Old 08-12-2013, 09:40 PM   #1
xxnightraven73x
Member#: 363148
2005 wrx
Default 05 lightly modded open source map help
i have an 05 wrx that ive done a bit to in the past couple weeks and im new to the whole open port flash tuning
current mods
3" CAI huge filter in the fender
catless uppipe
catless turbo back 3" exhaust
2 full turns in on the WG
wideband
we can only get 91 here locally but this is a map requirements i was testing out on it its not bad but its def off
Requirements:
- stock intake(drop in filter is ok)
- Turboback exhaust
- catless uppipe
- 93 octane ONLY
- 2 complete turns in on the wastegate actuator to hit target(18.25psi, although power graph below is at 16.25psi)
def need some help here
xxnightraven73x is offline   Reply With Quote
Old 08-12-2013, 10:39 PM   #2
JonnyV2889
Member#: 197384
2006 WRX Ltd
current mods
catless uppipe
wideband
Requirements:
- Turboback exhaust
- catless uppipe
- 93 octane ONLY
So you took an OTS map and decided veer off track, but have no idea how to fix it.
Check out bad noodles guide and a few others.
You'll at least need to scale your maf and probably reduce timing.
JonnyV2889 is offline   Reply With Quote
Old 08-12-2013, 10:48 PM   #3
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Pay someone. You are in over your head.
Black94Snake is offline   Reply With Quote
Old 10-08-2013, 02:05 AM   #4
tbanks024
Member#: 320902
2007 WRX
Did you at least save a copy of the original map before you started tweaking it and playing with the WG?
tbanks024 is offline   Reply With Quote
