info. There's 2 guys making a site specifically for people that are tuning their own motors with UTECs, Autronics, MOTECs and other what-have-yous. Until that site is up maybe you could get some i-clubbers with available space (you know who you are) to host them for a while. Good luck with the tuning though.
Steppin Razor is offline   Reply With Quote
Old 10-02-2002, 03:06 AM   #10
1SIKWRX4U2NV
Member#: 24358
I miss boost...
Jesus Christ man...that's alot of info! Keep it coming...it's cool to see people who can actually post their info and not keep EVERYTHING a secret.
1SIKWRX4U2NV is offline   Reply With Quote
Old 10-02-2002, 07:43 AM   #11
thejean
Member#: 17763
Great Info!! Couple of observations:
1. Most runs everything seems real good.
2. Mostly, there appears to be a slight timing advance towards redline and is pretty consistent.
3. One run had a consistent decrease in timing towards redline (long high gear pull)? This puzzles me because you have the timing set. Can the ECU still do some of its own compensation with the UTEC?
4. One knock event in all that is not so bad.
JC
thejean is offline   Reply With Quote
Old 10-02-2002, 07:57 AM   #12
Carlo
Member#: 18376
367 WHP!
460 HP at the crank!
Why is the TPS (throttle position sensor) well over 100 in many spots?
Carlo
Carlo is offline   Reply With Quote
Old 10-02-2002, 10:04 AM   #13
nmyeti
Member#: 4980
JC
JC,
The delta dash will report the timing it "thinks" the ECU is running.
The UTEC reports both the timing the ECU would run and the timing it is actually running.
Note that in the correct colum of the utec datalog the timing maxes out at 25 degrees... that's the timing the car is actually running.
-Nathan
nmyeti is offline   Reply With Quote
Old 10-02-2002, 10:38 AM   #14
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
since I only have one serial port on my laptop, I just ordered a USB/serial cable. I'll soon be doing DD/UTEC logs to add here.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 10-02-2002, 11:40 AM   #15
DiMensionX
Member#: 23517
Jorge, if you run at night a cool thing to get is a USB laptop light, I never knew why anyone would buy one but it kicks butt for logging at night.
I don't know why the TPS goes over 100. I also seemed to have cut out the bad knock event of 32 somehow. I'm going to log today and just go for a few WOT serious runs. These were a grab bag of runs.
Also, TheJean, sure enough that was a high gear low speed WOT run. If you notice I got a couple of knock's doing this around 2700-3200 RPMS. I did one in 5th gear from 40mph and EGT's during ALL runs never went over 800 degree's F...
Shawn
Old 10-02-2002, 11:57 AM   #16
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Shawn
Increase your 2k-3k knock threshold by 2 points and try it again. Basically adjust in 2's and you'll eventually find what works good with your car.
I love the knock correction system... in a way.. I'm glad ISR dragged their feet on the J&S for our car...
Jorge (RiftsWRX)
www.ProjectWRX.com
Log from tonight Strng1dah UTEC 8 05-10-2007 12:32 PM
Analyzing logs from tonight... Strng1dah UTEC 9 01-03-2007 11:23 PM
My ECUTEK DeltaDash logs ... Post yours here too!! wayoutwest Engine Management & Tuning 2 01-16-2003 10:00 PM
New UTEC & DeltaDash logs here from tonight 10.2.02 DiMensionX Engine Management & Tuning 30 10-04-2002 09:08 AM
DeltaDash logs of UTEC? desiwrx02 Engine Management & Tuning 5 09-27-2002 09:56 PM
