Old 10-02-2002, 03:17 PM   #1
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Unhappy Easy Start on link?
Okay, Im stumped.
I cant get my car to start on the first crank.
I played with timing, fuel, crank enrich, and prime temp.
Is there something Im missing to the fine art of easy starting? What do you link owners have your setting set to for easy starting?
Midwayman is offline   Reply With Quote
Old 10-02-2002, 03:32 PM   #2
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
I always wait for the fuel pump to prime the system. It takes about 2-3 seconds after you turn the key to the position before you crank it.
-Chav
Chav is offline   Reply With Quote
Old 10-02-2002, 04:31 PM   #3
8Complex
Member#: 922
04 FXT
Red
Might be the IAC being fully closed or something. Try waiting a few seconds as stated above, and see how it is then.
Old 10-02-2002, 09:11 PM   #4
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
I want to say that you either have:
a) too much fuel
b) too little fuel
on startup. But knowing the way your car starts. I'm going to say that you still don't have enough fuel dumping into a cold engine for good ignition. Too much fuel would cause the engine to rev hard on startup. Too little and it takes a bit more cranking. Seriously, try at least 100% more fuel on crank.
And send me a copy of your map so I can make fun of you at the next meet.
Revision is offline   Reply With Quote
Old 10-02-2002, 11:43 PM   #5
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
You'd make fun of me anyway! :P
Old 10-03-2002, 11:18 AM   #6
Blugin
Member#: 5270
2008 EvoX MR
Red
Supposedly the link has to "boot up" and that's why it takes a sec. I just put the key "on" till the fuel pump stops and the car starts perfectly.
Blugin is offline   Reply With Quote
Old 10-03-2002, 12:15 PM   #7
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Oh, and I cant hear the fuel pump.... the dynomat doesnt help that Im sure. But If I leave it in on for a sec or two it did start easier.
Old 10-03-2002, 02:08 PM   #8
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Midwayman, are you trying to get rid of a rough start with the Link? If you don't mind, I would love to hear the symptoms, as I have an ITC and I get crappy startups sometimes. It will crank crank crank, then stop (key still turned over), crank crank crank START!
Does your startup seem something like this?
It annoys the hell out of me.
Graham
Graham is offline   Reply With Quote
Old 10-03-2002, 02:47 PM   #9
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
<threadjack> Graham, check your PMs, I'm trying to get a hold of you relating to your fuel rail mod </threadjack>
Old 10-03-2002, 03:05 PM   #10
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Graham
Okay.. usual thing is this.
turn key
Crank crank crank (something an extra crank)
Stop key
turn key again...
Crank crank crank (sometimes crank) then it fires, but just barely
Kinda like fire-Vroom-sputtter sputter- idleling.
Old 10-03-2002, 03:13 PM   #11
DoctorNick
Member#: 7022
2013 BRZ Limited
<threadjack 2> sounds like a GM to me. Did ya let andrew look at your map. Seems to me, he would know all about this. I think someone needs to start a MAP database for all the ECUs and all the maps giving details to mods, weather, engine model and octain. Might help out newbies in the future. </threadjack 2>
Also...is this a recient thing or has it been like this since you first started running off the link ECU?
Pardon my newbness but wouldn't cranking for so long, flood your engine with fuel?
-Neal
DoctorNick is offline   Reply With Quote
Old 10-03-2002, 04:32 PM   #12
PunKidd
Member#: 8533
2002 2.5 RS-T
LudeSpeed S. III W/ FMIC
Like Chav and Blugin said... the link does have to boot up. If it is starting fine when you leave the key in the on position then there is not a problem. That is just one of the annoying little things about running a link. I usually just hop in the car and put the key in the on position, then by the time I’m done putting on my seatbelt the fuel system is primed and it starts right up. It doesn’t take long to get used to it.
-Jared.
PunKidd is offline   Reply With Quote
Old 10-03-2002, 05:06 PM   #13
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Yah, Ill give it longer to boot and see if I can fiddle more. Just used to hopping in and turning the key first.
Anyone know if its right that the LOWER that crank enrich is set to, the MORE fuel its throwing in??? Counterintuitive... but I think the manual said that.
Old 10-03-2002, 05:27 PM   #14
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Yep, that's what it does. Doesn't make sense to me either
Impreza Rider is offline   Reply With Quote
Old 07-20-2004, 11:49 AM   #15
maxiav
Member#: 40413
2001 BRP RS-T EJ257
Link'd - 252WHP 274WTQ
I guess this is to revive this thread.... a friend running the Link had to wait the same 3 seconds we all wait for the Link to start the fuel pump, and now... no more waiting, just like a stock ECU. He didn't do anything to the Link.
Does anybody have an idea on what happened? Anybody else experiencing the same luck?
maxiav is offline   Reply With Quote
Old 07-20-2004, 11:00 PM   #16
milkman
Member#: 8066
Y2K RSt
Sedona Mars Red Pearl
What software and chip is he running?
milkman is offline   Reply With Quote
Old 07-20-2004, 11:26 PM   #17
Chav
Member#: 3269
RSTi
I gave my car to subaru service to do the 30k mile service with the link installed. When I first got the car back the fuel pump would prime the instant the key was in the on position (and it would fire right up if cranked). I tried to connect to the link plus with the laptop and I got nothing. I keyed on then off a few times and then the laptop connected, I checked everything to make sure the settings were fine. Then I tried to start it, but it had gone back to the 3 second wait then fuel pump on. Weird, it has never happened since.
-Chav
Old 07-21-2004, 03:52 PM   #18
maxiav
Member#: 40413
2001 BRP RS-T EJ257
DAMN IT!!!!
This is the same thing. He has a Link Plus too, and he still gets the pump on as soon as he puts it in the on position. I'm trying to figure out how to do this and I have no clues where to look for this....
Cold Starts and Link Impreza Rider Engine Management & Tuning 18 06-05-2008 12:50 AM
Slow starting on Link Plus ai42 Engine Management & Tuning 4 10-11-2005 06:59 PM
FS: stock sti tires, 1000 easy miles on it $400.00 pierceman Private 'For Sale' Classifieds 5 02-21-2004 01:58 PM
Whos going to the barbecue at Easy Street on Saturday (12/14)? thebusiness999 Southern California Impreza Club Forum -- SCIC 5 12-14-2002 01:25 PM
Quick and easy question on spring rates DDMan Brakes, Steering & Suspension 5 10-15-2002 10:48 PM
Message Board Statistics All times are GMT -4. The time now is 05:24 AM.
