Old 10-03-2002, 10:19 AM   #1
Canuck
Member#: 17257
Angry Vishnu Up pipe O2 sensor falling out
It seems that my O2 sensor is coming loose and falling out of my Vishnu up-pipe avery month or so. It was fine for about half a year until recently. Now I have nothing but problems.
It seems that maybe someone did not tap the o2 sensor bung with the appropriate tolerances?
I've tried e-mailing Vishnu, but no luck.
I'm pissed!
Any suggestions would be much appreciated.
Canuck is offline   Reply With Quote
Old 10-03-2002, 10:57 AM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Vishnu uppipe... for the WRX?
Old 10-03-2002, 11:00 AM   #3
Canuck
Member#: 17257
Yup, for a WRX. I know this issue has been raised before, but I can't find it anywhere.
Old 10-03-2002, 12:52 PM   #4
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
O2 sensor or EGT sensor? I have not heard of this for the O2 sensor since it's an additional bung not typically used. I have experienced the problem with the EGT sensor however. The stock up-pipe has a bottom in the hole, the Vishnu pipe does not have anything to stop. They offer some little inserts to resolve this problem if you can get in contact with them. I had this problem until I bought a flare nut wrench and gave the sensor a good tightening. It's been about 4k miles and no problem yet.
PS: This needs to be moved.
-Jon
www.nothingserious.net
Old 10-03-2002, 12:57 PM   #5
Canuck
Member#: 17257
Isn't the EGT sensor the one on the manifold not the up-pipe? After tightening the sensor by hand, it really doesn't go much further with a wrench, and I don't want to reaf on it.
I've been trying to contact them, but no luck. I think that their website and e-mail is down, and I have no ph. numbers.
Thanks for the reply
Old 10-03-2002, 01:02 PM   #6
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Front O2 sensor goes into the passenger side exhaust manifold. The up-pipe contains a bung for the factory EGT sensor (long metal rod) and an extra O2 sensor bung (which is used for aftermarket O2 sensors).
Are you using the right website? www.vishnutuning.com
-Jon
Old 10-03-2002, 05:43 PM   #7
H8YNERS
Member#: 4995
2002 WRX wagon
On the Vishnu uppipe, it's the stock EGT probe that goes in the bung. I know, mine kept falling out. I finally did the bolt & resistor mod to fix. I got up and close and personal w/my EFT probe (wow..that sounds bad! ) as it fell out at least 3x's!
Stephen
H8YNERS is offline   Reply With Quote
Old 10-03-2002, 08:40 PM   #8
WRX216
Member#: 8027
2002 WRX sedan
Midnight Black
loctite makes a hi temp threadlocker that will fix your problem. Just don't use too much or you will never get the egt probe out again. Hope this helps
Chris
WRX216 is offline   Reply With Quote
Old 10-03-2002, 09:30 PM   #9
Yungimoto
Member#: 14940
Call them and they'll send out these little inserts right away. I got mine in 2 days. It is the egt sensor you're talking about.
Yungimoto is offline   Reply With Quote
Old 10-04-2002, 10:59 AM   #10
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Default Re: Vishnu Up pipe O2 sensor falling out
I'm pissed!
The O2 sensor is in the manifold and the EGT sensor is in the uppipe.
Best recommendation: Replace the EGT with a 12x1.25 bolt and a 2.2 kohm resistor. If you prefer to keep the EGT probe, get a medium-sized hoseclamp and cut a hole in the side of the metal band so that the probe can fit through it. Then just put the hoseclamp around the uppipe and it'll clamp your EGT probe down tight and permanent. If you do this and your probe comes out on its own again, I'll paypal you $10. That's how sure I am of this fix. If you need pictures to understand how to do it, I can get you some pictures.
nhluhr is offline   Reply With Quote
Old 10-04-2002, 01:34 PM   #11
H8YNERS
Member#: 4995
2002 WRX wagon
This is what I did after my EGT probe fell 3x's. So far, so good.
The EGT probe is there to monitor the temp to protect the pre-cat which is no longer there after the new uppipe install anyhow.
Stephen
Old 10-04-2002, 04:46 PM   #12
twinz
Member#: 13423
locktite isnt a decent solution because even their hitemp stuff is only rated to 450 derees..that locaton is seeing over 1500 drgrees. Permatex makes a hitemp muffler and tailpipe sealer that is good to 2k degrees...I had same issue with egt probe in my Perrin up-pipe and it has worked just great. Permatex part # 80335 ..you will probably have to order it as I was unable to find it in any local autoparts stores.
twinz is offline   Reply With Quote
Old 11-01-2002, 07:14 PM   #13
metoo
Member#: 4764
2004 STi sold :(
forizzle
Shoot.....I just used JB Weld. After trying a couple other products, this is the only one to hold so far. It's been in place about 4 or 5 months now.
metoo is offline   Reply With Quote
Vishnu Up pipe (BRAND NEW) and used Vishnu DP (SAN DIEGO) sdnativesurfer SCIC Private Classifieds 2 06-02-2009 02:12 AM
Vishnu up-pipe WRX Sti w/EGT sensor FusionMotorSwaps Engine/Power/Exhaust 4 02-20-2009 12:56 PM
up-pipe o2 sensor pearljam11 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-22-2008 04:59 PM
Up pipe / O2 sensor question armowrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 04-09-2008 06:21 PM
more stuff for sale Samco hoses, Vishnu up-pipe vishnu pulley and more.. titsataki Bay Area Impreza Club Forum -- BAIC 12 05-04-2004 10:17 PM
