Old 08-16-2013, 05:55 PM   #1
goomz25
Member#: 362517
Default More hp not noise
What, if anything can I do to add power without making my stock 13 sti any louder. Does a access port help on a stock car. Does acold air intake add outside noise. I know when you floor it you will hear it more but I'm just looking for no more idle and normal driving noise
goomz25 is offline   Reply With Quote
Old 08-16-2013, 06:03 PM   #2
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Stage 1 tune.
Black94Snake is offline   Reply With Quote
Old 08-16-2013, 08:33 PM   #3
hutch959
Member#: 267463
you could do a stage 2 with stock cat back and stock air cleaner...
might be a tad louder but not much.
hutch959 is offline   Reply With Quote
Old 08-16-2013, 09:12 PM   #4
JonnyV2889
Member#: 197384
2006 WRX Ltd
Downpipe. Pro tune.
JonnyV2889 is offline   Reply With Quote
Old 08-17-2013, 07:52 AM   #5
Cathexis
Member#: 335445
2012 WRX - BLK STIG
Stg. 2 - 287whp/317wtq.
Originally Posted by JonnyV2889 View Post
Downpipe. Pro tune.
Ding, ding, we have a winner.....
That's it in a nutshell right there.
Cathexis is offline   Reply With Quote
Old 08-17-2013, 04:22 PM   #6
goomz25
Member#: 362517
Down pipe will be louder but only when you hammer on it right?
Old 08-17-2013, 04:43 PM   #7
JonnyV2889
Member#: 197384
2006 WRX Ltd
Barely. Not sure db level difference between catted vs catless dp maybe 1 or 2 dBs. I gutted my Sti CBE to get a little more bark from the thing and I'm running a catless dp. I drive 55 miles each way to work, want to be incognito and not have a headache when I get there.
Old 08-17-2013, 05:10 PM   #8
gutie04
Member#: 219717
05 FXT Dom2.5R
4EAT FTW!!!!
AP + protune.
I recommend some upgraded bushing, maybe some lockdown bolts. The bushings and bolts can add some noise, but it was negligible to me and well worth how the car put power down to the wheels. They are very easy to install and remove and sell here if you dislike them. Only other option I know of is light weight parts, like driveshaft and pully. Again these don't add power but reduce losses.
gutie04 is offline   Reply With Quote
Old 08-17-2013, 05:22 PM   #9
Cathexis
Member#: 335445
2012 WRX - BLK STIG
I'll go with deeper, not louder. Get one with a high flow cat. Dp is biggest single hp mod for our cars.
Old 08-17-2013, 05:23 PM   #10
JonnyV2889
Member#: 197384
2006 WRX Ltd
Originally Posted by gutie04 View Post
AP + protune.
I personally don't see any point in paying $500+ for an AP then shelling out $200+ for a pro tune on the damn thing. You can buy a tactrix or vagcom if you want to dick with the cable and get a pro etune for under $250 or dyno time for $300+
Old 08-17-2013, 05:50 PM   #11
gutie04
Member#: 219717
05 FXT Dom2.5R
4EAT FTW!!!!
You are correct, AP is expensive. But I recommend it because it Is significantly more user friendly than open-source.
Old 08-17-2013, 07:59 PM   #12
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
It's only crazy expensive if you buy it new. I have bought 4 of them for under $350 each. Some people also benefit from it because you don't need to have a laptop in the car for datalogging.
For someone who won't be putting tons of time into learning to tune, the AP is a great purchase. Especially if its used.
Old 08-17-2013, 09:13 PM   #13
weric
Member#: 19817
13 STI
AP stage 2 + protune + headers and up pipe
weric is offline   Reply With Quote
Old 08-18-2013, 09:30 AM   #14
Cathexis
Member#: 335445
2012 WRX - BLK STIG
No need for an up pipe on our cars unless you want an external wastegate. They are already catless.
Old 08-19-2013, 01:03 PM   #15
knownin951
Member#: 365870
2006 Sti
intake, catted downpipe, tune
knownin951 is offline   Reply With Quote
Old 08-19-2013, 01:53 PM   #16
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
No intake, as to avoid boost creep. DP + Tuning. Skip an AP pick up a tactrix and look into good tuning. E tuning can be had and get the same results as pro tuning just takes a little longer!
-Ceir @ EndrTuningLLC
endrswrd is offline   Reply With Quote
Old 08-20-2013, 05:35 PM   #17
goomz25
Member#: 362517
Can I go stage 2 with just a dp and air box?
Old 08-20-2013, 07:00 PM   #18
JonnyV2889
Member#: 197384
2006 WRX Ltd
Drop your notation of stages, it's a marketing thing. You can do anything you want as long as you're tuned for it. Not sure what you mean air box? You can't change just the air box out, nor would I know why you want to?
Old 08-23-2013, 08:37 PM   #19
goomz25
Member#: 362517
Well what does it take to get to 300 whp?
Old 08-23-2013, 09:23 PM   #20
DentMagnet
Member#: 352689
2004 Impreza
dark green but looks blak
Active Noise Cancellation?
DentMagnet is offline   Reply With Quote
Old 08-23-2013, 10:03 PM   #21
JonnyV2889
Member#: 197384
2006 WRX Ltd
It's just a number. Do you want that on a dynojet or mustang?
Either way you should be close if not there with a downpipe, fuel pump and pro tune. A 3 port would help using that torque in lower gears. Pretty much all the stocker is capable of is 300 or a little over.
Old 08-23-2013, 10:16 PM   #22
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
Downpipe and very good tune will get you close enough that makes no matter. Shooting for hp numbers is for the uninformed. Find a goal that isn't just a piece of paper.
Modify until you are satisfied with the performance. Then drive it 'til you aren't. Then repeat.
ProfessWRX is offline   Reply With Quote
