Old 07-26-2013, 10:04 AM   #1
GRSSHPR1
Member#: 154205
2002 wrx sport wagon
black
Default My boss doesn't believe me
So long story short I work at a shop in ohio and used to own a 2002 wrx and we received one today from a dealership it only has 45000 miles on it and possibly a junkyard motor barely any fuel in it and it has cel of p0102,p0113,p0171 I am extremely convinced that they put 87 in it and that's why there is no power until it reaches about 4500 rpms. He doesn't believe me and wants me to convince him otherwise that the car will run bad on 87 I've told him we need to put 91 in it to check. I made the same mistake with my car when I had it. please help thanks guys
GRSSHPR1 is offline   Reply With Quote
Old 07-26-2013, 10:08 AM   #2
silvercookie
Member#: 180033
2005 WRX
just show him the handbook. All turbo subaru's require 91 at the minimum.
Run the tank down, refill. reset the ecu take it for a gentle 50 mile drive.
silvercookie is offline   Reply With Quote
Old 07-26-2013, 10:09 AM   #3
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Open fuel door
Point to sticker
Walk away
Old 07-26-2013, 10:15 AM   #4
SoapBox
Member#: 204578
S54 E46, N54 E82,
N55 E84, AKA REX8
So you think that 8 octane gas is responsible for no low/mid range power, but yet, the car still makes decent power up top?
If they car was pulling timing, it would be just as bad, if not worse the higher in the rev-range you are.
SoapBox is offline   Reply With Quote
Old 07-26-2013, 10:44 AM   #5
GRSSHPR1
Member#: 154205
black
it's an automatic and wot it's a dog until it reaches higher rpm then it takes off. but we see junkyard marker on the intake which concerns me we're looking for a specifics description of how the ecu realizes what octane is in it. anyone?
Old 07-26-2013, 10:52 AM   #6
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
the ecu doesn't know octane directly, it knows by repetitive knock and adjusts accordingly by pulling timing and lowering the IAM from 16 to OMG its blown.
Old 07-26-2013, 10:59 AM   #7
GRSSHPR1
Member#: 154205
black
ok so I guess the question is will putting a low octane like 87 make it go into somewhat of a limp mode?
Old 07-26-2013, 11:01 AM   #8
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
It will make it run like ****, but mainly at higher rpm, not at lower rpm.
Those codes could mean your MAF is toast/unplugged/has damaged wiring/installed backwards. What direction is the clip on the MAF pointed/do you have a known good one you can swap in?
Old 07-26-2013, 11:04 AM   #9
GRSSHPR1
Member#: 154205
black
ok well i'm getting him to put higher octane in it right now and we'll see if that cures it lol let's hope for me because if i'm right I get a full tank of gas lmao
Old 07-26-2013, 11:27 AM   #10
Psychoreo
Member#: 79643
2015 WRX STI
How exactly does bad gas cause a MAF, IAT, and a fuel trim too lean code?
I'd be looking for pre turbo leaks and faulty maf sensors before I'd be worried about the gas.
Old 07-26-2013, 11:27 AM   #11
Impreza WR Rex
Member#: 40060
2002 EJ207 Bug-STi
Reset the ECU after you fill up and see if the codes come back
Impreza WR Rex is offline   Reply With Quote
Old 07-26-2013, 11:31 AM   #12
cmiovino
Member#: 134005
2004 WRX Premium
I'm 99% sure it's not the octane. If it was a fuel issue (delivery, quality, octane), you'd see more issues in the higher RPMs than lower.
From those codes you give, all three are pointing to the intake area. Looks like there are incorrect A/F ratios down low in 'closed loop' from a MAF issue, leading to it running lean and not having power. Above 3Kish is 'open loop', where things like the front O2 sensor are not contributing to the A/F ratio. I'm not 100% sure if the MAF is contributing here to calculations.
Either way, I'd say it's not an octane or fuel issue at all. Looks to be a bad MAF or front O2 sensor. I'd point more towards the MAF considering the MAF specific code.
Old 07-26-2013, 11:56 AM   #13
GRSSHPR1
Member#: 154205
black
so it made a huge difference of say you were sitting at 50 mph and wot it it takes off like a rocket which it didn't before but it still has what feels like lag off a dead stop. erased codes and none have come back on yet and I reset the ecu by disconnecting the battery and touching the terminals together before I started it with the new gas. which was 93
Old 07-26-2013, 12:09 PM   #14
GRSSHPR1
Member#: 154205
black
the connector is pointed towards the front of the vehicle but I checked that already and it's impossible to mount it backwards lol I see that everywhere but idk how people are doing it.
Old 07-27-2013, 02:31 PM   #15
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
Clean the maf check the wires...I had the same codes after cleaning it and resetting ecu they were gone.
Side note if ur just gassing it from a dead stop and going %100 throttle and your saying its a little slow and Laggy till 3,000 ish rpm that's normal for a automatic sadly.
Shortpersonbk is offline   Reply With Quote
Old 07-27-2013, 07:22 PM   #16
paulpat
Member#: 237145
02 WRX
12 FXT
Yeah some td04 start at around 3k. It depends on many factors. You have some good advice here. Check that stuff too.
paulpat is offline   Reply With Quote
Old 07-27-2013, 07:31 PM   #17
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
it aint the gas......nope
Old 07-28-2013, 02:24 PM   #18
Haelan
Member#: 151045
2013 Subaru STI
CBP
P0113 is intake air temperature circuit high. This is not caused by bad gas. This sensor is integrated in with with the MAF sensor. I'd start there.
Haelan is offline   Reply With Quote
Old 07-28-2013, 05:52 PM   #19
Uncle Scotty
OK buy Nates beans
id start with the connectors to the maf and the ground to the manifold......
it aint the gas
