Old 10-02-2002, 01:19 PM   #1
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
Default UTEC ground strap question
ok, got mine today... but I have an installation question.
"fit the black GROUND LINK from the UTEC to a good ground on the car. We suggest bolting the lead to the mounting bolt of the passenger seat".
Thats all well and good.. but where do you mount the ground link on the UTEC? Its a seperate wire, is there anyplace particular you are supposed to mount it? HELP! I have my new toy and I can't play with it! (
DarthChicken is offline   Reply With Quote
Old 10-02-2002, 02:37 PM   #2
paul99se
Member#: 17822
On the end of the UTEC with the red switch, there is a white screw-down recepticle for the forked end of the ground strap.
There is a hole in the black circuit board cover that will allow access (with a small screwdriver) so that you can tighten the frok connection down with two screws.
I stared at it for a bit as well... I was workin in low light and didn't see the hole in the black cover.
I grounded the UTEC to the lower ECU mount stud and seem to have a satisfactory ground there so far.
-Paul
paul99se is offline   Reply With Quote
Old 10-02-2002, 03:04 PM   #3
codean
Member#: 10186
When did you order your utec? I'm still waiting for mine and not knowing when it i'll get is driving me nuts!
codean is offline   Reply With Quote
Grounding strap mod?? BALISTC Newbies & FAQs 2 09-12-2002 11:41 AM
Where to buy a JDM grounding strap? BADWRX Bay Area Impreza Club Forum -- BAIC 13 07-02-2002 02:02 PM
Ground Straps EvasionOfTruth Mid Atlantic Impreza Club -- MAIC 31 04-17-2002 12:01 AM
OK So I check under all the grounding straps and!! Wheels New England Impreza Club Forum -- NESIC 52 03-24-2002 02:34 PM
