Welcome to the North American Subaru Impreza Owners Club Thursday March 5, 2015
Old 08-04-2013, 05:22 AM   #1
leftsquarebracket
Member#: 359087
2002 WRX S/W
Default MOD: '02 WRX, auxiliary input WITH iPod control
I made an interface that enables an audio input for the CN702 jack in the back of the Matsu****a/Panasonic headunits in the early '00 models.
Yes, it requires absolutely NO modification to the headunit itself.
There has been discussion over how to add a line-in to these Panasonic headunits now for more than a decade (1, 2, 3, 4, 5), and in many, many hours over a month throwing my google-fu at the problem, nobody had actually posted that they had done this. If they had, there weren't even dead URLs floating around elsewhere referring to them. There's one thread on the AVRFreaks forums that describes some of the protocol, and unless you register you can't see that you can download the bus logs. And even for those there's NO direction information. I annotated them here (Google Docs).
The other solutions were similar to the Jazzy Engineering one, CDs playing in the HU (silent or the audio switched) to work, and did only audio. No controls.
It took probably two weeks of late nights to figure out how the data got passed around. My testing rig consisted of an Arduino, a couple of breadboarded components for the data bus, and an ATX power supply driving both. This shows the Arduino actually successfully posing as a CD changer, the 44:55 time hardcoded:
I found a 15-foot cable that had the mating CN702 connector on one end off of eBay, intended for adding a (presumably) trunk-mounted Panasonic CD changer in a Mazda. All the pins were in the right spots! I lopped off the other end and put my own connector on.
Since the microcontroller and power supply are an integral part of this, I figured there was no point in not adding an iPod interface, too. With a basic 3.5mm jack and an iPod, I decided a relay to switch the audio signals was necessary as well. It got a little more packed than I expected, and if I did it again I'd definitely get a bigger box and/or whip up a PCB to cut down on wire count.
I currently have it set up to show a time stamp of A:0A to indicate that the 3.5mm aux jack is in use, as shown:
The price on the bill of materials below is kind of steep, but a lot of that is in the cable and parts that added extra features. To make a simple line-in, things are much simpler and more compact. This could also be built upon for any sort of audio input, like a carputer, Bluetooth audio, or probably even Zunes or Android devices.
What do you guys think?
leftsquarebracket is offline   Reply With Quote
Old 08-04-2013, 05:23 AM   #2
leftsquarebracket
Member#: 359087
2002 WRX S/W
The Technical Stuff
These Panasonic headunits use a modified version of Alpine's M-Bus. It's a bidirectional half-duplex bus, where each bit lasts 3ms and a 0 or 1 is determined by how long the bus is held low.
What's different?
- It operates at 5V instead of 12V. Good for microcontrollers!
- The HU and changer addresses are different
- The ping sequence is entirely different, and almost looks like more of a type enumeration.
- The playback control commands seem different. Play/pause, fast-forward, rewind, and resume normal play.
Other than those, the structure and CRCs are the same. Numbers are represented as binary coded decimal, so such that hex values like 0x68 represent decimal 68 instead of decimal 104.
Here's a detailed breakdown of what gets transferred on the bus. (Google Drive/Spreadsheets)
Here's the code on GitHub
Schematic
Bill Of Materials (more complete version here)
Special Purchases
  • 1x 15' Mazda CD changer cable - eBay ($35)
  • 1x Teensy 2.0 - PJRC ($16)
  • 1x adjustable voltage regulator board - Amazon ($6)
  • 1x DIN-7 male plug - DigiKey
  • 1x DIN-7 female socket - DigiKey
  • 1x 3.5mm headphone jack - DigiKey
  • 1x DPDT latching signal relay - DigiKey
  • 1x SPDT mom-off-mom toggle switch - DigiKey
  • 1x MiniDIN-8 female socket - DigiKey
  • 1x MiniDIN-8 male plug and cable assembly - DigiKey
Parts I already had
  • 1x iPod dock connector and housing, originally from Sparkfun
  • 2x Green 3mm LEDs and 220 ohm resistors
  • 1x 10 kohm resistor
  • 1x 4.7 kohm resistor
  • 1x N-channel MOSFET
  • 1x PNP transistor
  • Assorted wire, screw terminals, heat shrink, hot glue, etc.
Last edited by leftsquarebracket; 09-10-2013 at 02:34 AM. Reason: thought I put more complete info in before :/
Old 09-09-2013, 07:58 PM   #3
compu829
Member#: 250363
good work! I was working on this off an on for my 99 Legacy. Any chance you could post the source code?
I noticed that this protocol appeared to match the Honda protocol. (I am guessing it is all modified Alpine M-Bus), except the Honda box runs at 12v.
compu829 is offline   Reply With Quote
Old 09-10-2013, 12:01 AM   #4
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Great job!
SVXdc is offline   Reply With Quote
Old 09-10-2013, 02:52 AM   #5
leftsquarebracket
Member#: 359087
2002 WRX S/W
I thought I had edited my post to include that before. Anyways, here ya go! https://github.com/kjanesch/pseudochanger
Sorry that it's a bit messy. I seem to be demanding too much with my 64-bit math, so some stuff is hardcoded.
The handshaking seems to be the major difference, at least for these HUs. I didn't see anything else that worked quite the same.
Originally Posted by SVXdc View Post
Great job!
Thanks!
Old 10-26-2013, 03:20 PM   #6
hwwoo
Member#: 234612
2005 WRX
i've been looking for this, thank you. Jazzy's solution was clever but not attractive to me.
hwwoo is offline   Reply With Quote
Old 10-28-2013, 03:26 PM   #7
leftsquarebracket
Member#: 359087
2002 WRX S/W
Glad it helps! Are you rolling your own?
Old 10-28-2013, 06:01 PM   #8
indirection_
Member#: 349415
Nice job! I have been looking for a solution like this!
indirection_ is offline   Reply With Quote
