Old 07-29-2013, 09:52 AM   #1
Limasubaru
Member#: 336182
2002 Subaru WRX
Aqua Pearl Metallic
Default Help: car runs like crap after intake install
Just installed some eBay intake and now my car barely runs and barely stalls. Stutters when you start to drive. I have BOV installed to.. I reset my ecu and still sounds like crap. Any suggestions?
Limasubaru is offline   Reply With Quote
Old 07-29-2013, 09:54 AM   #2
dirtcollector
Member#: 357347
2005 wrx sti
aspen white
Take it off and put your stock one back on that will not work without a tune
dirtcollector is offline   Reply With Quote
Old 07-29-2013, 09:55 AM   #3
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
Go back to stock airbox and ditch the BOV.
nmlittlebigman is offline   Reply With Quote
Old 07-29-2013, 09:57 AM   #4
SouthernWRX
Member#: 321571
2012 WRX Base
Ice Silver
You need a tune when you upgrade your intake. I'd baby her until you get the stock intake back on there.
SouthernWRX is offline   Reply With Quote
Old 07-29-2013, 10:05 AM   #5
cmiovino
Member#: 134005
2004 WRX Premium
At first, I actually wanted to call "troll" on this one. I don't think that's the case however.
Go back to your stock intake. The only intakes I'd run without a tune would be the Cobb SF or SPT for the 2002. A random eBay ones is bad. Not to mention, who knows the filtering properties.
Also, ditch the BOV. The stock one is just fine.
I'd highly suggest more reading before spending more money. You'll thank me later for saving money on mods and a new engine if you continue down this path
Good luck!
Old 07-29-2013, 10:19 AM   #6
Limasubaru
Member#: 336182
2002 Subaru WRX
Aqua Pearl Metallic
Not to sound like an idiot but I am, could the map sensor effect it in anyway? I tried to get it on all the way but it just wouldn't sit in the hole so I just screwed it on as far as it would go and didn't seem like there was any gaps I could see....
Old 07-29-2013, 10:35 AM   #7
Cocoa Beach Bum
Member#: 17355
You are probably talking about the Mass Air Flow (MAF) sensor and it is probably your problem. You can quickly confirm that by disconnecting its wiring from the engine bay wiring harness. If the car runs fine, then you've installed your MAF sensor backwards. MAF sensor installation is counter-intuitive because its wires should be pointing to the front of the car even though its wiring harness connector is in the opposite direction.
Cocoa Beach Bum is offline   Reply With Quote
Old 07-29-2013, 10:36 AM   #8
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
So the MAF sensor isn't even installed correctly? That's a problem.
Ebay intake? Also a problem.
BOV? Problem.
Contrary to others, using an intake on an 02/03 without a tune isn't entirely a problem.
Resetting the ECU doesn't help anything, and will now take longer to learn parameters.
Old 07-29-2013, 10:41 AM   #9
Limasubaru
Member#: 336182
2002 Subaru WRX
Aqua Pearl Metallic
The MAF sensor is pointing forward... Does it make a difference if it's not sitting right? If I disconnect it, won't it not do anything different to how the car runs?
Old 07-29-2013, 10:48 AM   #10
atech34
Member#: 304389
2013 WRX Hatch
ISM
I may be wrong but if you disconnect the maf and it runs better it is because the ecu has preset parameters instead of getting interpreted air data from the maf for finer a/f mixtures.
atech34 is offline   Reply With Quote
Old 07-29-2013, 10:59 AM   #11
Napalm3nema
Member#: 263954
2014 EVO X / 05 WRX
Wicked White / Blue
Everyone is giving you great advice, time to start following it!
Remove the Ebay intake, and BOV if you can. Your car will thank you for it.
Napalm3nema is offline   Reply With Quote
Old 07-29-2013, 10:59 AM   #12
Limasubaru
Member#: 336182
2002 Subaru WRX
Aqua Pearl Metallic
I'll try it when I get back home from my oral sergeon appointment and see if it makes a difference.
Old 07-29-2013, 01:32 PM   #13
Limasubaru
Member#: 336182
2002 Subaru WRX
Aqua Pearl Metallic
Unplugged the MAF sensor and started it up and ran perfectly fine. I think it's just not sealed right.
Old 07-29-2013, 01:39 PM   #14
bugeye829
Member#: 81995
2008 Impreza
02 WRX 247k RIP
so much fail here. please be nice to your car and don't install ebay intakes. also ditch the bov and re-install the maf sensor correctly. what the hell is wrong with people?
bugeye829 is offline   Reply With Quote
Old 07-29-2013, 01:40 PM   #15
DansSpace
Member#: 157029
'13 Mazdaspeed3
I put the reasons why your car runs bad in bold.
DansSpace is offline   Reply With Quote
Old 07-29-2013, 04:40 PM   #16
eNx
Member#: 268580
Waiting for the blow-up mod
eNx is offline   Reply With Quote
Old 07-29-2013, 05:00 PM   #17
08legacy207
Member#: 362577
Subscribed for the neon undercarriage lighting to come.
08legacy207 is offline   Reply With Quote
Old 07-29-2013, 05:04 PM   #18
02bugeyed
Member#: 248761
2011 Civic Si
Sell your car and buy a Honda, you can slap the finest eBay finds on them and still run it like a champ.
02bugeyed is offline   Reply With Quote
Old 07-29-2013, 05:07 PM   #19
Mike05wrx
Member#: 314747
2005 WRX
ditch the crappy eBay intake and take the bov off too. you need a tune for both of those, unless it's a cobb or spt intake
Mike05wrx is offline   Reply With Quote
Old 07-29-2013, 06:12 PM   #20
Wireeater
Member#: 76503
2015 WRX
I bet it has one of these on the side of the fender too.
Wireeater is offline   Reply With Quote
Old 07-29-2013, 06:20 PM   #21
turbo_dreams
Member#: 348721
eBay intake
Most of the problem is right here.
turbo_dreams is offline   Reply With Quote
Old 07-29-2013, 09:41 PM   #22
cbr600f3
Member#: 55067
2015 Audi S3
Monsoon Gray
Damn you just did two things that will blow up a Subaru turbo
Put stock intake and bpv on and call it a day.
cbr600f3 is offline   Reply With Quote
Old 07-29-2013, 10:14 PM   #23
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
unplugging the MAF doesn't solve the issue of altered airflow due to intake changes. On a stock car the stock ecu can deal with an unplugged MAF. On a car with breathing mods, unplugging the MAF and saying "hey it runs great" will end in one of my favorite Saabrally.com sayings:
"It sounded terrible, then the (engine) noise stopped, and so do the moving (of the car)"
aerosaaber is offline   Reply With Quote
Old 07-30-2013, 01:57 AM   #24
Limasubaru
Member#: 336182
2002 Subaru WRX
Aqua Pearl Metallic
You guys can all **** off. I figured the **** out myself and the car runs perfectly fine now. My car and I can do what I want to it. If I want I WILL BLOW UP MY ****ING TURBO. I don't care. I'm ****ing 17 owning my own wrx for a first car that I built from a parts car and all you ****ers probably had some ****ty 120hp 3 cylinder garbage cans.
Old 07-30-2013, 02:09 AM   #25
p951951951t
Member#: 276541
1972 Alfa Romeo GTV
Alfa Rosso
Come at me bro!
p951951951t is offline   Reply With Quote
