Old 07-26-2013, 08:36 PM   #1
jzehren11
Member#: 357281
2004 WRX Wagon
Default JDM EJ205 heads on my USDM 205??
So pretty much, long story short.... replacing my head gaskets, and regasketing the the whole motor, and I found the VERY common cracks between the spark plug and the valve seals. Mine are pretty much cracked all the way through though :/
Found a look set of JDM heads with AVCS for $600, no cracks. Only thing is, will everything work out fine if I install them? Yes, I know the AVCS wont work.
Thanks in advance.
Justin
jzehren11 is offline   Reply With Quote
Old 07-27-2013, 03:26 PM   #2
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
I am not sure if its true but I heard our ej205 heads partswise outside of avcs are about the same as ej207 heads but no big ports so you may want to look into that if ur just looking rev it out somewhat more.
Shortpersonbk is offline   Reply With Quote
Old 07-28-2013, 11:27 AM   #3
jzehren11
Member#: 357281
2004 WRX Wagon
bumppp anyone?
Old 07-28-2013, 02:16 PM   #4
rdieder
Member#: 257818
2007 STi
CGM
What ecu are you using? Rumor has it that the Jdm and usdm short blocks are the same
rdieder is offline   Reply With Quote
Old 07-28-2013, 06:30 PM   #5
jzehren11
Member#: 357281
2004 WRX Wagon
I'll be using the usdm harness and ecu.....
I just want to know if the JDM heads will bolt up with no issues and work without issues.....
Old 07-29-2013, 07:43 AM   #6
jzehren11
Member#: 357281
2004 WRX Wagon
Bump...
Old 07-29-2013, 08:43 AM   #7
rdieder
Member#: 257818
2007 STi
CGM
pretty much every motor from 2002+ on this forum has been mixed and matched. These motors are like legos. So it should bolt up together. You'll have to fool around to get it to work, you aren't using the correct ecu for those heads, so don't expect it to work without issues.
Old 07-29-2013, 08:58 AM   #8
jzehren11
Member#: 357281
2004 WRX Wagon
well I dont expect for the AVCS to work... but everything else should correct?
Old 07-29-2013, 12:04 PM   #9
ogboot
Member#: 170906
psm
I'd recommend getting some USDM ej205 heads, i got mine on here cheaper than $300 shipped.
ogboot is offline   Reply With Quote
Old 07-30-2013, 02:38 AM   #10
jzehren11
Member#: 357281
2004 WRX Wagon
see I just dont want to have to deal with having to get them shipped... plus it would be going through military postal service...which has been known to break ****!
Old 07-30-2013, 11:49 AM   #11
jzehren11
Member#: 357281
2004 WRX Wagon
bump??
Old 07-31-2013, 02:01 PM   #12
rdieder
Member#: 257818
2007 STi
CGM
what answer are you looking for? get them and install. Should be no different than deleting avcs as they do on the 2.5 heads
Old 08-01-2013, 03:13 AM   #13
jhayesvw
Member#: 326502
2003 WRX Wagon
I think IA performance sells an easy wiring kit to make the avcs work.
You may want to check into it.
as for mechanically, there is no reason the heads wont work.
jhayesvw is offline   Reply With Quote
