Old 08-02-2013, 08:15 AM   #1
Evans609
Member#: 334639
12 ISM STI
10 OB Ralliart
Default Brandon's 2012 STi Build Vollkommen Design WB/Air Suspension/Turbo/Work Wheels
Hey everyone, I figured I'd start a thread seeing I have a few things done and plan on doing a lot of things to my car. So here goes...
Previous cars:
1999 Buick Century
2001 Chevy Cavalier
2004 Olds Alero
2004 Nissan Sentra (first std)
2006 Mazda 6 GT
2011 Hyundai Genesis 2.0T
Winter Beater/Daily cars while owning my STI
2003 Volvo S40
2004 Chrysler Sebring
2010 Mitsubishi Ralliart (current daily car)
My current mod list
Engine/Power:
CP 99.5mm/ 8.2 comp forged pistons
Invidia divorced wastegate/catless
Invidia Q300 Cat-Back exhaust
Agency Power UEL Header
Agency Power Uppipe
Perrin BPV
Perrin pulley and rad cover
Cusco Catch Can
Tomei Turbo Inlet Pipe (2.4")
Cobb SF intake & Box (Blue Piping)
Grimmspeed ERCS
Grimmspeed Intercooler Y-Pipe kit
Competition Clutch Stage 2
Motul Gear Oil
DW65c Fuel Pump
Interior/Exterior:
HT Autos front lip, side skirts, rear lip and exhaust garnishes
OEM JDM rain guards
SMY gauge cluster
15% tint in back
Password JDM fasteners
STI Carbon-Fibre valve caps
Rally Armour Mudflaps (Black with Silver lettering)
Anarchy Motive Shift Knob (White)
Pioneer Headunit
Drivetrain/Transmission:
Kartboy Short Shifter
Kartboy front and rear shifter bushings
Suspension:
BC Br Coilovers
Brakes/wheels:
Muteki Lug Nuts
BF Goodwrich GForce Sport Comp 2s in 245
Here is how it sits now..
On order:
Perrin Fuel Pressure Regulator
Grimmspeed Gaskets
Killer B Hardened Steel Studs
Injector O-Rings
Subaru OEM Turbo Bolts
Rays Gram Lighst 57dr 18x9.5 +38
Waiting to install:
Tomei Fuel Pressure Gauge
Grimmspeed Ceramic coated ewg uppipe with a 38mm (Red) wastegate
Tomei UEL header (Wrapped)
Zerolift TGV deletes
Deatsch Werks 1000cc ev14 injectors.
Perrin License plate delete
Perrin 3inch shorty antenna
Perrin EBCS cover (Red)
Grimmspeed Universal IWG bracket
PTP Turbo blanket (Blue)
Mishimoto Rad Stays (Blue)
Whiteline Rear Differential power front kit
Whiteline Steering Rack bushings
Tail light overlays for blinker
Red pin strip for front grill
FP Green HTA turbo (Ported and Ceramic coated)
AVCS oil lines
Soon to come: (End of Summer or Over Winter)
Possibly Turbo Upgrade
Evans609 is offline   Reply With Quote
Old 08-02-2013, 08:21 AM   #2
Evans609
Member#: 334639
12 ISM STI
10 OB Ralliart
So lets start from the beginning.. I will be updating slowly from the start
Old 08-02-2013, 08:29 AM   #3
Evans609
Member#: 334639
12 ISM STI
10 OB Ralliart
First thing I ordered when I hit 7000km was Nameless performance muffler deletes and a K&N short ram. The intake in my opinion is not great. It sucks in too much air. The mufflers are pretty good. Nice sound but lots of drone. Not my pics but they are pretty much the same \/
Old 08-02-2013, 08:32 AM   #4
Evans609
Member#: 334639
12 ISM STI
10 OB Ralliart
Once that came I had a off the shelf map (Stage 1) from Perrin with at that point my new Cobb V2 access port and a Perrin recir by pass valve.
Old 08-02-2013, 08:41 AM   #5
Evans609
Member#: 334639
12 ISM STI
10 OB Ralliart
I was running Cobb Stage 1 for a little while and then I decided I wanted more power. So I was talking to my tuner and he recommended that I get a Catless Invidia Downpipe. Once I got that I took off this piece of garbage \/
And put on this beauty \/
I got that tuned up and got 267whp and 290wtq on 91 Octane
Old 08-02-2013, 08:46 AM   #6
Evans609
Member#: 334639
12 ISM STI
10 OB Ralliart
The following day I picked my little brother up and we went out for something to eat. While I was parked I noticed my car let out a weird shake.. So I quickly turned the car off. Fearing it was the common issue with sti (blown ring land) I called my tuner. He told
Me to do a couple tests and see what the Cobb AP was saying. It was reading a misfire on cylinder 4. He told me to bring it in the next day. When I brought it in he begun to do a compression test. She was reading 52psi on cylinder 4 when I do believe it supposed to be around 130psi. He told me my ring land was gone. Seeing at this point it was almost time for snow I put the car away for winter. (We still use salt in Newfoundland so I will not drive my sti in that dirt)
Old 08-02-2013, 09:35 AM   #7
Evans609
Member#: 334639
12 ISM STI
10 OB Ralliart
When I took it out the following April I brought it to my tuner. The car at this point only had a little over 13,000km on the engine. We started to scrap it...
Tied up and pulling the engine \/
Old 08-02-2013, 09:46 AM   #8
Evans609
Member#: 334639
12 ISM STI
10 OB Ralliart
Engine out! \/
She's pretty empty in there at this point
Engine with the cam gears and intake manifold off \/
Old 08-02-2013, 09:50 AM   #9
Evans609
Member#: 334639
12 ISM STI
10 OB Ralliart
All the parts off \/
This is what it looks like with all that off
Old 08-02-2013, 09:55 AM   #10
Evans609
Member#: 334639
12 ISM STI
10 OB Ralliart
This is the cracked ring land \/
And these are the new baby's that went in \/
These are the new CP forged pistons put back in the block \/
Old 08-02-2013, 09:58 AM   #11
Evans609
Member#: 334639
12 ISM STI
10 OB Ralliart
Going back in the engine bay!\/
And she's back in
My tuner took the engine out on a Thursday, taking his time (2 hrs) and Friday he started at 3pm and at 3am the next day or morning however you want to look at it I was on my way home. It was a pretty nervous drive home.
Old 08-02-2013, 10:13 AM   #12
Evans609
Member#: 334639
12 ISM STI
10 OB Ralliart
Next I ordered a HT autos front lip, side skirts, rear lip and exhaust garnishes. And took my car to my buddy's garage.
Getting ready to install \/
After install, exhaust garnishes arent on in these pictures
Old 08-02-2013, 10:30 AM   #13
Evans609
Member#: 334639
12 ISM STI
10 OB Ralliart
Next I ordered: OEM rain guards
Blox shifter knob
Kartboy short shifter and bushings
Proto Cobb AP holder
When they arrived
During install
Comparison of stock shifter and kartboy shifter
After install
Install was fairly easy. It's best to jack the transmission up when putting on the bushings. The shifter itself is straight pretty forward
Old 08-02-2013, 10:37 AM   #14
Evans609
Member#: 334639
12 ISM STI
10 OB Ralliart
Next was the mudflaps.
Taking the tires off for easy access
The beautiful sti brakes lol
After install.. Pic isn't that great
Old 08-02-2013, 10:45 AM   #15
Evans609
Member#: 334639
12 ISM STI
10 OB Ralliart
Next I ordered a SMY gauge cluster with prosport boost/vac and AEM AFR
When I got my gauges
Installed
Old 08-02-2013, 10:53 AM   #16
Evans609
Member#: 334639
12 ISM STI
10 OB Ralliart
Next I got OBX header (which is garbage). Fitment of this header was horrible. The gaskets was like using toilet paper. The studs that for the up-pipe to turbo where way to long and protruded into the turbo so I had to sand down the studs. It rusted fairly quickly and the up-pipe ended up being away from the header by a half an inch.
And not long after that I ordered Perrin rad and pulley covers
Before
After
the front lip looks wavy cause i have water on the lens
Old 08-02-2013, 10:57 AM   #17
Evans609
Member#: 334639
12 ISM STI
10 OB Ralliart
I have a tint and hopefully vinyl work scheduled for next week if the vinyl comes in. I also have a Tomei fuel pressure regulator and gauge on the way (well soon, regulator is on back order till September), cusco catch can and hella super tone horns. The current tune has 272whp and 317wtq on 91 octane
This is how she is sitting..
Old 08-02-2013, 11:11 AM   #18
Aralliius
Member#: 209016
looks good, the sideskirt looks wavey tho
Aralliius is offline   Reply With Quote
Old 08-02-2013, 11:23 AM   #19
Evans609
Member#: 334639
12 ISM STI
10 OB Ralliart
I noticed that not too long ago.. ill have to change it at some point.
Old 08-04-2013, 06:23 PM   #20
VEGAS WRX
Member#: 362867
2013 WRX
How accurate is your boost gauage? I have heard conflicting opinions on here?
VEGAS WRX is offline   Reply With Quote
Old 08-04-2013, 07:39 PM   #21
Evans609
Member#: 334639
12 ISM STI
10 OB Ralliart
I find it very accurate. If I had my time back I would of went digital. Prob the prosport evo gauge
Old 08-06-2013, 09:25 PM   #22
Evans609
Member#: 334639
12 ISM STI
10 OB Ralliart
Then i waxed and De-badged it today
Getting ready to de-badge
De-badging complete
Old 08-06-2013, 09:43 PM   #23
KIMUTAKU
Member#: 19776
2012 GVF SWP
Ninja Lime Green
nice build so far!
so how long were you in stage 2 before it went ka-boom?
KIMUTAKU is offline   Reply With Quote
Old 08-07-2013, 03:35 AM   #24
Evans609
Member#: 334639
12 ISM STI
10 OB Ralliart
Originally Posted by KIMUTAKU View Post
nice build so far!
Thanks! I got about 2 days lol when I was getting the stage 2 done my tuner said that one of my cylinders was getting low compression. I said if they went then I can just put something better in it.
Old 08-07-2013, 09:58 AM   #25
VEGAS WRX
Member#: 362867
2013 WRX
Debage looks so much cleaner. I might do it!
