Old 10-02-2002, 09:34 PM   #1
Otaku64
Member#: 2971
Default utec or unichip...what's the difference?
i would like to get an engine management system. i already have an avc-r and an afc installed. would adding an ems be very beneficial after what i already have? so far, there's a full catback exhaust as well as the electronics mentioned above. i will be adding a larger turbo kit (injectors, fuel system, etc.), so would it be worth it yet to get the chip?
thanks,
-salvatore
Otaku64 is offline   Reply With Quote
Old 10-02-2002, 11:48 PM   #2
DJWRX
Member#: 10340
Since you already have the SAFC, just get a Delta Dash, that way you can control both fuel and timing. Or just ditch the SAFC and go with the UTEC. Either way, you have way more tunability compared to the unichip, with which you have no tunability.
There is TONS of info out there on these two systems. Do a search, you'll find days worth of reading.
Tim
DJWRX is offline   Reply With Quote
Old 10-03-2002, 12:40 AM   #3
mlambert
Member#: 13831
the only thing you can do with the DD in regard to changing stuff is engine IDLE rpm, the delta dash is a datalogger!
a unichip is a piggyback ecu that offers 0 end user control
the utec is an ecu that works in unison with the stock ecu that allows the user to change everything
mlambert is offline   Reply With Quote
AGP or PCI video card? What's the difference? RacerinLSL Off-Topic 11 08-28-2003 04:50 PM
utec or unichip or boost controller and fuel computer? racewagon Engine Management & Tuning 4 05-28-2003 05:06 PM
What's the difference? Cheap up-pipe or expensive up-pipe? Rallye-fan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-26-2003 01:19 AM
what's the difference between turboxs and vishnu's unichip? Poe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 10-24-2002 11:14 PM
What's the difference between the different gauge brands? Alpine Newbies & FAQs 2 10-04-2002 01:55 PM
