South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 08-28-2013, 10:15 PM   #51
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Originally Posted by yman View Post
Was a bad coil pack. Running a lot better now, but could probably use a tune. Compression was good though so I haven't blown up Ken's old motor yet.
Pm me about a tune if you want
blkscooby is offline   Reply With Quote
Old 09-17-2013, 08:19 PM   #52
bapaul
Member#: 147708
Carbon Panda
Any updates, Andrew?
bapaul is offline   Reply With Quote
Old 09-17-2013, 10:47 PM   #53
yman
Member#: 199051
04 sti
psm
So I think the oil pickup tube cracked in the STI. Oil light is on or flickering at low RPMs, getting some noise. Praying that no metal shavings got sucked up into the engine and that I can replace it in the driveway.
yman is offline   Reply With Quote
Old 09-19-2013, 02:02 PM   #54
yman
Member#: 199051
04 sti
psm
I'm really hoping this isn't a blown motor this time. I heard a little bit of noise on and off, starting with a whirring here and there and then what sounded like a bit of occasional (for a couple seconds) knocking but it cleared up each time as I slowly drove the >1 mile back to my house the other night. The CEL illuminated but didn't flash and I figured it was my old P0457 code but when I went to double check today it showed
P0011, P0021, and P0457. Car sounded fine when I parked it, haven't started it since Tuesday. New pickup tube will be here tomorrow so I'll probably drop the pan today or tomorrow and see what's up. Really starting to freak out a bit though.
Old 09-19-2013, 06:07 PM   #55
Steye05
Member#: 197008
2012 Golf R
Dark Black Metallic
Ah man what the heck is up with this car
Steye05 is offline   Reply With Quote
Old 09-20-2013, 03:38 AM   #56
yman
Member#: 199051
04 sti
psm
having some serious strife trying to remove this oil pan. all the bolts are off but this bastard is stuck.
Old 09-22-2013, 04:18 PM   #57
yman
Member#: 199051
04 sti
psm
argh. if anyone wants to help me finish it out today and learn a little bit about doing this yourself let me know. it's in the reassembly stage but slipping the pan over the tube is a real pain the arse.
Old 09-23-2013, 12:43 AM   #58
diponyou
Member#: 361653
2002 wrx sedan
matte gun metal
Damn dude im sorry to hear this. Im always weary when it comes to buying a built motor now. Have had a few bad experiences.
Hoping that its just something stupid.
diponyou is offline   Reply With Quote
Old 09-23-2013, 11:44 AM   #59
yman
Member#: 199051
04 sti
psm
The motor itself was fine, it's the fact that the pickup tube was a stocker and they are a weak point in the EJ motors.Anyways, I'll find out soon if the seal held and if I fixed the problem, I'll let y'all know.
Also, while I was under there I changed the trans fluid with Amsoil Severe Gear. If this doesn't fix my synchro issue then I'll need to rebuild the transmission too. Good times.
Old 09-23-2013, 02:38 PM   #60
yman
Member#: 199051
04 sti
psm
No apparent leaks. Oil light is not on. Now I'm just hoping I never have to pull the oil pan ever again. That thing is a bastard.
Old 09-23-2013, 04:19 PM   #61
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
I found severe gear to be trash. My box shifted far worse with it. I went to Motul and it was much better.
Was there a crack on the tube?
Old 09-23-2013, 08:56 PM   #62
yman
Member#: 199051
04 sti
psm
I couldn't see a crack prior to replacing it since the tube broke when I pulled the pan down. It had to have been cracked though since I wasn't pulling that hard, and it broke in exactly the same place as everybody else's.
I'm trying it even though it had fresh Subaru Extra S in it. Trans was being bitey into 3rd and 5th and so I'll probably try Motul or the cocktail next and then just tear it down and rebuild.
Old 09-24-2013, 10:21 AM   #63
blkscooby
Member#: 44422
2009 G8 GT
I've had great success with Severe Gear. However, no fluid change will fix worn synchros. And please don't use cocktail, no no.
Old 09-24-2013, 02:19 PM   #64
yman
Member#: 199051
04 sti
psm
It's not really a true cocktail, it's just half motul/half amsoil 75W90.
Old 09-24-2013, 10:48 PM   #65
jhayesvw
Member#: 326502
2003 WRX Wagon
I replaced my 2.0 wrx oilpan and pickup with an STI pan and Killer Bees pickup.
The whole thing wasnt too hard. Just time consuming. I did it all myself in about 4 hours on the floor of my garage.
I hope you caught it in time. Those pickups scare me which is why I put the Killer Bees one in.
jhayesvw is offline   Reply With Quote
Old 09-25-2013, 01:23 AM   #66
yman
Member#: 199051
04 sti
psm
Drove it to Tempe and back tonight, seems fine. Heard some random pops every now and then but the heat shields aren't fully tight so I'll have to tighten them before getting a full 3rd/4th pull. Got on it 100% in 1st and a little through 2nd and it was fine, but it doesn't really make full boost until 3rd gear and I've been pussyfootin' it.
Old 09-26-2013, 12:10 AM   #67
bapaul
Member#: 147708
Carbon Panda
Tune? Pussyfootin? Why aren't you making full boost in 1st/2nd?
Old 09-26-2013, 02:05 AM   #68
yman
Member#: 199051
04 sti
psm
SR55 tuned to 22-ish psi is probably (don't have a boost gauge) only hitting around 16-18 psi and since I'm guessing it tapers it's probably hitting around 20 tops at the top of 2nd. This is one of those 3-6th gear turbos and since the swap I haven't had the stones to go WOT in 3rd+
Old 09-26-2013, 11:00 PM   #69
bapaul
Member#: 147708
Carbon Panda
^ Makes sense.
I have the OEM steering column gauge, it's yours once I get my Defi's back in. I also still have those D-Specs+Apexi springs if you were still interested.
Old 09-27-2013, 07:39 PM   #70
yman
Member#: 199051
04 sti
psm
^ Makes sense.
word man thanks!
Old 09-28-2013, 02:47 PM   #71
yman
Member#: 199051
04 sti
psm
nasty fuel leak found this morning. gonna have to pull the intake manifold. if any of you ladies have any input on where to start feel free to throw down, i've got a small 1/4 oz. size puddle on the back of the block and a hose that looks like it's collapsing, along with strong fuel smell over the driver side of the engine.
Old 10-02-2013, 04:59 PM   #72
yman
Member#: 199051
04 sti
psm
If anybody's interested in learning how to take off the intake manifold to do something like TGV deletes or phenolic spacers let me know I'm doing it tomorrow (Thursday). Gonna try to get to the bottom of this fuel issue.
Old 10-04-2013, 03:14 AM   #73
yman
Member#: 199051
04 sti
psm
anybody know what size the fuel rail hoses are? gonna try replacing them tomorrow. tried tightening them today because they seemed fine, but loose. didn't solve the problem, still hissed fuel everywhere.
tomorrow just gonna go crazy and replace all the hoses on the driver's side and probably the tgv gaskets.
if anybody would like to donate these driver side rubbers+clamps i'd appreciate it greatly.
Old 10-04-2013, 09:09 AM   #74
kpluiten
Member#: 120273
06 WRBWRXWGN
It's 5/16". Well it's a metric size, but is very close to 5/16". You won't find the metric stuff easily. Make sure it is rated for fuel injection, and not simply fuel. The pressure rating of injection hose is much higher. I like the Ethanol resistant PTFE lined Goodyear stuff. It should run about $5 a foot. Also, you must use fuel line clamps. Regular worm drive or spring clamps won't cut it.
Old 10-05-2013, 04:47 AM   #75
yman
Member#: 199051
04 sti
psm
thanks ken.
so yea, fuel leak fixed, still p0457. why won't this P0457 leave me alone
