Old 10-02-2002, 02:23 AM   #1
jatyrx
Member#: 23382
2003 ej207
Question Best Uppipe??
hello everyone!
well, i finally got enough money for an uppipe. i just dont know what to get? can anyone assist me on which upipe to get?
thanks
-jayson
jatyrx is offline   Reply With Quote
Old 10-02-2002, 02:29 AM   #2
wayoutwest
Member#: 14379
2007 Acura
gray
www.vishnutuning.com
dyno's there too. higher grade materials + expansion collars.
wayoutwest is offline   Reply With Quote
Old 10-02-2002, 04:08 AM   #3
subarud
Gone.. But not forgotten
Member#: 9863
02 WRX Blue & Fast
91 S10 Red & Abused
Default uppipe
I am using the vishnu and I agree with tknodav, its a great pipe. I have heard good things about perrin and pde. My 2nd choice if I knew about them earlier would be to get the jdm uppipe which doesn't have the uppipe cat but it looks very similar to the OEM uppipe on usdm wrx. since you live in the bay area check out i-speedusa.com they sell the jdm catless pipes.
~evan
subarud is offline   Reply With Quote
Old 10-02-2002, 01:09 PM   #4
TheMadScientist
Member#: 23717
2005 Big red
Any one with phone# to I-speed?
TheMadScientist is offline   Reply With Quote
Old 10-02-2002, 01:42 PM   #5
Rich10
Member#: 14934
One thing that you should remember about uppipes is that it is a fairly simple piece. It is a piece of bent tubing with a flange at each end and (in most cases) a bung for the EGT sensor. The only problem that people have really had with uppipes is leaks. These leaks seem to be related to bad installations, not the brand of uppipe that was used. I see alot of people saying that you need expansion collars and/or a flex joint, but from what I have read, they all work about the same. My advise would be that whatever uppipe you get, make sure that you install it correctly OR get help to make sure that it is installed correctly.
Rich
Rich10 is offline   Reply With Quote
Old 10-02-2002, 01:48 PM   #6
pehavens
Member#: 11821
Default jdm uppipe
anybody know why the jdm uppipe has the section on it that looks like a cat??? What would be the purpose of this if there is really nothing in there? What does the JDM uppipe look like on the inside?
-peter
pehavens is offline   Reply With Quote
Old 10-02-2002, 03:12 PM   #7
Corn-Picker
Member#: 8679
2010 The most hated
vehicle on the internets
Default Re: jdm uppipe
-peter
I think you may be refering to the "flex joint", the corrugated metal piece in the center of the pipe. This flex joint allows the uppie to flex when the engine moves, as it does during the course of normal operation.
Corn-Picker is offline   Reply With Quote
Old 10-02-2002, 04:34 PM   #8
jmaiken
Member#: 8506
04 Forester XT
Black -VF39, STi tmic etc
I am happy with my turbo xs uppipe. I like the fact that it is cast iron and is not noticeably louder than the factory setup.
jmaiken is offline   Reply With Quote
Old 10-02-2002, 06:34 PM   #9
jatyrx
Member#: 23382
2003 ej207
Thansk everyone for your help
-jayson
Old 10-02-2002, 08:58 PM   #10
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
i kinda like my stock uppipe with a gutted cat....
-mike
MJU1983 is offline   Reply With Quote
Old 10-03-2002, 12:14 AM   #11
Rattler
Member#: 6351
2004 Tacoma 2xCab
\m/ \m/
I got a Perrin. I used new gaskets also. I had a loose bolt that leaked but that was our fault when we installed it. No problems since.
There was a thread that was surveying uppipe-owners somewhere too.
Rattler is offline   Reply With Quote
Best uppipe installation Instructions. tuca33 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-14-2003 12:31 AM
Best Uppipe/Downpipe/Exhaust setup? Kickz107 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 10-18-2002 01:33 PM
Best Uppipe/downpipe to bolt up to HKS Exhaust? Big R Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-11-2002 10:37 PM
Best Uppipe? guitboymc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 07-15-2002 07:23 PM
Best uppipe Gadiel Puerto Rico Impreza Club Forum -- PRSIC 15 06-07-2002 04:31 PM
