Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 08-11-2013, 01:09 PM   #1
krypton
Member#: 277092
2011 wrx sti sedan
black
Default Cusco LCA
Hi NASIOC
Im in the process of doing my new rims set up and got a question. I got a "11 STI wheels are work xd9 18X10 +18 im planing on running 225/40 tires and im aware that i have to roll the rear fenders and run -3 -4 camber.So i got the cusco LCA to do the job. Question is concerning toe. Will i need toe link to bring the toe back to 0 with that kind of camber settings? Just wanted to know so i get everything ready and have it all done at once.
Thanks in advance guys
krypton is offline   Reply With Quote
Old 08-11-2013, 03:01 PM   #2
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Have u considered a whiteline roll center kit (bump steer). Just might be the fix u need especially if u r lowered.
trev762 is offline   Reply With Quote
Old 08-11-2013, 04:21 PM   #3
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
i think he's asking about the rears.
i wonder also if i should get the whiteline LCA or the cusco cause they have the arms also but not sure honestly how it will help in your situation going negative camber.
the roll center kit helps the front. i'm waiting for my coils and installing these also.
JAMM0N is offline   Reply With Quote
Old 08-13-2013, 06:27 PM   #4
calebtharrell
Member#: 242113
2004 STi, 2008 STi
With that amount of camber you will definitely want to buy some rear toe arms.
calebtharrell is offline   Reply With Quote
Old 08-13-2013, 11:41 PM   #5
krypton
Member#: 277092
2011 wrx sti sedan
black
Well i guess its going to be rear toe arms or raise the suspension
Old 08-13-2013, 11:58 PM   #6
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
You could try the Whiteline upper control arm bushings; PITA, but that way you get at least a degree or two of camber that doesn't effect your toe...allowing you to run less camber from the control arm.
At the end of the day you'd probably still need toe arms.
OrbitalEllipses is offline   Reply With Quote
Old 08-14-2013, 12:16 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Originally Posted by krypton View Post
Hi NASIOC
d0h....yer one of those special idiots
a 225 on a 10" wheel is just about the most brainless thing i see posted here
congrats on the idiot of the month award
Old 08-14-2013, 09:14 PM   #8
krypton
Member#: 277092
2011 wrx sti sedan
black
Any mods to the front to run this setup?
Old 09-11-2013, 12:21 PM   #9
calebtharrell
Member#: 242113
2004 STi, 2008 STi
I am running 275's on the front without an issue. You will be fine as long as you aren't super slammed.
Old 09-11-2013, 05:10 PM   #10
Paul_Illest
Member#: 335368
2010 WRX
you wont have to run that much camber to make it work...and i doubt you'll have to roll much. I hardly rolled to fit a 18x9.5 +38 with 225/40/18. And im on a narrow body 2010 wrx, versus you having a widebody. My camber ended up being -1.8 front and -2.6 rear, i do have the cusco control arms though, but toe wasnt needed. I fit even wider wheels/tires on my car also! So you should be fine! Also depends how low you go, im slammed as far as i can go almost on coils
Paul_Illest is offline   Reply With Quote
Old 09-13-2013, 02:01 AM   #11
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
i run 255/35/18 :]
more meat less sidewall. rub a little in the rear.
you have the LCA but you still have -2.6? i'm at -1.6 w my LCA (Agency Power)
