Old 09-14-2008, 11:09 AM   #1
ismegamanthere
Member#: 156167
2015 WRX Limited
Lightning Red
Default What kind of 1/4 mile times are you putting down with your 2.0?
Stock, modified, whatever. I'm hoping to take my car to the track before it starts getting REALLY cold out now that my VF34 swap is done. I'm hoping that high 12s are possible.
ismegamanthere is offline   Reply With Quote
Old 09-14-2008, 11:43 AM   #2
SideWay
Member#: 148497
04 Stage II WRX
Java Black Pearl
I ran a 14.6 bone stock and I ran a 13.6 after a TBE and Cobbs stage II 94 map.
SideWay is offline   Reply With Quote
Old 09-14-2008, 11:44 AM   #3
vtec4life
Member#: 174344
or 12 mins when your tranny blows.
vtec4life is offline   Reply With Quote
Old 09-14-2008, 11:53 AM   #4
djoye
Member#: 50072
2003 WRX
[email protected] 20psi
<--- 205 with bolt-ons
djoye is offline   Reply With Quote
Old 09-14-2008, 12:47 PM   #5
jack klompus
Member#: 152885
2014 Malibu LTZ
It depends on how hard you want to launch.
jack klompus is offline   Reply With Quote
Old 09-14-2008, 12:59 PM   #6
MS WRX
Member#: 117780
2004 WRX
This is accurate. add a VF34 and 13.0's are possible
MS WRX is offline   Reply With Quote
Old 09-14-2008, 01:00 PM   #7
Kaldar142
Member#: 151090
S197 boosted V8 FTW
i did 13.0s on stage 2...
Kaldar142 is offline   Reply With Quote
Old 09-14-2008, 01:03 PM   #8
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
high 12s should be possible with any VF..
high 12s are possible on the pea shooter td04
mxpunk is offline   Reply With Quote
Old 09-14-2008, 01:06 PM   #9
Str8Gone
Member#: 147972
2004 wrx hybrid 18g
[email protected] dd
best trap 104.3, best et 12.9 with stage 2, a mbc and ppg 1-4 helical synchro + numerous bolt ons. No tune as well, cobb stg 2 map. mbc makes a world of difference.
Str8Gone is offline   Reply With Quote
Old 09-14-2008, 02:33 PM   #10
rallyrab
Member#: 145844
fp green with 350 whp, on completely stock drivetrain got me 12.3 at 110, that was with my brother and my 15 inch sub in the back, i bet i could do 11's, anyone know the record for the fastest time on the 02,03 weak trannys?
rallyrab is offline   Reply With Quote
Old 09-14-2008, 02:38 PM   #11
SideWay
Member#: 148497
04 Stage II WRX
Java Black Pearl
Mind you my times are all with around 2.0 - 1.9 60' times. I'm a terrible drag racer, I go to get an idea of my power levels, but im sure I could do much better if I made an effort to perfect my launches.
Old 09-14-2008, 02:56 PM   #12
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
Coolrex's wrx ran a 11.7 on the stock ej205 motor/drive train
he has an ecutek tune w/ an 18g and meth i believe
Old 09-14-2008, 06:36 PM   #13
69subaru360
Member#: 159682
1995 WRX
2015 F150
I went a 13.2 on the stock td04.
I just went a crappy 13.0 with a 16G. I made the mistake of putting a light flywheel in that killed my 60 foot times. I put a stock flywheel back in and with my 60 foot times back to the 1.7's it used to run I expect at least 12.50's probably low 12's in the cooler weather.
Old 09-14-2008, 06:40 PM   #14
matty50racer
Member#: 166668
[email protected]
13.1 with stock TD04, stock cat-back, and stock TMIC on 93 octane. I tuned it myself using ecuflash and a MBC. This was only my secod time to the track with this car. I'm sure it will go 12's with a little more tuning, practice, and cool air.
matty50racer is offline   Reply With Quote
Old 09-14-2008, 06:51 PM   #15
Effex Unlimited
Member#: 114562
2013 STI Hatch
Crystal Black Silica
13.8xx with the td04 stg 2 tune. not sure with my vf39, i haven't had a night off to go to the track for t&t night.
Effex Unlimited is offline   Reply With Quote
Old 09-14-2008, 08:15 PM   #16
Farnk
Member#: 91093
2002 Wrx
I got a 12.7 with a vf34. That was on my old tune tho, since i have gotten a mbc/new tune/2 more psi.
Farnk is offline   Reply With Quote
Old 09-14-2008, 09:51 PM   #17
ismegamanthere
Member#: 156167
2015 WRX Limited
Lightning Red
Are most of you running stock trannies? It seems as though 04/05+ WRX owners have much better luck with their 5-speeds than 02-03 WRX owners.
Old 09-14-2008, 10:34 PM   #18
matty50racer
Member#: 166668
[email protected]
I installed LGT 1-2 gears and 03+ 3-4 shortly after I bought the car because I shifted it just like the Mustangs that I've owned. I've learned how to shift and launch much smoother with this car using the clutch instead of brute force and always lifting between shifts now. I have about 8,000 miles of abuse on this transmission and knock on wood I haven't had any more problems.
Old 09-14-2008, 10:39 PM   #19
69subaru360
Member#: 159682
1995 WRX
2015 F150
I have the stock trans with 115,000 miles on it. I did finally wear out the original stock clutch last month and got an exedy stage 1. The trans doesn't like to downshift into first much, it never has since I got the car. I launch the car off LC at 5500. I'll probably break it now...
Old 09-14-2008, 11:26 PM   #20
ismegamanthere
Member#: 156167
2015 WRX Limited
Lightning Red
How much were the LGT 1+2? I'm considering doing Mfactory gears next summer or just do an LGT 1+2 if it's reliable enough.
Old 09-15-2008, 12:48 AM   #21
Effex Unlimited
Member#: 114562
2013 STI Hatch
stock 5spd
Old 09-15-2008, 01:57 AM   #22
GeneralTJI
Member#: 152680
I'm shooting for a high 11 come early November... but will probably end up with a low 12.... and that's at 4900ft elevation Stock block 205 with 167k miles!! I pray it holds together a while longer!
GeneralTJI is offline   Reply With Quote
Old 09-15-2008, 02:12 AM   #23
GeneralTJI
Member#: 152680
Double post
Old 09-15-2008, 03:04 AM   #24
Clark Turner
Member#: 178047
02 WRX STI Spec C
02 WRX during the late 02 to late 03, I dragged alot.
stock 15.6. I sucked.
Boost controler and Cat back 14.2.
Lots of practice 13.5 around 99mph
VF22,pinks, tune, 13.0
Lots of practice - 12.8.
PE1820 turbo, new tune, downpipe, upipe 12.50s
50 shot of nitrous. Wet kit. One up nitruos jet, one down fuel jet. 11.80s
The old rule of 11.99 and faster with no cage, got me booted off the track.
Pulled motor and installed JDM EJ207 and then 2.5 ltr. ect ect ect... 6 years later....
clark
Clark Turner is offline   Reply With Quote
Old 09-15-2008, 01:30 PM   #25
matty50racer
Member#: 166668
[email protected]
I think I paid around 900 for the parts from Fred Beans Subaru. That included all new synchros. and new 3-4 gears.
FS: NoVA: Samco Radiator Hoses in Black and 4 No Tear Clamps for 02-07 WRX / STi. adjasont Engine/Power/Exhaust 5 11-27-2011 03:06 PM
Visual speed estimates by police are guesses with no formula, just practice, to guide AVANTI R5 Non-Subaru News & Rumors 56 09-21-2011 07:30 AM
FS/FT : 5x100 17x7+48 PIAA Sportmesh wheels with tires soob836 NWIC Private Classifieds 23 09-13-2010 02:39 AM
2.2 heads on a 2.0 block chong74 Subaru Conversions 24 06-06-2010 03:41 AM
If you could...would you? I25 Off-Topic 83 06-04-2010 02:48 PM
