Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 10-12-2013, 09:55 PM   #226
nullsprock
Member#: 366790
Replaced the valve cover gasket on my beater civic and kept trying to figure out my coolant puking/overheating issues. Found out I had two lines crossed (the one plumbed to the turbo and the one coming off the nipple of the expansion tank by the turbo, have a post in the 2.0 powertrain forum), took it on a test drive, no overheating but the coolant was frothy and close to overflowing when I was parking again. Mechanically inclined subaru enthusiast friend says it could still be some trapped air, especially since I had the lines crossed until today, but back at it tomorrow. Couldn't do a block test with the lines crossed because coolant kept spurting from the nipple on the expansion tank, getting sucked into the block tester, so hopefully I can at least get the test run successfully tomorrow.
nullsprock is offline   Reply With Quote
Old 10-12-2013, 10:01 PM   #227
SIRDEADPOOL
Member#: 346164
07 WRX
Perrin drop in filter
SIRDEADPOOL is offline   Reply With Quote
Old 10-12-2013, 10:45 PM   #228
SWP is Sexy
Member#: 302389
2011 WRX
I'm a stormtrooper pewpew
Plan to stop bleeder leak enacted, seems to be successful. Time will tell
SWP is Sexy is offline   Reply With Quote
Old 10-13-2013, 11:59 PM   #229
Subie2.5i
Member#: 216472
'05 Legacy GT Wagon
95 WRX/L
Started wiring up my jdm hid headlights and jdm power folding mirrors.
Subie2.5i is offline   Reply With Quote
Old 10-14-2013, 09:28 AM   #230
SGC2CIC
Member#: 286908
2014 EVO X GSR
2000 2.5RS
Did you use jdm soap and jdm rag?
:-p
SGC2CIC is offline   Reply With Quote
Old 10-14-2013, 11:36 AM   #231
MikeKyu
Member#: 330342
2010 Impreza WRX
Lightning Red
Bought used 2013 STi calipers, ordered dba 4000 double drilled rotors, goodrich lines, and stop tech street II pads.
MikeKyu is offline   Reply With Quote
Old 10-14-2013, 01:56 PM   #232
juandering
Member#: 330389
05 Saabaru
Hopefully my h6 brackets came in at work so that I can finally install the h6 brakes later this week. I was surprised how cheap everything was under my discount Also had my valve cover gaskets shipped out
juandering is offline   Reply With Quote
Old 10-18-2013, 12:03 PM   #233
dzywrx
Member#: 77610
2015 WRX-byebye 04
Sexy
finally got around to doing the seatbelt chime mod - turned my frown upside down
ordered some ramm mat/ensolite stuff for future fun.
dzywrx is offline   Reply With Quote
Old 10-18-2013, 12:50 PM   #234
juandering
Member#: 330389
05 Saabaru
Finally got around to changing out the passenger side valve cover gasket and half moons, perfectly good reason to hoon my car, gotta make sure there's no more leak
Now I don't have to deal with a smoke show coming out of my hood scoop every time I drive my car
Old 10-18-2013, 05:37 PM   #235
Excision
Member#: 294622
2007 STI - WRB
Perrin GTX3076r, Slow
replaced my plugs. now its pulling hard as f*ck again
Excision is offline   Reply With Quote
Old 10-18-2013, 05:58 PM   #236
Guac
Member#: 364898
2013 WRX Sedan-ISM
294awhp/334awtq AWDTuning
Installed AEM intake and Cobb AP. Tomorrow, Kartboy SS/Bushings and Perrin Turbo Inlet Hose.
Guac is offline   Reply With Quote
Old 10-18-2013, 06:17 PM   #237
SGC2CIC
Member#: 286908
2014 EVO X GSR
2000 2.5RS
I'd ditch the intake . And the inlet hose is not compatible with an OTS map I hope you know.
Old 10-18-2013, 06:59 PM   #238
iconone
Member#: 174883
135i 05 CGM WRX
2006 Yamaha R1
You can't run a turbo inlet with a ots map?
iconone is offline   Reply With Quote
Old 10-18-2013, 07:37 PM   #239
Guac
Member#: 364898
2013 WRX Sedan-ISM
Even if its post MAF? I thought its okay to install as long as its past the MAF sensor. Correct me if I'm wrong.
Old 10-18-2013, 08:20 PM   #240
SGC2CIC
Member#: 286908
2014 EVO X GSR
2000 2.5RS
I even called cobb plano to make sure before i posted that and yes its not approved to use on an OTS map. the intake is if you use the specific intake map but i wouldnt use it since 08+ subies have had bad luck with intakes. you can always get a protune
Old 10-18-2013, 08:33 PM   #241
Guac
Member#: 364898
2013 WRX Sedan-ISM
Hmmmm, okay. Thank you for the information. I'll probably just hold off on installing the inlet then until I can get a protune from Cobb one of these days.
Old 10-19-2013, 08:18 PM   #242
SGC2CIC
Member#: 286908
2014 EVO X GSR
2000 2.5RS
Hand washed and polished both cars
Old 10-19-2013, 08:55 PM   #243
Gary Bechtold
Member#: 99393
1997 Supra Turbo
2005 Legacy 2.5 GT Wagon
What do you use for polish? Looks good.
Gary Bechtold is offline   Reply With Quote
Old 10-19-2013, 09:26 PM   #244
SGC2CIC
Member#: 286908
2014 EVO X GSR
2000 2.5RS
Just some detailer spray
Old 10-22-2013, 03:25 PM   #245
Excision
Member#: 294622
2007 STI - WRB
changed oil and filter
Old 10-23-2013, 02:00 PM   #246
gregsatt
Member#: 38536
'02 WRX Wagon
FreeRentMoney.com White
2.5l STI Shortblock in my 2002 WRX Wagon Can't wait for it to be finished up so I can enjoy the torque.
gregsatt is offline   Reply With Quote
Old 10-24-2013, 12:09 AM   #247
juandering
Member#: 330389
05 Saabaru
Finally did the H6 upgrade in the rear with some Wagner pads and switched out the crappy duralast pads from the po with PFC pads in the front, flushed out the DOT 3 with DOT4 and bedded the pads in.
No more braking slightly hard once then having completely useless spongy brakes
Old 10-24-2013, 08:51 PM   #248
In10city
Member#: 363489
2006 Subaru WRX STi
04/05 carbon fiber hood on the 06 STI
In10city is offline   Reply With Quote
Old 10-24-2013, 08:56 PM   #249
In10city
Member#: 363489
2006 Subaru WRX STi
Badge overlay;
Off ebay for 7 dollars shipped; same quality as the ones that are selling for 18 on that jdm vinyl site; I had one given to me but it didn't fit so I stuck it on a water bottle.. Then found these ones on ebay and when they came in I compared and they are exactly the same
When installing you may think they aren't a perfect match but you need to heat with hair dryer or heat gun and press to stretch around the ends
I say it's a 98% match; good enough for me
Old 10-24-2013, 08:58 PM   #250
In10city
Member#: 363489
2006 Subaru WRX STi
Sorry for the double post; my iPad is tripping
