Old 08-09-2013, 08:53 AM   #1
KC
Member#: 442
13 Crosstrek XV
00 S2000
Default Dash accents - how to remove?
Anyone know how to remove the silver dash accents (those two silver bars on the drivers side and passenger side dash).
I'm thinking of plastidipping them orange to match my XV color.
--kC
KC is offline   Reply With Quote
Old 08-09-2013, 01:07 PM   #2
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
The service manual makes it look like those trim pieces are held in with typical clips, so you should be able to use typical trim removal tools to pop them out. It also looks like if you remove the trim pieces that are along the side of the dash (the plastic covers that are up against the door when the door is closed), you can reach behind the trim pieces you're trying to remove and push them from the backside.
On the passenger's side, you might need to remove the glove box first, too.
sgoldste01 is online now   Reply With Quote
Old 08-09-2013, 01:11 PM   #3
myrt1987
Member#: 323103
2012 Limited 2.0i
Dreamy Gray Mistress
Somebody here removed them to wrap in CF vinyl, pretty sure they pop off with a flathead or those plastic panel tools.
Old 08-09-2013, 02:08 PM   #4
KC
Member#: 442
13 Crosstrek XV
00 S2000
OK. cool. SHould be easy enough.
Shop manual... how do those work again?
--kC
Old 10-05-2013, 11:25 PM   #5
alymida
Member#: 350783
2013 2.0i Sport Ltd
Dark Gray Metallic
I popped mine off today with a flat head but it did bang up my dash vinyl or whatever it is ... Maybe someone with a gentler touch could do it nicer lol. I am hoping armor all will restore the nice black color.
Anyone know how to remove the silver trim around the shifter? And that little silver piece on the steering wheel?
alymida is offline   Reply With Quote
Old 10-06-2013, 09:42 PM   #6
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
KC, talk to this dude..
Originally Posted by TRSAndrew View Post
Color-keyed my dash trim
BrysImpreza is online now   Reply With Quote
Old 10-07-2013, 10:10 AM   #7
79letour
Member#: 302570
2013 XV
DGM!
The teim will rattle and be very loose if you arent careful. I'm having mine done by a body guy. I tried getting it off myself, and mine wouldn't come off at all. $20 worth of teim removal tools didn't even phase mine.
Best of luck, post pics!
79letour is offline   Reply With Quote
Old 10-07-2013, 12:20 PM   #8
TRSAndrew
Member#: 360634
2013 Crosstrek
Orange
It pops off. No biggie at all.
TRSAndrew is offline   Reply With Quote
Old 10-07-2013, 12:27 PM   #9
79letour
Member#: 302570
2013 XV
DGM!
Mine were pulling the entire dash panel behind them up. the trim pieces themselves pulled so far off without popping off that the entire clip was fully visible. It has me completely baffled.
Old 10-07-2013, 12:29 PM   #10
79letour
Member#: 302570
2013 XV
DGM!
The "clips" are molded into the accent pieces, and they slode into slots molded into tue panel behind. So if something gets broken it will be a bit pricey.
Old 10-07-2013, 12:52 PM   #11
TRSAndrew
Member#: 360634
2013 Crosstrek
Orange
Sounds like you're pulling wrong. I started next to the door panel and just shoved in a long, broad flathead and popped the first clip off, then went after it with a broad panel tool. Popped right off.
Old 10-07-2013, 09:14 PM   #12
myrt1987
Member#: 323103
2012 Limited 2.0i
Anyone?
Old 10-07-2013, 09:17 PM   #13
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Originally Posted by myrt1987 View Post
Anyone?
Thin flat tipped screwdriver and pry a little around the parameter
Old 10-07-2013, 09:40 PM   #14
myrt1987
Member#: 323103
2012 Limited 2.0i
Really? For the trim around the shift knob? I feel stupid that I didnt even try that.
Old 10-08-2013, 06:30 AM   #15
alymida
Member#: 350783
2013 2.0i Sport Ltd
Dark Gray Metallic
Maybe I need a thinner flat head before I try that again, it did a good job of chewing up the plastic 😑
Old 10-08-2013, 08:11 AM   #16
boymonkey
Member#: 363115
2013 Impreza Sport
Crystal Silica Black
Anyone figure out how to get the piece off on the steering wheel?
boymonkey is offline   Reply With Quote
Old 10-08-2013, 08:35 AM   #17
KC
Member#: 442
13 Crosstrek XV
00 S2000
Maybe I need a thinner flat head before I try that again, it did a good job of chewing up the plastic ��
Use plastic "trim pullers", not metal.
Thanks Bry for the pic, that's exactly what I wanna do.
--kC
Old 10-08-2013, 09:14 AM   #18
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
No. Invest in a set of these:
http://www.harborfreight.com/5-piece...set-67021.html
Old 10-10-2013, 06:17 PM   #19
79letour
Member#: 302570
2013 XV
DGM!
Those are what I used. I'll pay whoever can get mine off without destroying anything.
Old 10-21-2013, 03:06 PM   #20
alymida
Member#: 350783
2013 2.0i Sport Ltd
Dark Gray Metallic
I got everything off I wanted finally and dipped my pieces last night, turns out I just needed some man strength from my boyfriend to get out the plastic piece that goes around the shifter, after he cracked it loose I got the rest off no problem.
Still waiting for my long silver trim pieces to be hydro printed, but I plasti dipped the silver piece around the shifter and the silver parts on the actual shifter. YouTube helped immensely haha.
Old 10-21-2013, 03:49 PM   #21
myrt1987
Member#: 323103
2012 Limited 2.0i
Whaaat. How do you take off the shift knob? Damn, I was so close this weekend and I couldn't figure out the shifter. Figure I would ask before breaking something.
Old 10-21-2013, 04:40 PM   #22
mrbloink
Member#: 333058
Unscrew it fully and then when it is dangleing just pull it off from the boot
mrbloink is offline   Reply With Quote
Old 10-21-2013, 05:25 PM   #23
myrt1987
Member#: 323103
2012 Limited 2.0i
I tried twisting, it didn't budge. (AT shift knob btw) Twist harder?
I must sound like an idiot... lol
Old 10-22-2013, 12:33 AM   #24
Kho
Member#: 354623
2012 Impreza Sedan
Dark Grey Metallic
For CVT knob...please dont twist..u gonna break it :P...the knob is held in place by a metal clip
1. the chrome (bottom) of the shift knob can be pulled down to gain access to the clip
2. use fingers and/or flat head screw driver to carefully squeeze and pull out the pin
3. the shift knob should pull straight out at this point
4. reverse steps for re-install (just make sure u slide in chrome piece in before putting in the entire shifter knob and pin)
Kho is offline   Reply With Quote
Old 10-22-2013, 06:19 AM   #25
alymida
Member#: 350783
2013 2.0i Sport Ltd
Dark Gray Metallic
+1 for this, I used the flathead and popped the bottom piece off then just pulled out the staple looking thing and off goes the shift knob.
I wasn't too worried about messing up the chrome crap since I was gonna plasti dip it anyways. I have before and after pics but need to learn how to post them -_- haha.
