Old 08-07-2013, 04:54 PM   #1
UPPCOS
Member#: 364680
Default Open Souce Antilag and Rolling Antilag
Since I didn't find any patches, and 2011 isn't a group N compatible (afaik), we figured out a way to antilag on demand, both for launches and for roll on races.
UPPCOS is offline   Reply With Quote
Old 08-07-2013, 05:14 PM   #2
dux10
Member#: 235338
2002 Faggin Wagon
srp
Who is "we'?
Steve @ Pullz-On Tuning
dux10 is offline   Reply With Quote
Old 08-07-2013, 05:19 PM   #3
easyeatlanta
Member#: 347906
2008 Sti - 6066
im guessing underpressure power and performance
easyeatlanta is offline   Reply With Quote
Old 08-07-2013, 05:24 PM   #4
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Very cool... how does it work? I didn't catch anything about how it works in the video.
WRXt4cy is offline   Reply With Quote
Old 08-07-2013, 09:24 PM   #5
Paidfor
Member#: 267815
Be in awe
dont hate .)
O ****!!!!!!!!!!! You gotta get that patch Dux
I want this **** with your tune....real soon
Paidfor is offline   Reply With Quote
Old 08-08-2013, 10:12 AM   #6
bjohnson_55
Member#: 216580
So that was your launch with normal fuel cut launch control?? Why are you having such a hard time building boost with it? I could come up with a few things that are obvious culprits. Who coded the patch for you? Merp?
bjohnson_55 is offline   Reply With Quote
Old 08-08-2013, 10:23 AM   #7
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
It doesn't sound like a software patch. I know Merp is working on Anti-lag but I don't think he has anything ready to test yet.
This sounds more like hardware based. In the video, he talks about holding the anti-lag button to start it and then releasing it to go. I think they just have some module that is taking control of timing and retarding it and then letting it return to normal.
Old 08-08-2013, 10:34 AM   #8
Andrewxxcarlson
Member#: 316415
2006 WRX
Subscribed
Andrewxxcarlson is offline   Reply With Quote
Old 08-08-2013, 10:48 AM   #9
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
+1...
rexworx is offline   Reply With Quote
Old 08-08-2013, 11:32 AM   #10
UPPCOS
Member#: 364680
It's some hardware, some software, but no patches (other than the standard TinyWerx 2-step). It can be done on ANY of the roms, regardless of year, bits, platform, etc.
With our rotated mount 35R kit, the 2-step just isn't enough. We put the 2-step at redline even, still no boost for the launch. I could retard the timing in the main map to help this, but then I'd be left with a huge hole in the map. Stock turbos this really isn't a problem as they're so small they spool 5-10psi with just a 2-step, but when you go big, it's a different story. Once we figured out that even at redline there was zero boost, and the launches still sucked, we knew we needed a different avenue.
We've been running push button anti lag on all our other AEM cars for a while, and it works amazing. Rolling antilag on our 3KGT (AWD) rips the tires off in 1st gear, and damn near lifts the front end in 2nd. The honda's will rip the tires loose 4th doing 80+mph. And it's more controllable for the launches so we only have to anti-lag for a short time. When at the light we can bounce the -step, but not until the tree is dropping do we hit anti-lag, this way we're not sitting there burning the exhaust valves waiting on the other guy to stage.
And decel anti-lag sounds awesome! Slowing for a light crack the button, and nice gurgle popping from the exhaust.
CK
Old 08-08-2013, 11:58 AM   #11
WhatTurboLag?
Member#: 243992
2006 WRX TR
Is rolling antilag a predetermined rpm or is it whatever rpm you press the button at?
WhatTurboLag? is offline   Reply With Quote
Old 08-08-2013, 12:00 PM   #12
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Thanks for adding some extra details here.
Would you care to go into more depth about how the hardware piece works or are you planning to sell this as a solution or something? I've got some customers that are into drag racing that would be interested in anti-lag on their 32-bit ECU cars. CarBerry works great for the drive by cable guys but there hasn't been a good solution for everyone else yet.
I hoping you'll share more info with the community or offer this up as a product that other people can use.
It appears to be active whenever you push the button, regardless of speed or rpm.
Old 08-08-2013, 04:46 PM   #13
Paidfor
Member#: 267815
Be in awe
dont hate .)
Ok so its a combo of software and a magic timing module box
im in...how much?
Old 08-08-2013, 08:13 PM   #14
bjohnson_55
Member#: 216580
Please quit calling it a 2step. It's not a 2 step.
Old 08-08-2013, 09:57 PM   #15
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
This needs to be made available ASAP.
I'm still skeptical though.
Black94Snake is offline   Reply With Quote
Old 08-08-2013, 11:05 PM   #16
WhatTurboLag?
Member#: 243992
2006 WRX TR
Proefi has this already.. I hace a feeling its a set rpm and cant be changed.
Proefi also has real oem like flex fuel
And so much other awesome stuff.
Old 08-08-2013, 11:20 PM   #17
bjohnson_55
Member#: 216580
syvecs is the only one I'm aware of that has rolling anti-lag.
A lot of standalones support flex fuel.
Old 08-09-2013, 01:53 AM   #18
WhatTurboLag?
Member#: 243992
2006 WRX TR
I am talking TRUE flex fuel, not just a triggered map switch. It adjusts fuel boost timing etc based on the ethanol content in real time. No map switch.
And proefi just came out with rolling antilag. Again true. Any speed any rpm with the push of a button antilag.
Old 08-09-2013, 10:07 PM   #19
bjohnson_55
Member#: 216580
Rolling Antilag supra - YouTube
Yeah I'm talking about TRUE flex fuel too..
Old 08-09-2013, 10:07 PM   #20
Paidfor
Member#: 267815
Be in awe
dont hate .)
Who the hell is Proefi and why have I been under a rock?
I must have this ............ive yet to snap a axle, kinda wanna see what it feels like lol
Seriously.....the community needs this **** bro.....post a link so I can buy this **** already!!!
Old 08-10-2013, 12:08 PM   #21
GulfCoastMotorworks
Member#: 358317
6266 Built Bugeye
GulfCoastMotorWorks.com
Take my MONEY!!!!!!!!!!!!
GulfCoastMotorworks is offline   Reply With Quote
Old 08-10-2013, 01:50 PM   #22
Paidfor
Member#: 267815
Be in awe
dont hate .)
NOW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!
please .)
Old 08-10-2013, 11:43 PM   #23
WhatTurboLag?
Member#: 243992
2006 WRX TR
un fortunately proefi takes a lot of work to run on a Subaru. Something about the cam and crank sensors or something. Which sucks because in my opinion it's the best out there. Better than motel, syvecs, vipec, etc.
Old 08-11-2013, 02:32 PM   #24
Paidfor
Member#: 267815
Be in awe
dont hate .)
Dammit.....ok, well someone figure this **** out and make a us kit .)
Ill take one please.
Old 08-13-2013, 01:02 PM   #25
UPPCOS
Member#: 364680
No, it's not RPM specific. You can run it at any RPM. The other vid that was posted in here was a 2-step, hence why it's bouncing off of a rev-limiter, this doesn't have a 2-step (except while sitting still using the 2-step launch control).
There are 2 different things we're talking about here, 2-step is a rev control, either eliminating spark or fuel causing a bouncing of the RPMs, holding a steady RPM for launching (and what was seen in the 2nd vid). The other is Anti-Lag, which is simply retarding the timing to cause the turbo to spool. Anti-lag can be accomplished when ever you want, at any RPM, and at any speed, you just push a button and it retards your timing.
Like it shows in the video, your car doesn't bounce off a rev-limit while you're moving, the timing is just SO retarded that you don't actually make power to accelerate your car, the result is you stay relatively the same speed, while your boost builds. Once you let go of the button, your boost is there, and then your timing returns, so your car again makes power.....lots of power.
We will not be selling this.....as we are not a vendor on this forum, we cannot post things for sale. However, if there is enough demand, I will do a write up on how to do this for FREE!!! I will however accept PP donations! ([email protected])
It's actually a pretty easy simple setup, no "magic box" or special hardware is needed.
CK
