Old 01-10-2014, 08:41 AM   #176
Nemesis_STI
Member#: 325545
2006 STI
Any one try this kn a Cobb ap w/ SD using a gm IAT sensor?
Nemesis_STI is offline   Reply With Quote
Old 01-10-2014, 09:50 AM   #177
umad
Member#: 351857
2013 STi
Cobb AP has the rev limiter already on it where it builds boost. Put in 1st gear , push clutch in and floor it. i tested it for a couple seconds and it builds boost. So this is for people with out the Cobb AP?
umad is offline   Reply With Quote
Old 01-10-2014, 11:12 AM   #178
bswilmington
Member#: 217563
2006 Sti 12.68 @ 108
321WHP 422WTQ dynojet SAE
Yeah but how much boost? Couple of lbs? Typically LC don't build much boost like this will.
bswilmington is offline   Reply With Quote
Old 01-10-2014, 11:31 AM   #179
Nemesis_STI
Member#: 325545
2006 STI
I guess ill try it. I am on SD with a Gm IAT welded to the Sti tmic. I unplugged it completely and the IAT temp read -0 so I think I need to just "interrupt" one of the wires rather than completly disconnect the sensor all together. Next I will change the values (-40 -20 or what ever the default value is once the signal is interrupted) to ~-27 as a starting point. And see if that works.
-Justin
Old 01-10-2014, 04:37 PM   #180
umad
Member#: 351857
2013 STi
It made about 8-9 lbs in just a few seconds.
Old 01-10-2014, 04:58 PM   #181
umad
Member#: 351857
2013 STi
http://www.cobbtuning.com/Subaru-Acc...ures/v2-subaru
Right from there site. . It is meant to build boost and to help launch your car in boost. .. /thread.
Old 01-10-2014, 05:26 PM   #182
TS7XREX
Member#: 287450
2011 Impreza WRX
Satin White Pearl
Yes with just launch control you will build boost, but with this type of setup you will build much more and do it faster...
so no "/thread"
TS7XREX is offline   Reply With Quote
Old 01-10-2014, 11:46 PM   #183
Nemesis_STI
Member#: 325545
2006 STI
Ok so I finnished up the wiring today, I interrupted one of the signal wires from the IAT to a "normally closed" momentary push button. Set the IAT comps to -32 disabled the p0111-p0113 codes. Set the 2 step to 4300 cut and 4290 resume. Fired it up. Ran normal. Hit the 2 step it built a little bit of boost and pressed the button the timing dropped to -10 lots of pops etc and it built about 13-15psi (too many things to watch like dam and fbkc!) it seemed pretty slow to rise. My IAT fuel comps in that range are +30% it's super rich. I'd like to compair settings to what you guys are running
Ps the roll on anti lag is pretty sweet
-Justin
Old 01-11-2014, 02:59 AM   #184
umad
Member#: 351857
2013 STi
so no "/thread"
how much boost do you really need to launch? 9 -10 psi is plenty to get it off the hole any more and you will prob just spin.
Originally Posted by Nemesis_STI View Post
Ok so I finnished up the wiring today, I int9 errupted one of the signal wires from the IAT to a "normally closed" momentary push button. Set the IAT comps to -32 disabled the p0111-p0113 codes. Set the 2 step to 4300 cut and 4290 resume. Fired it up. Ran normal. Hit the 2 step it built a little bit of boost and pressed the button the timing dropped to -10 lots of pops etc and it built about 13-15psi (too many things to watch like dam and fbkc!) it seemed pretty slow to rise. My IAT fuel comps in that range are +30% it's super rich. I'd like to compair settings to what you guys are running
-Justin
Cobb ap launch control works better .
/thread
Old 01-11-2014, 03:18 AM   #185
rocklizzard91
Member#: 226287
/thread
What makes one "better"?
Must have a ton of power or really bad tires if you can spin them. :P
rocklizzard91 is offline   Reply With Quote
Old 01-11-2014, 06:23 AM   #186
umad
Member#: 351857
2013 STi
So much easier with ap. Set rpm and your done.
Old 01-11-2014, 09:04 AM   #187
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
This wasn't intended to replace launch control, it was intended to aid launch control.
My VF43 will make 10psi on LC. But a larger rotated turbo won't spool up as easily. I personally have found my LC to produce a slower 60' time than launching without it. I did the "hack" but have not played with it all that much. It works great so far for roll races, but off the line it is worse than useless on my car.
Also, if you think spending 350-600 for an AP is justified just to have launch control... Then you should be nominated for noob of the month. Most open source roms can be patched or modded to have lc/ffs. I know mine does.
Merp SD w/NFSW LC/FFS.
Black94Snake is offline   Reply With Quote
Old 01-11-2014, 09:37 AM   #188
umad
Member#: 351857
2013 STi
This isn't my first Rodeo. . My last car i had a gt35r that spooled up 15 psi with launch control.. And I never said buying the ap would be just for launch control. I'm just saying this mod is useless and your a dumb ass for doing this for a roll race any way. .. That's even more retarded , have u not heard of Brake boosting? And using a hacked up way to build boost is so not safe for your engine, in for next thread " oh **** I just blew my motor ".
Old 01-11-2014, 10:17 AM   #189
Nemesis_STI
Member#: 325545
2006 STI
Ok so forgetting USADs verbal diarrhea... Anyone care to share there settings?
Old 01-11-2014, 11:19 AM   #190
umad
Member#: 351857
2013 STi
UMAD ?
subaru guys are such followers. ... lol.
Old 01-11-2014, 11:37 AM   #191
Nemesis_STI
Member#: 325545
2006 STI
UMAD ?
Lol sure there sport
Old 01-11-2014, 12:23 PM   #192
umad
Member#: 351857
2013 STi
Anti lag to be used from a roll .. That's genius. LOL
Old 01-11-2014, 02:36 PM   #193
rocklizzard91
Member#: 226287
Guess I didn't realize "better" meant "easier"
My open source Rom also sets basic launch control by setting rpm and you're done.
What did you have that spooled a gt35r off regular launch control to 15psi? Unless you were redlining at that 15psi spool :P
You like brake boosting? I absolutely hate it!
By your earlier logic, better = easier.
Therefore, it's easier to press a button to get full spool faster than brake boosting. So would that not mean that rolling anti-lag is better? :P
Old 01-11-2014, 04:26 PM   #194
umad
Member#: 351857
2013 STi
I don't even understand what your first statement and question is. Better = I didn't hack up my car for nothing. Are you not coordinated enough to press the brake and gas at the same time??. Being to lazy to brake boost your causing a lot of stress on your motor building boost in that manner and will most likely have engine problems/failure from it.
my last car was a rsx drag car and was the fastest rsx in the state.
Any how I'm done with this thread.. I'll be waiting for the Oh **** I blew my motor thread..
Old 01-11-2014, 05:32 PM   #195
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Hacking up the car?! Where's that coming from?
Are you the one that blew your motor on valentines day? *Or was that the other fastest rsx in nevada? *Seems you got all motor blowing knowledge.
I'll be waiting for ANOTHER blown motor from you.
You might as well leave. You aren't helping a single person in this thread.
My last car was a Trans Am and the fastest Trans Am on my block.
My current car is a Wrx and the fastest WRX on my street.
My future car is unknown but will undoubtedly be the fastest car in my garage.
ProfessWRX is offline   Reply With Quote
Old 01-11-2014, 06:04 PM   #196
umad
Member#: 351857
2013 STi
Yea I blew my motor on valentines day. It was my stock motor that I drove for 3 years making 440hp . Then I installed my built motor.
Don't hate cuz your to stupid to realize this mod is useless... My contribution to this thread is to make people think about doing this before they go and potentially blow their motor..
If people want to roll race without worrying about engine failure just brake boost . And for those who don't know brake boost = put in gear you want to start race in ex. 4th gear step on gas , car will build boost mean while hit brake just enough to keep mph at desired start mph and hold. . Honk three times and at third honk floor it and release brake.
Old 01-11-2014, 06:09 PM   #197
umad
Member#: 351857
2013 STi
Old 01-11-2014, 06:12 PM   #198
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
So you admit that your judgement is thoroughly flawed. Great.
Now you also don't tune your own cars. So you don't know how this mod even works.
Your fallback rant is about brake boosting. But this was conceptualized for launch control. Can't brake boost from a stop or have you got a magic car? I'd say no since your last magic car blew up.
Just let it go about this mod. It can be proven very useful and very effective. User error will blow motors, NOT this "hack." Just like your turbo kit didn't blow your motor. You did.
Serious question:
Did you really part that thing out? Or did you put it back to stock to sell? Or what happened to it?
Old 01-11-2014, 06:12 PM   #199
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
I know. I read all about it.
Old 01-11-2014, 06:21 PM   #200
umad
Member#: 351857
2013 STi
Serious question:
I didn't blow the motor , the stock motor wasn't built to handle the amount of power I was putting down. That's all.
I had launch control setup on last car with tuning software. The right way of doing things.
I sold the shell to guy in Washington , built block to guy in AZ I think and misc stuff to others. . So yes I parted it out and regret it now. .
