Old 07-27-2013, 03:35 PM   #1
DSM Goat
Member#: 313071
1998 Forester L
Default Piston and Head Damage - Opinions, please
I've an EJ20T w/a VF48 running E85. Stock bottom end, stock heads. Tuned by Clark Turner. Peak boost 22-24 lbs.
Anywhooo...I had a head gasket fail. So I pulled the motor, pulled the heads off, and was preparing to replace the head gaskets with some Cometic units and was also going to run ARP head studs.
So I started cleaning up the mating surface on the right hand cylinder head and noticed this,
Hmm, wasn't expecting to see THAT. Naturally, I wanted to see what the other side (piston/block) looked like...
DSM Goat is offline   Reply With Quote
Old 07-27-2013, 03:37 PM   #2
DSM Goat
Member#: 313071
1998 Forester L
And this is what I found,
Ouch!
Any takers on what happened here? I'd appreciate some thoughtful input. Thanks.
Old 07-27-2013, 04:19 PM   #3
sultanofsubguns
Member#: 351404
02 WRX Wagon
ProbablySomethingMundane
Is that at the bottom of the head/block? It so it may have been a previously damaged spark plug that lost a grounding strap into the head.
sultanofsubguns is offline   Reply With Quote
