Old 07-29-2013, 02:55 AM   #26
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Originally Posted by TheB00T8930 View Post
I have pumas. They're size 13, heel toe is very difficult!
i can do it in steel toe work boots....hiking boots...bare foot....sneakers....
Old 07-29-2013, 09:51 AM   #27
BeefCurtains64
Member#: 251257
12 WRX
He ish be doing heel toe while having the seckx.
BeefCurtains64 is offline   Reply With Quote
Old 07-29-2013, 11:43 AM   #28
TheB00T8930
Member#: 328014
2004 Impreza WRX
I'm sure I could do it with enough practice. It's just not the best size to learn with. Haha
TheB00T8930 is offline   Reply With Quote
Old 07-29-2013, 11:53 AM   #29
Navendra94
Member#: 327495
2012 Impreza WRX 5DR
Plasma Blue
I use my hands. I steer with my forehead though.
Navendra94 is offline   Reply With Quote
Old 07-29-2013, 11:58 AM   #30
TheB00T8930
Member#: 328014
2004 Impreza WRX
Lol^^^
Old 07-29-2013, 12:17 PM   #31
HoboBob
Member#: 253560
'83 Subaru GL Wagon
Easiest way to heel-toe in my old E46 BMW was to brake with your big toe and throttle with your pinkie side of your foot. Little wacky but it worked.
HoboBob is offline   Reply With Quote
Old 07-29-2013, 12:28 PM   #32
dburgoon
Member#: 310366
03 vf37'd WRB
Bugeye
The pedals in the e46 are weird! I had to come up with a weird way of doing it as well in my e46
dburgoon is offline   Reply With Quote
Old 07-29-2013, 01:43 PM   #33
urabuster
Member#: 266578
2003 WRX Sportwagon
Originally Posted by equiraptor View Post
That's still "heel toe". The term for "using three pedals with two feet" is heel & toe, no matter what parts of the foot you use.
What about 2 pedals with 2 feet? I've only ever been able to heel/toe well in go-karts...
urabuster is offline   Reply With Quote
Old 07-29-2013, 02:02 PM   #34
SilverSubaab
Member#: 88288
.... At this point,
even I have lost track.
I heel-toe under my desk all day long at work while I'm on my computer. Yep, I'm that full racecar.....
SilverSubaab is offline   Reply With Quote
Old 07-29-2013, 07:47 PM   #35
1BadP71
Member#: 289883
WRX '03 + '06 WAGON
White and Blue Limited
This.
Try a foxbody with size 13 steel toed boots lol.. I'm going to be moving my mustangs pedals around a bit eventually.
I wanted to get a nice pair of pumas for driving but my nike's do just fine. The older the shoes the better it feels.
1BadP71 is offline   Reply With Quote
Old 07-29-2013, 07:56 PM   #36
lightningdragon
Member#: 42898
2013 Wrx
Plasma Blue Pearl
This is a dieing art, in motorcycles as well as cars. The new corvette has active rev matching, same deal. I think the 370z as well, right?
lightningdragon is offline   Reply With Quote
Old 07-29-2013, 08:36 PM   #37
equiraptor
Member#: 300017
2012 WRX Limited
WR Blue
Yes, the 370Z also has active rev-matching. I found it actually threw me off - it created an unexpected behavior in the car that, on track and in the moment with many things to process, I didn't understand. In an effort to understand, I paused for a moment, and that corner was blown (didn't go off or anything, just didn't do it as effectively as I could have). I adjusted to it for later corners... but would rather not have it. I still need a foot ready for the throttle just in case.
equiraptor is offline   Reply With Quote
Old 07-30-2013, 10:24 AM   #38
johentie
Member#: 363790
i tried a few times, but being 6'4 it's hard ; <
johentie is offline   Reply With Quote
Old 07-30-2013, 04:26 PM   #39
aldsar
Member#: 356438
2013 BRZ Premium 6MT
Dark Grey Metallic
I have size 11 feet, and have no problem turning my whole foot sideways so my heel is on the brakes, and I blip the throttle with my toes. I find it lets me keep better control of both pedals than trying to use the big toe/pinky toe method. Also I drive a BRZ, and my dad has an '07 WRX, my footwell is smaller but my pedals are better set up for it.
aldsar is offline   Reply With Quote
Old 07-30-2013, 04:28 PM   #40
aldsar
Member#: 356438
Dark Grey Metallic
Originally Posted by dburgoon View Post
But the Wrx is a little different because under heavy braking my throttle is actually higher then my brake pedal (I have a very soft pedal for some reason)
look into a grimmspeed master brake cylinder brace, or maybe ss brake lines, both should give you a firmer pedal, the brace is easier and cheaper though.
Old 07-30-2013, 07:11 PM   #41
HoboBob
Member#: 253560
'83 Subaru GL Wagon
Chalking up another one.
In my old MKIV Golf the gas pedal was way lower than the brake and the first time I tried it I ended up slamming the brakes and not even getting near the throttle Took some doing but I eventually got something like heel-toe in that car.
Old 07-31-2013, 09:09 AM   #42
SpamBot
Member#: 287534
Originally Posted by dartdude72 View Post
I've never done the heal toe
I stubbed my big toe on a rock once, and it took about three days to heal. I had to walk on my heel to help it heal.
SpamBot is offline   Reply With Quote
Old 07-31-2013, 01:22 PM   #43
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
It's easier to heel toe when you are threshold braking because the pedal is in a more consistent spot. It's harder (but it'll eventually become easy) when not threshold braking; ie downshifting on the street.
But if you have a manual transmission car, there's no reason why you shouldn't learn to heel-tow rev match. Key being REV MATCH... and not so much emphasis on the heel-toe part. As others have described, whatever it takes to properly rev match using brake and accel with one foot is the important thing.
Here's one tip I found useful: your right foot should be flexed up with toe pointed towards your face, then plant the heel on the floor under the accelerator (not the brake). Using the tilt of your foot at the heel allows you to roll on/off the accelerator. When you want to brake, *keep your heel planted under the accel* and tilt your foot to the left to roll on/off the brakes.
^ this angle over the brake makes the muscle memory in your foot more ready to heel-toe, since it is the angle you'll be doing it with.
chimchimm5 is offline   Reply With Quote
Old 08-27-2013, 05:04 PM   #44
maxplanck
Member#: 255498
Originally Posted by Toombs View Post
Here you go, try to emulate this guy.
In loafers..... legendary.
Awe inspiring stuff. I really ought to learn how to do this. I always rev match on downshifts, but I brake first, then down shift.
I will go practice in my driveway first and make race car noises.
Q: What the heck is Senna doing pumping the throttle near the apex -- induced oversteer?
maxplanck is offline   Reply With Quote
Old 08-27-2013, 10:20 PM   #45
4-n-zics
Member#: 228961
2016 4Runner TRDP
Originally Posted by 69subaru360 View Post
I have this pedal set, it's not pep boys crap, they are functional and fit right. The little extension on the gas pedal lets you hit the throttle with your heel as you brake with your toe. You want to adjust the pedals so that when the brake is applied it's even with the gas at rest.
I know this post is a month old, but where did you get those?
4-n-zics is offline   Reply With Quote
Old 08-27-2013, 10:44 PM   #46
pho_shizzle
Member#: 181064
00' 2.5RS
BRP
From Subaru themselves.............
pho_shizzle is offline   Reply With Quote
Old 08-27-2013, 11:04 PM   #47
rudymcskoody
Member#: 257618
2006 wrx
aspen white
Friend of mine has those in his rs. He loves them
rudymcskoody is offline   Reply With Quote
Old 08-27-2013, 11:13 PM   #48
boczo777
Member#: 305314
2010 STI
BLACK
where can those pedals be bought?
boczo777 is offline   Reply With Quote
Old 08-27-2013, 11:36 PM   #49
equiraptor
Member#: 300017
2012 WRX Limited
WR Blue
It could be throttle on rotation, but it may just be simple weight transfer. An NSX (at least, the ones I've driven) responds really well to that kind of input for weight transfer. What looks like a harsh input actually balances the car very well. Feedback is extremely quick, and reactions are communicated but are small, so that seemingly large input means little, precise movements from the car. Whether it's about power on rotation or about weight transfer, it's little adjustments to get both the right placement on track and the right rotation from the car.
Old 08-27-2013, 11:50 PM   #50
Toombs
Member#: 340935
2001 RS
2013 WRX STi
Source: http://www.sccaforums.com/forums/aft/29667
Here's an explanation from Takeo Kiuchi, Senna's Honda engine engineer 1990-92:
"Normally the corner speed is decided at the entry - by the tyre grip. But Senna used the throttle to change the yaw of the rear tyre, using the engine torque over the limit of tyre grip. He would get yaw change into the car but without letting it become a slide - that's why only short, very quick movements on the throttle."
""The normal technique on corner entry is to keep it as smooth as possible", explains Takeo Kiuchi, Senna's race engineer of 1990-92. "But Ayrton would use the throttle to put more torque through the tyre and change the yaw, a little bit each time. This way he would get a better trajectory before the apex without as much steering. When we did our simulations, usually the actual time a driver set was slightly slower than the simulation;with Ayrton he was always nearly slightly quicker. That was because we couldn't model what he was doing with the throttle and how it affected the car."
Toombs is offline   Reply With Quote
