Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 10-02-2002, 08:32 PM   #1
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
Talking UTEC Question
First of all... awesome unit. Just thought I'd get that out of the way up front
Ok, one of the things I noticed in the manual, was the dip switches, and what those settings mean. Two of the switches are very interesting to me - the ones that control whether the front or the rear o2 sensor is used. Default is rear o2 sensor, if I'm reading this correctly.
What happens if you move this to front o2? Seems as though you'd have a LOT more accurate numbers, being its a wide band sensor instead of a narrow band. I have a turbo timer hooked up to my rear o2 (or rather.... did up until 5 minutes ago), but I know with the LINK, when I'd tune the turbo timer would actually screw up the voltage.
Same with the UTEC I would imagine. And since the number is given as an A/F ratio, I can't tell which sensor is REALLY being used here.
DarthChicken is offline   Reply With Quote
Old 10-02-2002, 08:35 PM   #2
crazyhorse
Member#: 19502
2010 Impreza with no
scoop. =(
Sorry to highjack your thread.. but if you noticed our thread about the new site, would you be so kind as to upload your maps sometime? Any data logs would be great.. My UTec gets here on Monday so I'd love to have a little information before I start tweaking it.
I didn't think the stock front O2 was a wideband... If you've got an aftermarket one up there, I'd definitely tune off of it. My rear seems to be fairly accurate from what I've seen.
crazyhorse is offline   Reply With Quote
Old 10-02-2002, 08:42 PM   #3
subix
Member#: 7970
2002 Impreza WRX
Actually the front o2 sensor on the rex is wide band. And from what I hear the rear o2 is really inacurate seeing it only works in a small af ratio and its behind 3 cats...
-Subix
subix is offline   Reply With Quote
Old 10-02-2002, 08:48 PM   #4
crazyhorse
Member#: 19502
scoop. =(
Learn something new every day.. Thanks for the info. Still getting used to having a flat 4. Then again.. my rear O2 is only behind 1 cat. Hrmm.. wonder where I read that I should tap into the rear one for my a/f gauge. Have to change that.
Thanks again!
Old 10-02-2002, 09:25 PM   #5
SFastWRX
Member#: 13379
I am Oz
The front O2 sensor is not true wideband.
SFastWRX is offline   Reply With Quote
Old 10-02-2002, 10:28 PM   #6
subix
Member#: 7970
2002 Impreza WRX
Thanks again!
Well, a normal a/f gauge is not compatable with wide band o2 sensors, thats why people use things like utec logging and deltadash to truely monitor their a/f ratio. Now on the other hand Greddy's a/f gauge comes with a semi-wideband o2 sensor that is more accurate.
-Subix
Old 10-02-2002, 10:35 PM   #7
crazyhorse
Member#: 19502
scoop. =(
Well I knew that I'd need a wide band O2 sensor if I wanted to be accurate.. and planned on using the UTec or Delta Dash to monitor it.. but I didn't think the rex had one stock... And I guess I was right thinking it didn't?
Old 10-03-2002, 01:12 AM   #8
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
My bad guys... I misread the form. Its using the front o2 sensor in the position its in. At least I didn't go tuning in the state of mind I'm in, otherwise I would have just kept adding more and more fuel
The log files can be a bit frustrating sometimes, because seeing the word "ECU" instead of a number is something that really makes me want to see what its REALLY doing. I know... let the ECU do its own thing below 60% TPS... I'm still in LINK tuning mode
As to whether or not the rex has a wide band o2 sensor... does it matter? You get A/F ratios out of it, it seems to work just fine. I say save grand, and buy a bigger turbo!
Old 10-03-2002, 01:14 AM   #9
STi_Pete
Member#: 14576
2002 WRX Sedan
Darth what are you're feeling on the UTEC as opposed to the LINK.
STi_Pete is offline   Reply With Quote
utec question changing to MBC from utec boost trbowrx Engine Management & Tuning 8 06-28-2005 07:15 AM
snowboard question and UTEC question i_heart_boost Newbies & FAQs 6 12-11-2002 12:30 PM
Another UTEC question DiMensionX Engine Management & Tuning 26 10-01-2002 03:03 AM
Utec Question? GT2WRX Engine Management & Tuning 7 09-07-2002 03:30 PM
Very specific UTEC questions for users/experts. davidm_sh Engine Management & Tuning 22 09-02-2002 11:27 AM
