Old 07-27-2013, 11:45 AM   #1
subarufan555
Member#: 255117
2000 RS
RED
Default 04 STI Cant download ROM get error All the time!!!
I have 04 STI It had a Turbo timer Gauges and custom stereo Installed by previous owner.
It had Cobb AP 2 on it I have un Married AP from the car (i made sure it was removed correct Im using it on another STI)
The problem I have I CANT DOWNLOAD THE ROM FROM ECU WITH MY TACTRIC CABLE.....
AS SOON AS I TURN THE IGNITION KEY ON AND CLICK OK BUTTON ON MY LAPTOP I GET ERROR.
Where can i look what cables may have been cut or disconnected as a result i cant put the car in the Mode to download the ROM.
I have the green plugs connected under the dash.....
subarufan555 is offline   Reply With Quote
Old 07-27-2013, 11:50 AM   #2
codesoccer
Member#: 179573
2002 MBP Bugeye
Flip Flop Tuned on corn
Someone else can chime in because I'm not positive about the 04's but I think you need a jumper block as well. It's pretty easy to make one.
codesoccer is offline   Reply With Quote
Old 07-27-2013, 12:52 PM   #3
jthatch12
Member#: 321715
03 Big 16G WRX
Yes you need a jumper block for 02-05. It can easily be made with 2 paper clips. I recommend the paper clips that have a thin plastic coating on them to prevent a short. You'll never have to remove them ever again :-)
jthatch12 is offline   Reply With Quote
Old 07-27-2013, 01:15 PM   #4
SharpTuning
Member#: 333363
Jumper blocks are only used on 02-05 WRX models in the US. All US STi models only require the green flash connectors to be connected, with the exception of newer 07 or 08+ models with CAN which require nothing.
Can you verify the car is actually going into test mode? After connecting the green connectors, cycle the ignition and you should see CEL flashing along with radiator fan cycles and fuel pump cycles.
Are you able to log the car at all?
Also, post the error message.
SharpTuning is offline   Reply With Quote
Old 07-28-2013, 11:01 AM   #5
subarufan555
Member#: 255117
2000 RS
RED
Yes the car is going in to test mode, I verified it.
the only think else i did was check the code with Learning Vie to find it has Running Lean Code...
The car had Remote start installed on it does it matter?
Old 07-28-2013, 02:03 PM   #6
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
Remote start diesnt matter as i have one.
Hook up everything correctly first.
Hit read rom button and then choose your car year type. Then turn the key ON and then hit Okay. When the key is.in the ON position the check eng light should not be flashing.
Also verify your ecu is the stock one. Not one from some other year sti
cosseywrx is offline   Reply With Quote
Old 07-29-2013, 10:59 AM   #7
subarufan555
Member#: 255117
2000 RS
RED
See the ECU number Ends with 500 (I checked with Clear View) I didnt see any thing this low on my Ecu Flash
for 04 STI it shows 515 or some thing and it goes up from there foe 05-07 STI....?
Old 07-29-2013, 11:20 AM   #8
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
What?
The ROM code is not a 3 digit number, it should be something like:
A2ZJ710J
or 700J or 500J. Other years look completely different, for example the 05 is:
A2ZJB11J
And the 07 is:
A2UJ000J
So what, exactly, is this number you're looking at?
