Old 10-02-2002, 11:15 PM   #1
DiMensionX
Member#: 23517
Talking NEW UTEC & DeltaDash logs HERE from tonight 10.2.02
Ok folks here are the next round of logs. These are perfectly (mostly) syncronized DeltaDash and UTEC log's. No comments on the 135mph run:-), my co-driver/logger (Steve) got a little nervous .
I'm going to a Dyno tommarow and REALLY REALLY REALLY need some REAL information on constants and tuning parameters ASAP. It's a little hard to tune without them. I only know what Nathan was kind enough to post in my other post regarding fuel changes, and also what Jorge posted about changing the knock sensitivity. Well, how do you do that (meaning the Knock Sensitivity?)? Please send any info, Alpha, Beta, whatever to [email protected]. As I learn this I am more than willing to pass the knowledge on, which will in turn save TurboXS, Jorge, and others from having to answer over and over again.
Thanks folks, onto tonight's 4 runs:-). The first 3 were UTEC logged using the Data4 log, the 4th run was using Data1 just for grins. I only got one knock event logged in the 3rd run, yet no timing was pulled. Is there a knock threshold that has to be exceeded for timing to be pulled? I did knock a couple of times this evening other than that according to the CEL knock sensor, however I fealt NO timing being pulled nor did I here or feel the knock. One of these was when a pesky Honda was messing with me, that didn't last long . This thing is a slingshot.
Onto the good stuff, please post comments, this stuff needs to be hashed out for ALL of us.
Thanks,
Shawn
DiMensionX is offline   Reply With Quote
Old 10-02-2002, 11:23 PM   #2
DiMensionX
Member#: 23517
Code:
Log 1 10.2.02
TIME     RPM  MAP MAF TPS MLP  Knock O2 IGN#1  INJ#1  IGN   FUEL BOOST
02871173   831  73 116  57  00    00 126 +11.1    5.0 ECU.   -9.5 ECU.
02871334  1130  99 100  61  00    00 122 +19.2    3.0 ECU.   -9.5 ECU.
02871734  1646 112 111  65  00    00 124 +29.8   15.0 ECU.   -5.5 ECU.
02872134  1984 108 118  76  00    00 102 +33.9    6.0 ECU.   -5.5 ECU.
02872534  1923 110 120  89  00    00 139 +32.2    7.0 ECU.   -5.5 ECU.
02872934  1801 114 119  98  00    00 122 +29.7    7.0 ECU.   -5.5 ECU.
02873334  1601 116 117 111  00    00 133 +26.3   66.0 ECU.   -5.5 ECU.
02873734  1488 117 113 119  00    00 128 +25.0    6.0 ECU.   -9.5 ECU.
02874134  1517 118 112 132  00    00 133 +25.2   16.0 ECU.   -9.5 ECU.
02874534  1743 119 117 152  10    00 122 +29.1    7.0 ECU.   -6.8 ECU.
02874934  2057 119 124 169  10    00 123 +32.8   11.0 ECU.   -6.1 100.00
02875334  2220 118 124 175  10    00 114 +31.4  106.0 ECU.   -6.1  95.00
02875734  2482 121 134 181  10    00  83 +32.6   12.0 ECU.   -5.9  95.00
02876134  2794 123 141 183  10    00 113 +32.7   13.0 ECU.   -5.9  95.00
02876534  3046 128 150 184  10    00 114 +30.3   16.0 ECU.   -5.9  50.00
02876934  3343 126 158 185  10    00 110 +28.4   20.0 ECU.   -5.9  46.80
02877334  3736 135 167 185  20    00  99 +27.5   26.0 ECU.   -5.9  43.50
02877734  4135 146 179 186  30    00  92 +23.2   33.0 ECU.   -5.9  44.50
02878134  4585 163 192 186  50    00  60 +16.8   48.0 ECU.   -5.6  48.60
02878534  5027 181 203 185  70    00  40 +19.5   64.0 +23.0  -5.3  46.00
02878934  5574 179 209 184  70    00  52 +22.1   75.0 +24.0  -5.1  42.50
02879334  6172 192 214 184  80    00  54 +24.1   83.0 +25.0  -5.1  42.50
02879734  6600 199 217 185  90    00  55 +26.6   85.0 +25.0  -5.0  42.50
02880134  7062 189 218 183  80    00  56 +29.1   41.0 +25.0  -5.0  42.50
02880534  6915 172  90  26  00    00 102 +10.1   32.0 ECU.   -5.5 ECU.
02880934  6184  70 107  47  00    00 180 +40.7   26.0 ECU.   -5.5 ECU.
02881334  5073 115 194 174  10    00 117 +25.3   52.0 ECU.   -5.3  48.00
02881734  4468 162 194 184  50    00  42 +15.1   54.0 ECU.   -5.6  48.60
02882134  4636 181 200 186  70    00  56 +15.6   62.0 +23.0  -5.3  48.00
02882534  4859 195 198 186  80    00  55 +17.8   67.0 +23.0  -5.3  48.00
02882934  5035 193 206 187  80    00  55 +20.4   69.0 +23.0  -5.3  46.00
02883334  5299 179 207 188  70    00  54 +22.2   73.0 +23.0  -5.2  43.50
02883734  5500 200 209 188  90    00  55 +21.6   78.0 +23.0  -5.1  42.50
02884134  5640 188 212 188  80    00  54 +22.1   82.0 +23.0  -5.1  42.50
02884534  5858 202 213 188  90    00  54 +23.5   85.0 +24.0  -5.1  42.50
02884934  5984 181 215 189  70    00  55 +24.2   86.0 +25.0  -5.1  42.50
02885334  6242 179 218 189  70    00  54 +24.1   88.0 +25.0  -5.1  42.50
02885734  6510 182 216 188  70    00  54 +25.9   89.0 +25.0  -5.1  42.50
02886134  6561 193 220 188  80    00  55 +25.7   92.0 +25.0  -5.0  42.50
02886534  6720 183 220 146  70    00  55 +27.7   88.0 +25.0  -5.0 ECU.
02886934  6747 121  87  26  00    00  80  +8.9   11.0 ECU.   -5.5 ECU.
02887334  6138  65 101  26  00    00 166 +10.3   11.0 ECU.   -5.5 ECU.
02887734  5827  79 185 141  10    00 177 +34.2   45.0 ECU.   -5.1 ECU.
02888134  4629 145 198 183  30    00  39 +17.0   56.0 ECU.   -5.6  48.60
02888534  4952 175 204 185  60    00  54 +17.5   71.0 ECU.   -5.3  46.00
02888934  5042 200 206 186  90    00  54 +21.0   73.0 +23.0  -5.3  46.00
02889334  5050 194 207 186  80    00  55 +21.1   75.0 +23.0  -5.3  46.00
02889734  5175 199 208 188  90    00  67 +21.9   74.0 +23.0  -5.3  46.00
02890134  5324 205 209 188  90    00  54 +21.9   78.0 +23.0  -5.2  43.50
02890534  5359 205 211 188  90    00  55 +22.1   79.0 +23.0  -5.2  43.50
02890934  5518 183 213 188  70    00  56 +21.7   81.0 +23.0  -5.2  43.50
02891334  5621 193 212 187  80    00  55 +22.2   83.0 +23.0  -5.1  42.50
02891734  5787 199 213 187  90    00  53 +22.2   84.0 +23.0  -5.1  42.50
02892134  5757 185 214 187  70    00  54 +22.5   87.0 +25.0  -5.1  42.50
02892534  5797 189 214 187  80    00  55 +22.9   87.0 +24.0  -5.1  42.50
02892934  5868 205 214 187  90    00  54 +23.1   88.0 +24.0  -5.1  42.50
02893334  5984 186 215 188  70    00  55 +23.8   88.0 +25.0  -5.1  42.50
02893734  6105 191 216 188  80    00  54 +24.6   88.0 +25.0  -5.1  42.50
02894134  6116 208 217 189 100    00  55 +24.2   89.0 +25.0  -5.1  42.50
02894534  6242 193 218 189  80    00  54 +26.0   89.0 +25.0  -5.1  42.50
02894934  6242 188 218 189  80    00  55 +25.8   88.0 +25.0  -5.1  42.50
02895334  6435 190 219 188  80    00  55 +25.7   90.0 +25.0  -5.0  42.50
02895734  6410 196 216 189  80    00  55 +25.5   91.0 +25.0  -5.0  42.50
02896134  6720 204 220 189  90    00  55 +25.7   92.0 +25.0  -5.0  42.50
02896534  6385 189 133  26  00    00  60  +9.1   10.0 ECU.   -5.5 ECU.
02896934  6060  71  92  27  00    00 100 +10.5   10.0 ECU.   -5.5 ECU.
02897334  5042  73 182 132  00    00 188 +16.8   40.0 ECU.   -5.5 ECU.
02897734  4668 151 195 186  40    00  42 +18.4   51.0 ECU.   -5.6  48.60
02898134  4816 169 202 187  60    00  54 +16.9   68.0 ECU.   -5.3  48.00
02898534  4768 191 202 187  80    00  56 +17.1   72.0 +23.0  -5.3  48.00
02898934  4837 200 204 188  90    00  55 +17.8   72.0 +23.0  -5.3  48.00
02899334  4837 198 201 188  90    00  55 +18.2   71.0 +23.0  -5.3  48.00
02899734  4945 198 204 188  90    00  55 +18.4   70.0 +23.0  -5.3  48.00
02900134  4982 201 202 187  90    00  55 +18.1   71.0 +23.0  -5.3  48.00
02900534  4975 184 204 188  70    00  56 +19.5   72.0 +23.0  -5.3  46.00
02900934  5065 192 203 188  80    00  55 +19.5   72.0 +23.0  -5.3  46.00
02901334  5005 204 206 190  90    00  56 +20.3   72.0 +23.0  -5.3  46.00
02901734  5175 196 202 189  80    00  56 +19.5   73.0 +23.0  -5.3  46.00
02902134  5200 200 204 188  90    00  56 +21.4   74.0 +23.0  -5.3  46.00
02902534  5144 200 208 195  90    00  57 +21.3   76.0 +23.0  -5.3  46.00
02902934  5257 203 205 188  90    00  56 +21.7   76.0 +23.0  -5.2  43.50
02903334  5257 191 208 189  80    00  57 +21.6   78.0 +23.0  -5.2  43.50
02903734  5274 208 208 189 100    00  56 +21.7   79.0 +23.0  -5.2  43.50
02904134  5316 185 209 190  70    00  57 +21.8   79.0 +23.0  -5.2  43.50
02904534  5402 205 211 190  90    00  58 +21.5   80.0 +23.0  -5.2  43.50
02904934  5420 188 211 190  80    00  58 +21.3   81.0 +23.0  -5.2  43.50
02905334  5509 188 212 190  80    00  57 +21.5   81.0 +23.0  -5.2  43.50
02905734  5500 207 210 190 100    00  57 +22.0   83.0 +23.0  -5.1  42.50
02906134  5574 201 212 188  90    00  57 +21.8   85.0 +23.0  -5.1  42.50
02906534  5630 189 212 190  80    00  58 +22.1   85.0 +24.0  -5.1  42.50
02906934  5640 193 213 190  80    00  58 +21.9   85.0 +23.0  -5.1  42.50
02907334  5611 190 212 190  80    00  59 +22.2   86.0 +23.0  -5.1  42.50
02907734  5707 195 213 189  80    00  58 +22.1   87.0 +23.0  -5.1  42.50
02908134  5727 206 215 190  90    00  58 +22.4   87.0 +23.0  -5.1  42.50
02908534  5777 212 214 189 100    00  59 +22.8   88.0 +24.0  -5.1  42.50
02908934  5757 187 214 191  70    00  60 +22.3   88.0 +24.0  -5.1  42.50
02909334  5797 183 213 189  70    00  58 +22.7   88.0 +24.0  -5.1  42.50
02909734  5899 203 217 190  90    00  59 +22.7   89.0 +24.0  -5.1  42.50
02910134  5899 207 214 190 100    00  59 +22.9   88.0 +24.0  -5.1  42.50
02910534  6006 188 217 190  80    00  59 +23.2   89.0 +24.0  -5.1  42.50
02910934  5995 197 216 190  80    00  60 +23.3   89.0 +25.0  -5.1  42.50
02911334  6006 200 216 191  90    00  60 +23.3   89.0 +25.0  -5.1  42.50
02911734  6071 188 217 190  80    00  60 +23.6   89.0 +25.0  -5.1  42.50
02912134  6184 209 217 191 100    00  61 +24.1   90.0 +25.0  -5.1  42.50
02912534  6071 198 216 189  90    00  61 +24.1   90.0 +25.0  -5.1  42.50
02912934  6093 211 217 190 100    00  60 +24.0   91.0 +25.0  -5.1  42.50
02913334  6116 199 218 192  90    00  60 +23.9   90.0 +25.0  -5.1  42.50
02913734  6242 210 219 190 100    00  61 +23.9   91.0 +25.0  -5.1  42.50
02914134  6301 190 217 191  80    00  60 +25.7   91.0 +25.0  -5.1  42.50
02914534  6253 190 220 190  80    00  61 +25.8   90.0 +25.0  -5.1  42.50
02914934  6253 198 219 192  90    00  62 +25.8   90.0 +25.0  -5.1  42.50
02915334  6301 203 218 191  90    00  61 +25.8   92.0 +25.0  -5.1  42.50
02915734  6447 187 216 189  70    00  61 +26.0   91.0 +25.0  -5.1  42.50
02916134  6385 206 218 190  90    00  61 +25.5   92.0 +25.0  -5.1  42.50
02916534  6397 201 219 190  90    00  61 +25.4   92.0 +25.0  -5.1  42.50
02916934  6523 189 219 190  80    00  61 +25.6   92.0 +25.0  -5.1  42.50
02917334  6548 201 218 191  90    00  62 +25.5   94.0 +25.0  -5.0  42.50
02917734  6523 187 217 191  70    00  61 +25.6   93.0 +25.0  -5.0  42.50
02918134  6485 194 219 196  80    00  62 +25.7   92.0 +25.0  -5.0  42.50
02918534  6497 187  93  25  00    00  68 +10.0   31.0 ECU.   -5.5 ECU.
02918934  6049  66  96  25  00    00 109 +10.6   31.0 ECU.   -5.5 ECU.
02919334  5640  64 106  26  00    00 178 +10.6   31.0 ECU.   -5.5 ECU.
02919734  5200  67 108  27  00    00 180 +10.7   31.0 ECU.   -5.5 ECU.
02920134  4708  66 108  27  00    00 180 +10.7   31.0 ECU.   -5.5 ECU.
02920534  4668  62 104  27  00    00 180 +10.8   31.0 ECU.   -5.5 ECU.
02920934  4486  62 101  27  00    00 179 +10.7   31.0 ECU.   -5.5 ECU.
02921334  4415  59  97  26  00    00 178 +10.7   31.0 ECU.   -5.5 ECU.
02921734  4340  58  95  27  00    00 180 +10.9   31.0 ECU.   -5.5 ECU.
02922134  4198  59  90  26  00    00 178 +11.0   31.0 ECU.   -5.5 ECU.
02922534  4130  61  88  27  00    00 180 +11.1   31.0 ECU.   -5.5 ECU.
02922934  4030  55  83  26  00    00 180 +10.9   31.0 ECU.   -5.5 ECU.
02923334  3880  55  81  26  00    00 179 +11.1   31.0 ECU.   -5.5 ECU.
02923734  3783  57  79  25  00    00 178 +11.2   31.0 ECU.   -5.5 ECU.
02924134  3635  57  78  26  00    00 179 +11.1   31.0 ECU.   -5.5 ECU.
02924534  3523  56  75  26  00    00 178 +11.1   31.0 ECU.   -5.5 ECU.
02924934  3360  55  76  26  00    00 179 +11.4   31.0 ECU.   -5.5 ECU.
02925334  3186  56  74  25  00    00 178 +11.3   31.0 ECU.   -5.5 ECU.
02925734  3129  56  74  27  00    00 178 +11.4   31.0 ECU.   -5.5 ECU.
02926134  2934  57  74  26  00    00 178 +11.5   31.0 ECU.   -5.5 ECU.
02926534  2844  56  73  26  00    00 180 +11.7   31.0 ECU.   -5.5 ECU.
02926934  2721  57  71  25  00    00 178 +11.6   31.0 ECU.   -5.5 ECU.
02927334  2681  56  73  26  00    00 178 +11.6   31.0 ECU.   -5.5 ECU.
02927734  2645  57  73  27  00    00 178 +11.6   31.0 ECU.   -5.5 ECU.
02928134  2656  57  72  27  00    00 178 +11.8   31.0 ECU.   -5.5 ECU.
02928534  2608  55  72  25  00    00 178 +11.6   31.0 ECU.   -5.5 ECU.
02928934  2614  57  71  25  00    00 179 +11.7   31.0 ECU.   -5.5 ECU.
02929334  2612  55  72  26  00    00 180 +11.6   31.0 ECU.   -5.5 ECU.
02929734  2614  55  71  26  00    00 179 +11.7   31.0 ECU.   -5.5 ECU.
02930134  2577  56  72  26  00    00 179 +11.5   31.0 ECU.   -5.5 ECU.
02930534  2590  54  71  25  00    00 178 +11.6   31.0 ECU.   -5.5 ECU.
Old 10-02-2002, 11:26 PM   #3
DiMensionX
Member#: 23517
Code:
Log 2 10.2.02
04348674  1260 112  98  81  00    00 110 +20.7    4.0 ECU.   -9.5 ECU.
04348934  1664 109 109  84  00    00 101 +29.8   16.0 ECU.   -5.5 ECU.
04349334  1997 111 120 106  00    00  95 +33.6    6.0 ECU.   -5.5 ECU.
04349734  1751 113 115 111  00    00 145 +30.4    5.0 ECU.   -5.5 ECU.
04350134  1722 115 116 127  00    00  75 +29.5    5.0 ECU.   -5.5 ECU.
04350534  1615 117 112 138  10    00 144 +26.4    6.0 ECU.   -6.8 ECU.
04350934  1563 115 114 153  10    00 137 +26.1   10.0 ECU.   -6.8 ECU.
04351334  1482 118 114 167  10    00  98 +25.9    7.0 ECU.   -6.8 100.00
04351734  1737 118 113 181  10    00 109 +27.6   15.0 ECU.   -6.8 100.00
04352134  1916 119 120 184  10    00 105 +31.6    8.0 ECU.   -6.8 100.00
04352534  2198 120 126 185  10    00 122 +33.5   10.0 ECU.   -6.1 100.00
04352934  2438 122 128 183  10    00 121 +33.8   11.0 ECU.   -6.1  95.00
04353334  2666 122 133 185  10    00 118 +32.2   13.0 ECU.   -5.9  95.00
04353734  2960 123 139 186  10    00 123 +32.6   15.0 ECU.   -5.9  95.00
04354134  3217 128 149 188  10    00 117 +29.5   18.0 ECU.   -5.9  50.00
04354534  3534 132 158 189  20    00 105 +28.7   21.0 ECU.   -5.9  43.50
04354934  3949 139 170 189  30    00 103 +27.8   26.0 ECU.   -5.9  43.50
04355334  4273 143 173 189  30    00  99 +23.9   33.0 ECU.   -5.4  45.90
04355734  4708 160 186 189  50    00  59 +19.1   48.0 ECU.   -5.3  48.00
04356134  5216 175 198 190  60    00  46 +22.5   59.0 ECU.   -5.2  43.50
04356534  5837 193 206 190  80    00  56 +22.3   69.0 +23.0  -5.1  42.50
04356934  6523 182 209 188  70    00  54 +27.1   75.0 +25.0  -5.1  42.50
04357334  6666 179 210 188  70    00  53 +29.1   79.0 +25.0  -5.0  42.50
04357734  7092 184 213 174  70    00  55 +32.2   51.0 +25.0  -5.0  42.50
04358134  6640 119  88  26  00    00  93 +10.1   33.0 ECU.   -5.5 ECU.
04358534  6049  65 108  57  00    00 178 +41.5   22.0 ECU.   -5.5 ECU.
04358934  5020 133 191 187  20    00 101 +24.9   47.0 ECU.   -5.3  46.00
04359334  4450 153 184 187  40    00  55 +16.7   48.0 ECU.   -5.6  48.60
04359734  4616 181 191 188  70    00  55 +16.4   57.0 +21.0  -5.6  48.00
04360134  4796 189 197 190  80    00  55 +18.4   61.0 +23.0  -5.3  48.00
04360534  5096 192 199 193  80    00  55 +20.0   63.0 +23.0  -5.3  46.00
04360934  5241 184 202 193  70    00  55 +21.3   65.0 +23.0  -5.2  43.50
04361334  5411 186 206 192  70    00  55 +21.7   70.0 +23.0  -5.2  43.50
04361734  5668 180 208 193  70    00  54 +22.1   74.0 +23.0  -5.1  42.50
04362134  5777 193 208 192  80    00  54 +22.5   76.0 +24.0  -5.1  42.50
04362534  6060 181 211 193  70    00  55 +23.7   81.0 +25.0  -5.1  42.50
04362934  6172 177 212 192  60    00  55 +24.0   83.0 ECU.   -5.1  42.50
04363334  6301 180 214 192  70    00  54 +26.9   86.0 +25.0  -5.1  42.50
04363734  6472 191 216 193  80    00  55 +27.6   87.0 +25.0  -5.0  42.50
04364134  6613 174 216 193  60    00  55 +28.3   87.0 ECU.   -5.0  42.50
04364534  6844 192 217 141  80    00  55 +31.6   33.0 +25.0  -5.0 ECU.
04364934  6410  90  83  25  00    00  75 +10.1    9.0 ECU.   -5.5 ECU.
04365334  6038  61 102  26  00    00 178 +12.2    2.0 ECU.   -5.5 ECU.
04365734  5437  91 186 142  10    00 172 +20.9   44.0 ECU.   -5.2 ECU.
04366134  5020 150 192 184  40    00  36 +21.6   56.0 ECU.   -5.3  46.00
04366534  5120 171 203 189  60    00  54 +19.3   66.0 ECU.   -5.3  46.00
04366934  5020 193 202 189  80    00  53 +19.5   68.0 +23.0  -5.3  46.00
04367334  5151 190 204 190  80    00  54 +21.9   69.0 +23.0  -5.3  46.00
04367734  5333 204 206 190  90    00  54 +22.2   71.0 +23.0  -5.2  43.50
04368134  5350 196 208 191  80    00  54 +22.1   73.0 +23.0  -5.2  43.50
04368534  5446 196 207 190  80    00  55 +22.0   74.0 +23.0  -5.2  43.50
04368934  5602 193 209 192  80    00  53 +22.4   77.0 +23.0  -5.1  42.50
04369334  5678 179 209 190  70    00  54 +22.4   78.0 +23.0  -5.1  42.50
04369734  5737 186 212 190  70    00  54 +22.5   80.0 +25.0  -5.1  42.50
04370134  5878 195 213 190  80    00  54 +23.2   82.0 +24.0  -5.1  42.50
04370534  5889 197 213 190  80    00  54 +23.6   83.0 +24.0  -5.1  42.50
04370934  5941 198 213 190  90    00  54 +24.1   85.0 +24.0  -5.1  42.50
04371334  5995 193 213 191  80    00  54 +24.4   87.0 +24.0  -5.1  42.50
04371734  6082 187 212 190  70    00  55 +24.5   87.0 +25.0  -5.1  42.50
04372134  6218 179 215 190  70    00  54 +26.6   88.0 +25.0  -5.1  42.50
04372534  6230 182 214 190  70    00  56 +26.1   88.0 +25.0  -5.1  42.50
04372934  6337 200 216 190  90    00  54 +26.7   89.0 +25.0  -5.1  42.50
04373334  6510 201 217 192  90    00  55 +27.0   90.0 +25.0  -5.0  42.50
04373734  6422 180 215 192  70    00  55 +27.2   92.0 +25.0  -5.0  42.50
04374134  6561 179 217 192  70    00  54 +27.0   92.0 +25.0  -5.0  42.50
04374534  6523 181 219 180  70    00  56 +26.7   90.0 +25.0  -5.0  42.50
04374934  6734 180 218 184  70    00  54 +27.5   89.0 +25.0  -5.0  42.50
04375334  6349 121  79  27  00    00  94 +10.0    9.0 ECU.   -5.5 ECU.
04375734  5920  67 136  79  00    00 127 +39.1   20.0 ECU.   -5.5 ECU.
04376134  4701 132 196 186  20    00  53 +16.7   51.0 ECU.   -5.6  48.60
04376534  4866 170 198 188  60    00  50 +16.5   64.0 ECU.   -5.3  48.00
04376934  4782 192 200 189  80    00  54 +15.7   68.0 +23.0  -5.3  48.00
04377334  4880 194 200 191  80    00  55 +16.7   67.0 +23.0  -5.3  48.00
04377734  4960 195 200 190  80    00  54 +17.1   67.0 +23.0  -5.3  46.00
04378134  4952 203 201 190  90    00  54 +16.7   67.0 +23.0  -5.3  48.00
04378534  5050 197 202 191  80    00  55 +17.0   67.0 +23.0  -5.3  46.00
04378934  5005 181 201 190  70    00  56 +18.1   68.0 +23.0  -5.3  46.00
04379334  5050 189 202 190  80    00  56 +18.2   69.0 +23.0  -5.3  46.00
04379734  5096 197 203 191  80    00  56 +19.5   70.0 +23.0  -5.3  46.00
04380134  5136 198 204 191  90    00  55 +19.9   71.0 +23.0  -5.3  46.00
04380534  5232 186 204 191  70    00  55 +21.7   72.0 +23.0  -5.3  46.00
04380934  5208 185 204 191  70    00  56 +21.4   72.0 +23.0  -5.2  43.50
04381334  5282 194 205 191  80    00  56 +21.4   73.0 +23.0  -5.2  43.50
04381734  5341 187 204 190  70    00  55 +20.8   73.0 +23.0  -5.2  43.50
04382134  5385 195 207 192  80    00  56 +21.3   75.0 +23.0  -5.2  43.50
04382534  5333 197 207 192  80    00  56 +20.9   75.0 +23.0  -5.2  43.50
04382934  5437 182 208 191  70    00  57 +21.3   77.0 +23.0  -5.2  43.50
04383334  5491 181 210 192  70    00  57 +21.6   78.0 +23.0  -5.1  42.50
04383734  5500 191 209 192  80    00  57 +21.2   79.0 +23.0  -5.1  42.50
04384134  5527 203 209 191  90    00  57 +21.3   80.0 +23.0  -5.1  42.50
04384534  5546 194 211 190  80    00  57 +21.6   81.0 +23.0  -5.1  42.50
04384934  5583 194 211 193  80    00  58 +21.3   81.0 +23.0  -5.1  42.50
04385334  5621 197 212 191  80    00  57 +21.6   82.0 +23.0  -5.1  42.50
04385734  5630 194 214 193  80    00  57 +21.6   82.0 +23.0  -5.1  42.50
04386134  5757 183 212 193  70    00  57 +23.1   83.0 +24.0  -5.1  42.50
04386534  5688 181 210 192  70    00  57 +23.3   83.0 +23.0  -5.1  42.50
04386934  5747 198 213 192  90    00  58 +23.1   84.0 +23.0  -5.1  42.50
04387334  5797 190 214 192  80    00  57 +23.8   84.0 +24.0  -5.1  42.50
04387734  5787 199 213 192  90    00  57 +23.7   85.0 +25.0  -5.1  42.50
04388134  5847 188 214 193  80    00  57 +23.7   87.0 +24.0  -5.1  42.50
04388534  6006 194 212 197  80    00  58 +24.0   86.0 +24.0  -5.1  42.50
04388934  5995 179 218 193  70    00  58 +24.5   87.0 +25.0  -5.1  42.50
04389334  5963 183 214 192  70    00  59 +24.4   87.0 +24.0  -5.1  42.50
04389734  5963 210 215 192 100    00  58 +24.8   87.0 +24.0  -5.1  42.50
04390134  5995 203 214 192  90    00  59 +24.7   87.0 +25.0  -5.1  42.50
04390534  6161 198 214 192  90    00  58 +24.7   87.0 +25.0  -5.1  42.50
04390934  6184 200 214 192  90    00  58 +24.6   88.0 +25.0  -5.1  42.50
04391334  6138 206 217 192  90    00  58 +24.3   88.0 +25.0  -5.1  42.50
04391734  6116 200 214 192  90    00  59 +24.5   88.0 +25.0  -5.1  42.50
04392134  6172 197 216 192  80    00  59 +26.5   88.0 +25.0  -5.1  42.50
04392534  6301 192 216 192  80    00  59 +24.2   88.0 +25.0  -5.1  42.50
04392934  6265 194 216 193  80    00  59 +26.5   88.0 +25.0  -5.1  42.50
04393334  6253 191 218 191  80    00  59 +26.4   89.0 +25.0  -5.1  42.50
04393734  6410 204 216 191  90    00  59 +26.1   88.0 +25.0  -5.1  42.50
04394134  6242 206 216 192  90    00  60 +26.6   88.0 +25.0  -5.1  42.50
04394534  6361 190 216 192  80    00  60 +26.5   88.0 +25.0  -5.1  42.50
04394934  6397 188 218 192  80    00  61 +26.1   89.0 +25.0  -5.1  42.50
04395334  6485 186 218 192  70    00  60 +26.3   90.0 +25.0  -5.0  42.50
04395734  6422 205 217 193  90    00  60 +26.5   89.0 +25.0  -5.0  42.50
04396134  6548 207 215 193 100    00  59 +26.3   91.0 +25.0  -5.0  42.50
04396534  6600 204 220 192  90    00  59 +26.9   90.0 +25.0  -5.0  42.50
04396934  7077 190 120  25  00    00  63  +9.9   17.0 ECU.   -5.5 ECU.
04397334  6472  71  94  27  00    00 100 +10.0   17.0 ECU.   -5.5 ECU.
04397734  6184  70 170  97  00    00 179 +39.1   35.0 ECU.   -5.5 ECU.
04398134  4823 131 194 184  20    00  40 +16.9   56.0 ECU.   -5.3  46.00
04398534  4887 162 202 189  50    00  52 +16.4   68.0 ECU.   -5.3  48.00
04398934  4967 190 206 190  80    00  55 +17.9   71.0 +23.0  -5.3  46.00
04399334  4967 196 204 190  80    00  55 +17.9   70.0 +23.0  -5.3  46.00
04399734  4960 192 204 190  80    00  57 +17.3   69.0 +23.0  -5.3  46.00
04400134  4982 196 204 191  80    00  57 +18.1   70.0 +23.0  -5.3  46.00
04400534  4967 200 201 190  90    00  58 +18.2   69.0 +23.0  -5.3  46.00
04400934  5089 190 203 190  80    00  60 +17.4   70.0 +23.0  -5.3  46.00
04401334  5020 201 202 190  90    00  59 +18.8   69.0 +23.0  -5.3  46.00
04401734  5020 200 201 189  90    00  59 +19.2   70.0 +23.0  -5.3  46.00
04402134  5096 205 204 189  90    00  59 +18.1   71.0 +23.0  -5.3  46.00
04402534  5089 187 203 189  70    00  60 +19.2   71.0 +23.0  -5.3  46.00
04402934  5136 195 203 190  80    00  59 +19.1   71.0 +23.0  -5.3  46.00
04403334  5112 194 203 190  80    00  61 +20.6   70.0 +23.0  -5.3  46.00
04403734  5159 204 204 190  90    00  61 +20.6   71.0 +23.0  -5.3  46.00
04404134  5120 206 204 190  90    00  61 +20.5   72.0 +23.0  -5.3  46.00
04404534  5184 206 205 189  90    00  60 +20.6   73.0 +23.0  -5.3  46.00
04404934  5144 194 203 190  80    00  60 +19.5   73.0 +23.0  -5.3  46.00
04405334  5136 196 204 190  80    00  61 +20.9   72.0 +23.0  -5.3  46.00
04405734  5144 184 206 191  70    00  61 +20.9   73.0 +23.0  -5.3  46.00
04406134  5200 208 204 190 100    00  61 +21.2   73.0 +23.0  -5.3  46.00
04406534  5224 201 206 191  90    00  62 +20.7   73.0 +23.0  -5.2  43.50
04406934  5208 207 205 190 100    00  61 +21.2   74.0 +23.0  -5.3  46.00
04407334  5005 186 199  64  00    00  62 +38.9    5.0 ECU.   -5.5 ECU.
04407734  5167  88  85  26  00    00  89 +10.6    5.0 ECU.   -5.5 ECU.
04408134  5175  66 103  26  00    00 154 +10.7    5.0 ECU.   -5.5 ECU.
04408534  5020  61 104  26  00    00 180 +10.7    5.0 ECU.   -5.5 ECU.
04408934  4880  62 106  26  00    00 180 +10.8    5.0 ECU.   -5.5 ECU.
04409334  4789  61 103  26  00    00 178 +10.8    5.0 ECU.   -5.5 ECU.
04409734  4572  63 101  26  00    00 178 +10.8    5.0 ECU.   -5.5 ECU.
Old 10-02-2002, 11:29 PM   #4
DiMensionX
Member#: 23517
Code:
Log 3 10.2.02
05643836  1895 111 112  86  00    00 133 +32.4   17.0 ECU.   -5.5 ECU.
05644134  2103 113 122 114  00    00  59 +34.8    8.0 ECU.   -5.5 ECU.
05644534  2223 114 125 130  00    00 112 +34.7   13.0 ECU.   -5.5 ECU.
05644934  2063 115 125 153  10    00 107 +32.6    9.0 ECU.   -6.1 ECU.
05645334  1774 118 117 157  10    00 115 +28.7    8.0 ECU.   -6.8 100.00
05645734  1598 119 110 171  10    00  95 +24.3  222.0 ECU.   -6.8 100.00
05646134  1993 120 124 186  10    00  76 +32.9    9.0 ECU.   -6.8 100.00
05646534  2210 120 124 188  10    00 107 +33.0   10.0 ECU.   -6.1 100.00
05646934  2377 122 128 189  10    00 107 +33.8   11.0 ECU.   -6.1  95.00
05647334  2699 124 136 190  10    00 107 +32.6   13.0 ECU.   -5.9  95.00
05647734  2952 123 141 190  10    00 113 +32.2   15.0 ECU.   -5.9  95.00
05648134  3217 129 147 190  20    00 107 +30.5   18.0 ECU.   -5.9  46.80
05648534  3542 126 153 191  10    00 100 +28.7   21.0 ECU.   -5.9  43.50
05648934  4079 132 163 192  20    00  96 +28.1   26.0 ECU.   -5.9  44.50
05649334  4450 148 177 191  30    00  92 +23.9   32.0 ECU.   -5.4  45.90
05649734  4668 152 188 191  40    00  51 +18.5   47.0 ECU.   -5.3  48.00
05650134  5249 175 198 191  60    00  43 +21.3   59.0 ECU.   -5.2  43.50
05650534  5707 178 208 190  70    00  56 +21.5   70.0 +23.0  -5.1  42.50
05650934  6161 179 212 191  70    00  56 +23.9   76.0 +25.0  -5.1  42.50
05651334  6761 175 215 190  60    00  53 +28.2   80.0 ECU.   -5.0  42.50
05651734  7077 190 217 143  80    00  54 +34.1   79.0 +25.0  -5.0 ECU.
05652134  6523  85  77  26  00    00  88  +9.0    7.0 ECU.   -5.5 ECU.
05652534  5984  64 182 176  10    00 182 +35.9   41.0 ECU.   -5.1  42.50
05652934  4363 148 191 186  30    00  40 +17.7   50.0 ECU.   -5.4  45.90
05653334  4535 173 192 191  60    00  55 +16.6   52.0 ECU.   -5.6  48.60
05653734  4721 180 196 191  70    00  56 +17.6   57.0 +13.0  -5.6  48.60
05654134  4830 190 198 192  80    00  55 +18.2   61.0 +15.0  -5.3  48.00
05654534  5042 186 202 193  70    00  55 +20.1   63.0 +15.0  -5.3  46.00
05654934  5184 191 204 194  80    00  55 +20.6   67.0 +23.0  -5.2  43.50
05655334  5420 196 206 193  80    00  54 +21.6   69.0 +23.0  -5.2  43.50
05655734  5574 173 208 192  60    00  54 +21.4   73.0 ECU.   -5.1  42.50
05656134  5797 183 208 189  70    00  54 +22.6   77.0 +24.0  -5.1  42.50
05656534  5973 172 211 192  60    00  55 +23.6   80.0 ECU.   -5.1  42.50
05656934  6230 191 212 191  80    00  54 +24.4   82.0 +25.0  -5.1  42.50
05657334  6325 181 212 191  70    00  54 +27.1   85.0 +25.0  -5.1  42.50
05657734  6459 176 214 191  60    00  54 +27.5   87.0 ECU.   -5.0  42.50
05658134  6535 197 216 191  80    00  55 +27.3   88.0 +25.0  -5.0  42.50
05658534  6887 181 217 153  70    00  55 +30.9   73.0 +25.0  -5.0 ECU.
05658934  6666  88  89  26  00    00  67 +10.0   29.0 ECU.   -5.5 ECU.
05659334  6027  64 134  68  00    00 173 +41.7   24.0 ECU.   -5.5 ECU.
05659734  5333 130 193 182  20    00  58 +26.6   53.0 ECU.   -5.2  43.50
05660134  5012 159 200 188  50    00  48 +19.3   64.0 ECU.   -5.3  48.00
05660534  4967 199 202 188  90    00  53 +19.3   68.0 +23.0  -5.3  48.00
05660934  5096 194 202 188  80    00  55 +20.7   68.0 +23.0  -5.3  46.00
05661334  5224 195 204 189  80    00  54 +21.7   68.0 +23.0  -5.3  46.00
05661734  5232 192 204 189  80    00  54 +22.0   70.0 +23.0  -5.2  43.50
05662134  5324 198 205 191  90    00  53 +21.9   73.0 +23.0  -5.2  43.50
05662534  5411 193 206 190  80    00  53 +22.5   74.0 +23.0  -5.2  43.50
05662934  5491 193 208 190  80    00  54 +22.4   75.0 +23.0  -5.1  42.50
05663334  5621 197 209 190  80    00  54 +22.1   77.0 +23.0  -5.1  42.50
05663734  5698 181 210 190  70    00  55 +22.7   79.0 +23.0  -5.1  42.50
05664134  5757 202 212 190  90    00  54 +23.2   81.0 +24.0  -5.1  42.50
05664534  5941 181 210 190  70    00  55 +23.5   82.0 +25.0  -5.1  42.50
05664934  5931 204 211 190  90    00  55 +24.0   84.0 +24.0  -5.1  42.50
05665334  6105 189 212 190  80    00  55 +24.0   84.0 +25.0  -5.1  42.50
05665734  6049 183 213 189  70    00  55 +24.0   86.0 +25.0  -5.1  42.50
05666134  6242 179 214 189  70    00  54 +24.1   87.0 +25.0  -5.1  42.50
05666534  6161 187 213 190  70    00  55 +26.5   88.0 +25.0  -5.1  42.50
05666934  6385 194 214 190  80    00  55 +25.9   89.0 +25.0  -5.1  42.50
05667334  6472 180 214 190  70    00  54 +26.6   89.0 +25.0  -5.1  42.50
05667734  6325 200 215 192  90    00  54 +26.9   89.0 +25.0  -5.0  42.50
05668134  6535 180 216 190  70    00  54 +27.0   77.0 +25.0  -5.0  42.50
05668534  6253 147  86  27  00    00  70 +10.4   31.0 ECU.   -5.5 ECU.
05668934  5698  70 187 183  10    00 176 +30.7   44.0 ECU.   -5.1  42.50
05669334  4803 138 192 190  20    00  42 +16.3   57.0 ECU.   -5.3  48.60
05669734  4688 183 200 192  70    00  56 +14.1   65.0 +21.0  -5.6  48.60
05670134  4796 196 200 192  80    05  55 +14.7   65.0 +15.0  -5.3  48.00
05670534  4810 194 201 192  80    00  54 +15.3   66.0 +15.0  -5.3  48.00
05670934  4761 190 200 191  80    00  54 +15.8   66.0 +15.0  -5.3  48.00
05671334  4789 206 200 192  90    00  55 +15.9   65.0 +15.0  -5.3  48.00
05671734  4967 193 199 193  80    00  56 +16.9   65.0 +23.0  -5.3  48.00
05672134  4909 190 203 192  80    00  55 +17.6   66.0 +23.0  -5.3  48.00
05672534  4901 191 200 191  80    00  55 +17.4   66.0 +23.0  -5.3  48.00
05672934  5073 199 202 192  90    00  56 +17.0   67.0 +23.0  -5.3  46.00
05673334  5005 190 202 192  80    00  55 +19.3   67.0 +23.0  -5.3  46.00
05673734  5020 197 202 192  80    00  57 +19.4   68.0 +23.0  -5.3  46.00
05674134  5081 192 202 191  80    00  55 +20.2   68.0 +23.0  -5.3  46.00
05674534  5128 200 203 191  90    00  57 +20.7   69.0 +23.0  -5.3  46.00
05674934  5257 190 202 191  80    00  57 +20.8   70.0 +23.0  -5.3  46.00
05675334  5241 192 204 192  80    00  56 +20.9   71.0 +23.0  -5.2  43.50
05675734  5241 183 205 191  70    00  56 +21.1   71.0 +23.0  -5.2  43.50
05676134  5291 200 206 192  90    00  56 +21.0   72.0 +23.0  -5.2  43.50
05676534  5333 184 207 191  70    00  56 +20.9   73.0 +23.0  -5.2  43.50
05676934  5359 181 206 192  70    00  56 +20.9   75.0 +23.0  -5.2  43.50
05677334  5393 181 207 191  70    00  56 +21.3   75.0 +23.0  -5.2  43.50
05677734  5455 189 206 192  80    00  58 +21.0   76.0 +23.0  -5.2  43.50
05678134  5473 182 208 192  70    00  58 +21.2   77.0 +23.0  -5.2  43.50
05678534  5630 177 210 193  60    00  58 +22.6   77.0 ECU.   -5.1  42.50
05678934  5509 184 208 191  70    00  57 +22.3   78.0 +23.0  -5.1  42.50
05679334  5640 184 208 190  70    00  57 +22.7   80.0 +24.0  -5.1  42.50
05679734  5546 189 213 192  80    00  57 +22.3   81.0 +15.0  -5.1  42.50
05680134  5640 181 211 192  70    00  58 +22.8   82.0 +15.0  -5.1  42.50
05680534  5688 185 213 192  70    00  58 +22.4   85.0 +15.0  -5.1  42.50
05680934  5659 211 213 191 100    00  58 +22.8   85.0 +23.0  -5.1  42.50
05681334  6038 211 214 192 100    00  58 +23.0   85.0 +24.0  -5.1  42.50
05681734  5737 187 213 192  70    00  58 +23.4   85.0 +23.0  -5.1  42.50
05682134  5787 181 214 190  70    00  59 +23.7   85.0 +24.0  -5.1  42.50
05682534  5847 188 212 192  80    00  58 +24.0   85.0 +24.0  -5.1  42.50
05682934  5868 182 212 191  70    00  58 +24.1   86.0 +24.0  -5.1  42.50
05683334  5931 199 216 192  90    00  59 +24.1   86.0 +24.0  -5.1  42.50
05683734  5941 194 214 191  80    00  59 +25.0   86.0 +24.0  -5.1  42.50
05684134  6127 203 214 191  90    00  58 +24.9   87.0 +25.0  -5.1  42.50
05684534  6127 190 214 191  80    00  59 +24.7   87.0 +25.0  -5.1  42.50
05684934  6093 201 214 191  90    00  58 +24.8   87.0 +25.0  -5.1  42.50
05685334  6105 183 215 190  70    00  58 +24.6   87.0 +25.0  -5.1  42.50
05685734  6105 186 215 191  70    00  59 +24.5   87.0 +25.0  -5.1  42.50
05686134  6242 197 216 191  80    00  59 +24.4   88.0 +25.0  -5.1  42.50
05686534  6161 199 214 190  90    00  59 +24.1   88.0 +25.0  -5.1  42.50
05686934  6325 187 215 190  70    00  59 +24.1   88.0 +25.0  -5.1  42.50
05687334  6337 183 216 190  70    00  59 +24.0   88.0 +25.0  -5.1  42.50
05687734  6265 183 216 192  70    00  59 +26.6   88.0 +25.0  -5.1  42.50
05688134  6242 192 218 191  80    00  60 +26.2   87.0 +25.0  -5.1  42.50
05688534  6349 195 218 191  80    00  59 +26.9   88.0 +25.0  -5.1  42.50
05688934  6325 191 200  60  00    00  60 +41.3   30.0 ECU.   -5.5 ECU.
05689334  5995  73  85  26  00    00  77 +10.6   30.0 ECU.   -5.5 ECU.
05689734  5611  64 103  26  00    00 157 +10.5   30.0 ECU.   -5.5 ECU.
05690134  5151  62 106  26  00    00 179 +10.6   30.0 ECU.   -5.5 ECU.
05690534  4782  67 107  26  00    00 179 +10.8   30.0 ECU.   -5.5 ECU.
05690934  4504  63 104  26  00    00 179 +10.8   30.0 ECU.   -5.5 ECU.
05691334  4714  61  99  26  00    00 179 +10.5   30.0 ECU.   -5.5 ECU.
05691734  4655  59  98  27  00    00 179 +10.6   30.0 ECU.   -5.5 ECU.
05692134  4694  58  94  26  00    00 179 +10.7   30.0 ECU.   -5.5 ECU.
Old 10-02-2002, 11:33 PM   #5
DiMensionX
Member#: 23517
Code:
Log 4 10.2.02
                    Load Knock                     Mod   Mod         Mod
 RPM   MAP  MAF TPS Site Count  AFR  Ign#1  Inj#1  Ign   Fuel Boost  MAF
 1957  -1.6 2.3  82  10    00   12.5 +32.6    8.0 ECU.   -6.8 100.00 2.1
 1855  -1.6 2.2  87  10    00   14.7 +30.6    8.0 ECU.   -6.8 100.00 2.1
 1694  -1.2 2.2  86  10    00   13.3 +28.8    7.0 ECU.   -6.8 100.00 2.0
 1497  -1.2 2.1  88  10    00   13.1 +26.0    7.0 ECU.   -6.8 100.00 2.0
 1191  -1.0 2.0  91  10    00   12.8 +22.6    6.0 ECU.   -6.8 100.00 1.8
 1645  -1.0 2.1  92  10    00   12.6 +27.1    6.0 ECU.   -6.8 100.00 2.1
 1618  -0.4 2.2  94  10    00   14.0 +25.4    7.0 ECU.   -6.8 100.00 2.1
 1940  -0.6 2.3  92  10    00   13.7 +31.8    9.0 ECU.   -6.8 100.00 2.1
 2204  -0.4 2.4  93  10    00   14.1 +32.4   10.0 ECU.   -6.1 100.00 2.3
 2387  -0.8 2.5  94  10    00   13.9 +32.7   11.0 ECU.   -6.1  95.00 2.3
 2649  +0.2 2.5  93  10    00   13.5 +31.2   12.0 ECU.   -5.9  95.00 2.4
 2923  +0.4 2.7  92  10    00   13.7 +30.8   14.0 ECU.   -5.9  95.00 2.5
 3183  +1.3 2.8  93  10    00   13.3 +28.8   17.0 ECU.   -5.9  50.00 2.7
 3468  +2.1 2.9  94  20    00   12.8 +28.0   20.0 ECU.   -5.9  43.50 2.9
 3813  +3.1 3.2  94  20    00   12.9 +27.1   24.0 ECU.   -5.9  43.50 3.0
 4171  +4.3 3.4  94  30    00   12.2 +24.4   30.0 ECU.   -5.9  44.50 3.1
 4492  +5.7 3.5  93  30    00   rich +19.3   41.0 ECU.   -5.6  48.60 3.3
 5073 +10.6 3.8  93  60    00   rich +19.3   55.0 ECU.   -5.3  46.00 3.7
 5555 +11.3 3.9  92  60    00   rich +21.3   64.0 ECU.   -5.1  42.50 3.7
 6105 +13.1 4.0  92  70    00   rich +22.5   71.0 +25.0  -5.1  42.50 3.8
 6397 +14.3 4.1  92  80    00   rich +27.1   77.0 +25.0  -5.0  42.50 3.9
 6901 +12.1 4.1  88  70    00   rich +29.1   63.0 +25.0  -5.0  42.50 3.9
 6613  +0.6 1.5   0  00    00   13.1  +9.0   33.0 ECU.   -5.5 ECU.   1.5
 6242 -10.4 3.5  77  10    00   lean +36.6   37.0 ECU.   -5.1  42.50 3.5
 5058  +4.1 3.9  92  30    00   rich +20.5   56.0 ECU.   -5.3  48.00 3.6
 4444 +13.5 3.6  92  70    00   rich +14.5   51.0 +21.0  -5.6  48.60 3.5
 4675 +13.9 3.7  94  80    00   rich +15.3   54.0 +21.0  -5.6  48.60 3.6
 4810 +13.7 3.8  93  70    00   rich +16.7   58.0 +23.0  -5.3  48.00 3.6
 5042 +14.5 3.8  94  80    00   rich +18.6   61.0 +23.0  -5.3  46.00 3.6
 5216 +11.9 3.9  94  70    00   rich +21.7   64.0 +23.0  -5.2  43.50 3.7
 5402 +13.7 3.9  94  70    00   rich +21.1   67.0 +23.0  -5.1  42.50 3.7
 5611 +11.3 4.0  93  60    00   rich +21.0   70.0 ECU.   -5.1  42.50 3.8
 5797 +14.1 4.0  93  80    00   rich +22.6   73.0 +24.0  -5.1  42.50 3.8
 6049 +11.3 4.0  93  60    00   rich +22.6   77.0 ECU.   -5.1  42.50 3.8
 6082 +13.1 4.1  92  70    00   rich +24.1   80.0 +25.0  -5.1  42.50 3.9
 6337 +12.1 4.1  92  70    00   rich +26.9   82.0 +25.0  -5.1  42.50 3.9
 6459 +13.1 4.1  92  70    00   rich +27.2   84.0 +25.0  -5.0  42.50 3.9
 6666 +11.3 4.1  92  60    00   rich +27.4   86.0 ECU.   -5.0  42.50 3.9
 6734 +11.7 4.1  85  60    00   rich +28.9   84.0 ECU.   -5.0  42.50 3.4
 6574  -5.1 1.5   0  00    00   rich +10.1   12.0 ECU.   -5.5 ECU.   1.6
 5973 -11.8 2.8  28  00    00   22.9 +41.2   28.0 ECU.   -5.5 ECU.   3.3
 4662  +1.1 3.7  91  10    00   rich +19.3   49.0 ECU.   -5.3  48.00 3.5
 4930  +9.4 3.8  94  50    00   rich +18.3   62.0 ECU.   -5.3  46.00 3.7
 5167 +10.4 3.9  93  60    00   rich +19.9   66.0 ECU.   -5.3  46.00 3.7
 5096 +15.1 3.9  94  80    00   rich +19.5   67.0 +23.0  -5.3  46.00 3.6
 5224 +13.3 3.9  93  70    00   rich +21.3   66.0 +23.0  -5.3  46.00 3.7
 5291 +11.7 3.9  94  60    00   rich +21.2   68.0 ECU.   -5.2  43.50 3.7
 5316 +12.1 3.9  94  70    00   rich +20.9   70.0 +23.0  -5.2  43.50 3.7
 5464 +15.1 4.0  94  80    00   rich +21.3   71.0 +23.0  -5.1  42.50 3.7
 5583 +11.3 4.0  92  60    00   rich +21.5   74.0 ECU.   -5.1  42.50 3.8
 5564 +15.5 4.0  93  80    00   rich +21.6   76.0 +23.0  -5.1  42.50 3.8
 5767 +13.7 4.0  92  70    00   rich +21.9   77.0 +24.0  -5.1  42.50 3.9
 5807 +13.9 4.0  93  80    00   rich +22.3   79.0 +24.0  -5.1  42.50 3.8
 5837 +16.1 4.1  92  90    00   rich +22.7   79.0 +24.0  -5.1  42.50 3.9
 5941 +15.7 4.1  91  80    00   rich +23.1   82.0 +25.0  -5.1  42.50 3.9
 6016 +13.1 4.1  92  70    00   rich +23.4   82.0 +25.0  -5.1  42.50 3.9
 6082 +11.0 4.1  92  60    00   rich +23.4   84.0 ECU.   -5.1  42.50 3.9
 6207 +13.5 4.1  92  70    00   rich +25.9   85.0 +25.0  -5.1  42.50 3.9
 6313 +13.3 4.1  92  70    00   rich +25.8   86.0 +25.0  -5.1  42.50 3.9
 6472 +11.3 4.1  92  60    00   rich +25.5   87.0 ECU.   -5.1  42.50 3.9
 6435 +13.5 4.1  92  70    00   rich +26.2   88.0 +25.0  -5.0  42.50 3.9
 6561 +16.4 4.2  92  90    00   rich +26.9   89.0 +25.0  -5.0  42.50 4.0
 6277  +9.2 1.5   0  00    00   12.5 +10.0   14.0 ECU.   -5.5 ECU.   1.5
 5649 -10.6 3.6  68  10    00   14.2 +36.1   39.0 ECU.   -5.1 ECU.   3.5
 4694  +5.1 3.6  91  30    00   rich +18.7   53.0 ECU.   -5.3  48.00 3.5
 4616 +11.5 3.8  92  60    00   rich +15.5   63.0 ECU.   -5.6  48.60 3.6
 4810 +13.1 3.8  92  70    00   rich +15.9   64.0 +21.0  -5.3  48.00 3.6
 4748 +15.3 3.8  94  80    00   rich +16.7   64.0 +23.0  -5.3  48.00 3.6
 4741 +15.5 3.8  93  80    00   rich +16.7   64.0 +23.0  -5.3  48.00 3.6
 4789 +13.9 3.8  92  80    00   rich +17.8   63.0 +23.0  -5.3  48.00 3.6
 4938 +12.3 3.8  91  70    00   rich +17.1   64.0 +23.0  -5.3  48.00 3.6
 4952 +13.3 3.9  89  70    00   rich +18.3   64.0 +23.0  -5.3  48.00 3.7
 4930 +14.1 3.8  76  80    00   rich +18.9   65.0 +23.0  -5.3  48.00 3.6
 5005 +14.5 3.9  73  80    00   rich +18.9   64.0 +23.0  -5.3  46.00 3.6
 4975 +15.3 3.9  69  80    00   rich +19.5   66.0 +23.0  -5.3 ECU.   3.7
 5089 +12.5 3.9  59  00    00   rich +19.3   67.0 ECU.   -5.5 ECU.   3.7
 5120 +15.1 4.0  60  80    00   rich +20.0   73.0 +23.0  -5.3 ECU.   3.8
 5175 +13.9 4.0  60  80    00   rich +21.1   74.0 +23.0  -5.3 ECU.   3.7
 5232 +14.1 4.0  55  00    00   rich +20.5   72.0 ECU.   -5.5 ECU.   3.7
 5208 +17.4 3.9  50  00    00   rich +20.4   67.0 ECU.   -5.5 ECU.   3.6
 5316 +11.7 3.9  50  00    00   rich +22.3   66.0 ECU.   -5.5 ECU.   3.7
 5316 +12.9 3.9  52  00    00   rich +22.5   64.0 ECU.   -5.5 ECU.   3.7
 5437 +13.5 3.8  55  00    00   rich +22.5   64.0 ECU.   -5.5 ECU.   3.6
 5299  +9.2 3.9  59  00    00   rich +22.8   65.0 ECU.   -5.5 ECU.   3.7
 5359 +11.9 3.9  62  70    00   rich +22.7   66.0 +23.0  -5.2 ECU.   3.6
 5437  +9.8 4.0  78  60    00   rich +22.4   65.0 ECU.   -5.2  43.50 3.7
 5455  +9.4 4.0  89  50    00   rich +22.1   68.0 ECU.   -5.1  42.50 3.7
 5491 +11.9 4.0  90  70    00   rich +21.4   72.0 +23.0  -5.1  42.50 3.7
 5878 +11.9 4.0  90  70    00   rich +21.2   74.0 +23.0  -5.1  42.50 3.8
 5500 +12.1 4.0  90  70    00   rich +21.8   77.0 +23.0  -5.1  42.50 3.8
 5574 +12.9 4.0  90  70    00   rich +21.9   78.0 +23.0  -5.1  42.50 3.8
 5659 +12.9 4.0  91  70    00   rich +22.0   79.0 +23.0  -5.1  42.50 3.9
 5787 +13.9 4.0  91  80    00   rich +21.8   80.0 +24.0  -5.1  42.50 3.9
 5678 +13.1 4.1  91  70    00   rich +22.4   81.0 +23.0  -5.1  42.50 3.9
 5717 +18.2 4.1  91 100    00   rich +22.6   81.0 +23.0  -5.1  42.50 3.8
 5757 +16.6 4.1  91  90    00   rich +22.5   82.0 +23.0  -5.1  42.50 3.9
 5807 +15.9 4.1  90  90    00   rich +22.7   82.0 +24.0  -5.1  42.50 3.9
 5837 +15.1 4.1  91  80    00   rich +23.1   84.0 +24.0  -5.1  42.50 3.9
 5889 +16.8 4.1  91  90    00   rich +23.1   84.0 +24.0  -5.1  42.50 3.9
 5920 +12.5 4.1  89  70    00   rich +23.5   85.0 +25.0  -5.1  42.50 3.9
 5858 +12.1 4.1  88  70    00   rich +23.7   85.0 +24.0  -5.1  42.50 3.9
 6038 +18.0 4.1  89 100    00   rich +24.1   85.0 +25.0  -5.1  42.50 3.9
 6016 +13.5 4.1  89  70    00   rich +24.1   87.0 +25.0  -5.1  42.50 3.9
 6049 +17.0 4.1  89  90    00   rich +24.4   86.0 +25.0  -5.1  42.50 4.0
 5984 +12.5 4.1  89  70    00   rich +24.5   88.0 +25.0  -5.1  42.50 3.9
 6127 +13.9 4.1  89  80    00   rich +24.1   87.0 +25.0  -5.1  42.50 3.9
 6049 +16.8 4.1  89  90    00   rich +24.4   87.0 +25.0  -5.1  42.50 3.9
 6218 +15.3 4.1  83  80    00   rich +24.4   88.0 +25.0  -5.1  42.50 4.0
 6082 +13.9 4.1  36  00    00   rich +26.8   29.0 ECU.   -5.5 ECU.   2.3
 6195  -8.3 1.6   0  00    00   rich +10.5   29.0 ECU.   -5.5 ECU.   1.6
 6626 -12.0 2.0   0  00    00   18.4 +10.3   29.0 ECU.   -5.5 ECU.   1.9
 6038 -11.6 2.0   0  00    00   24.5 +10.5   29.0 ECU.   -5.5 ECU.   1.9
 5878 -12.0 2.0   0  00    00   24.2 +10.3   29.0 ECU.   -5.5 ECU.   1.9
 5868 -12.4 2.0   0  00    00   24.2 +10.5   29.0 ECU.   -5.5 ECU.   1.9
 5757 -12.8 2.0   0  00    00   24.2 +10.4   29.0 ECU.   -5.5 ECU.   1.9
 5611 -12.4 2.0   0  00    00   24.5 +10.5   29.0 ECU.   -5.5 ECU.   1.8
 5437 -13.2 1.9   0  00    00   lean +10.5   29.0 ECU.   -5.5 ECU.   1.8
 5393 -13.2 1.4   0  00    00   24.2 +10.4   29.0 ECU.   -5.5 ECU.   1.8
 5291 -13.0 1.8   0  00    00   24.2 +10.7   29.0 ECU.   -5.5 ECU.   1.7
 5184 -13.2 1.8   0  00    00   lean +10.7   29.0 ECU.   -5.5 ECU.   1.7
 5042 -13.4 1.8   0  00    00   24.5 +10.4   29.0 ECU.   -5.5 ECU.   1.7
 5042 -12.2 1.8   0  00    00   24.5 +10.6   29.0 ECU.   -5.5 ECU.   1.7
 4830 -13.2 1.8   0  00    00   24.5 +10.7   29.0 ECU.   -5.5 ECU.   1.7
Old 10-02-2002, 11:43 PM   #6
mlambert
Member#: 13831
I dont see the knock event, might just be missing it.
your IDC looks good, cept for 2 of them which id guess were just odd values
a/f is hard to read, rich lean rich lean...some of those leans at really high rpm must of been when you were shifting (I see stock ecu is controlling at those points, so I guess that was when you were off throttle). So why is the a/f only shown in the last one, is that cause you were going off the front o2? Mod maf only showed in the last log too.
In all my delta dash logs I basically just tuned into what the knock correction timing was and with the UTEC it looks pretty solid across the board, nice!
Ok I didnt help much, consider this a bump more than anything.
We really need an aftermarket ecu forum
mlambert is offline   Reply With Quote
Old 10-03-2002, 12:03 AM   #7
DiMensionX
Member#: 23517
Mark, the knock is on log three, most of the way down and shows a count of 05. I stand corrected as IT DID PULL TIMING.
The reason the first three logs look different is because with Rev 2 of the UTEC SW there are 5 or so logging options, with different things logged under each. After looking through these I think Data1 (Thats what the log is called in the UTEC, accessed by pressing 1) is the info in log 4 on this thread. I think going forward this is the log I will use for consistancies sake, unless others think there is a better way.
As for the Rich/Lean yes that was the Stock ECU controling the car during shifts or non WOT (between shirft on these logs:-)). If you notice I shifted VERY conservatively as I'm being cautious for now. In each of the logs you'll see me blip through the gears each time it flips to ECU instead of the a number under the "Boost" column. In most you'll see "ECU" for several timing event's, thats a slow shift for you:-). Some are only showing "ECU" for 1 timing record, thats a pretty fast shift:-).
Check out the DD logs at the EGT's! I think my stock EGT may be fried (and my darn Defi one isn't here yet). I just can not believe they would stay that constant, or maybe the UTEC is modifying that signal before the DD gets a hold of it.
I still don't know what MLP is, and it only comes on when the TPS goes OVER 100. I still don't know why the TPS goes over 100... Another wierd thing is that the DD NEVER shows a knock event, I assume that the UTEC is intercepting it and not passing it on to prevent the stock ECU from dumping fuel and pulling timing.
Now the last question for this post:-). INJ#1 shows up to 90 sometimes. Is this 90% duty cycle? If so whats up with that! These are STI 560CC's with a 255 liter fuel pump.
Shawn
Old 10-03-2002, 12:32 AM   #8
mlambert
Member#: 13831
ok I see the knock now, wish DD wouldve picked it up
yea i figured the IDC was in percentages, 90% for 560cc is alot of fuel but it should be safe (well as long as IDC of another injector is maxed while #1 is at 90%, I have no idea if #1 would be the most worked!)
Need some UTEC familars to look at this, keep it at the top
Old 10-03-2002, 12:34 AM   #9
STR8OUT
Member#: 15533
2010 Dodge Ram Hemi
boat, dirt bikes, bobcat
I think my brain just exploded
STR8OUT is offline   Reply With Quote
Old 10-03-2002, 12:52 AM   #10
DiMensionX
Member#: 23517
Yet another intresting note. In the install manual I found where to go to set the TPS min and max. It's the under "Parameter Tuning" supposedly which I DO NOT HAVE listed on the UTEC ANYWHERE.
Under "Parameter Tuning" there should be three other options listed according to the manual:
User Constants
Tuner Constants
Special Constants
What gives? I assume I'm blind or that TurboXS removed them from this release of code (or there is a magic key to get there, maybe "p", I'll try it tomarrow for grins). This explains why I can't set the knock threashold like Jorge can. I would have kept my mouth shut however it IS in the manual:-), just not on my UTEC.
Also, per Nathan's suggestion of adjusting the intake air temp, that is done through this screen set as well. I'll call them tomarrow if they don't chime in on this thread (read pretty please).
Gnight folks,
Shawn
Old 10-03-2002, 12:59 AM   #11
mlambert
Member#: 13831
theres screenshots of that at riftswrx webpage
In USER CONSTANTS you can setup features such as shift lights, optional solenoids, CEL (Check Engine Light) bypass features, etc.
TUNER CONSTANTS really should only be adjusted by those knowledgeable in tuning. Changing values outside of these parameters can directly affect the safeguards built into the UTEC. Proceed with vigilance!
SPECIAL CONSTANTS are for new features and functionality, as well as items that involve sensor calibration, etc. These should only be modified by the direction of TurboXS, or a knowledgeable tuner
the above copied from that link
Old 10-03-2002, 01:02 AM   #12
DiMensionX
Member#: 23517
Well, I'm going out to my car right now just to see if I'm blind or if they pulled it:-)... Be right back.
Shawn
Old 10-03-2002, 01:07 AM   #13
DiMensionX
Member#: 23517
I'm BLIND! Ok, my bad, I feel stupid but enlightend at the same time. It's right where it is supposed to be:-). Sorry for the confusion.
Shawn
Old 10-03-2002, 03:39 AM   #14
TurboXS (Pete)
Member#: 16704
Sorry guys but we need to provide some better information for the loggers in our manuals.
Log Usage
Log 1, 2, 3, and 5 use "real" numbers such as percentage for TPS.
Log 4 is raw digital numbers and is provided for people who want to grab the numbers and apply their own calibrations to them. In this case the TPS data is a number between 0 to 255 representing the TPS voltage. This is why when you use Log 4 the TPS can exceed 100.
MLP
This is the Map Load Point to indicate whereabouts on the map you are.
Knock Detection
The UTEC only monitors the knock sensor. The signal is still available to the factory ECU.
Also remember that the knock detection happens much faster than the Logger and so a knock count may not be displayed. However you should see timing retarded.
Pete
(TurboXS)
TurboXS (Pete) is offline   Reply With Quote
Old 10-03-2002, 12:15 PM   #15
DiMensionX
Member#: 23517
Thanks Pete, I guess I'll use the standard L for logging from now on as it seems to be the most suited to basic tuning.
Any other comments?
Shawn
Old 10-03-2002, 01:01 PM   #16
motoxphil
Member#: 5094
11.96, 1.64, 115mph!
Shawn,
A little note on detecting knock with the UTEC. We set the thresholds very agressive with the UTEC for maximum safety. If you have ever used a "knock link," the UTEC will pull timing or count "knock" when the second green light flashes. This is why you don't hear the knock and why your DD doesn't register it.
We set these thresholds using a microphone on the block. We have acheived all the power we need with these Knock settings so we have made them as sensitive as possible while not hurting performance.
I would add a little fuel or drop a degree of timing in the areas you are knocking. I would not reduce sensitivity on the knock settings until you have a solid grasp on tuning with the UTEC.
Thanks,
Phil
TurboXS
motoxphil is offline   Reply With Quote
Old 10-03-2002, 02:00 PM   #17
BOP
Member#: 8681
Post
this is pointless
BOP is offline   Reply With Quote
Old 10-03-2002, 02:23 PM   #18
nmyeti
Member#: 4980
Originally posted by BOP
Pete or Phil- could you please shed more light on how the UTEC works? Which sensors are being read directly and which are being polled from the ECU?
I've passed this on to Pete. When he wakes up i expect he'll give us an answer.
-Nathan
www.turboxs.com
nmyeti is offline   Reply With Quote
Old 10-03-2002, 05:20 PM   #19
TurboXS (Pete)
Member#: 16704
The UTEC was designed to monitor the signals from the engine via its on-board signal conditioning circuits and analog to digital converters.
Pete
(TurboXS)
Old 10-03-2002, 05:35 PM   #20
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Talking Grump!
Pete
(TurboXS)
I'm sorry Pete, you lost us there....could you be a little less technical?
n2xlr8n is offline   Reply With Quote
Old 10-03-2002, 06:13 PM   #21
BOP
Member#: 8681
Post
this is pointless
Old 10-03-2002, 08:01 PM   #22
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Default oops....sorry!
No exceptions? BOP respects
I misunderstood the question; I understand now. Sorry Pete, just j/k'n with ya, mate.
Old 10-03-2002, 08:16 PM   #23
StephenDone
Member#: 17994
99 Impreza UKTurbo
Midnight Blue
Bear in mind that DeltaDash reports information that has come directly from the OEM ECU. If the ECU is being 'fooled' by any external equipment, then the figures you are reading may not be accurate. A boost sensor clamp is the simplest example.
It is very rare to see the knock signal via DeltaDash, since knock events are very brief - the ECU deals with them instantly. To determine whether you are running too much timing, simply watch the knock correction analogue value. Positive values are good - ECU is advancing the timing. Negative values are bad - ECU is retarding the timing. Of course, this assumes that the OEM knock sensor is not intercepted.
It would be good to know which OEM ECU input signals & which ECU output signals are altered by the UTEC. You would then know which DD params you can rely on and which are then inaccurate.
Regs.
Stephen Done
Developer
EcuTek.
StephenDone is offline   Reply With Quote
Old 10-03-2002, 08:31 PM   #24
Schlad
Member#: 25433
2003 WRX SW
all we'll drive
I was overwhelmed by all this data at first since I'm new to ECU tuning. But, if I went with the idea of looking for trends, things seem to make some sense. So, please for give my ignorant questions...
Are the IGN#1 and IGN columns the timing degrees? I'm guessing they are.
If they are, in the log 3 where there was a 05 knock count, the IGN column the timing in second gear had many more ECU entries than the other logs. You ended up with the 05 knock count shifting into 4th it seems. Do you think something was going wrong with the engine in second gear to eventually end up with knocking? I know that's a reach because 3rd gear was knock free. I think...which leads me to this question....
Does the knock count of 5 mean that there were 5 knock events between where there were 00 and 05 *or* were the 5 knock events happening throughout the run and the UTEC gathered them all at that point? Did that make sense? Like were all the 5 knock events occuring all in that interval or were they spread out in time and the UTEC finally gathered them? I'm going to guess they all happened at one time or else there would've been a count of 01, 02 etc right?
heh heh that's all for now!
Schlad is offline   Reply With Quote
Old 10-03-2002, 09:34 PM   #25
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Default I'm somewhat of a UTEC newbie, but........
There were 5 knock counts between 4796 and 4810 rpm. Pretty good tool in my estimation. Nathan/Pete/Rifts might be the best people to address this.
Meet tonight 10/2/04 Grottos on rt 202 DE at 8:00 be there if you can TurboCharged97L Tri-State Area Forum 5 10-02-2004 06:46 PM
wrb wrx on army trail tonight 10.9.02 around 10:10 Achilles38WRX Mid West Subaru Owners Club Forum -- MWSOC 0 10-09-2002 11:39 PM
New UTEC Map and some log's from tongiht's tuning... DiMensionX Engine Management & Tuning 17 10-06-2002 11:02 PM
Forgotten Sighting: Blue WRX Sedan @ Sac Raceway 10/2/02 StankFootZ Bay Area Impreza Club Forum -- BAIC 2 10-05-2002 01:50 PM
UTEC & DeltaDash logs here from tonight DiMensionX Engine Management & Tuning 15 10-02-2002 11:57 AM
