Old 04-14-2001, 05:49 AM   #1
nav
Member#: 4966
99 2.5RS
Rally Blue
Post car is running rough!....help, quick!
sorry to post this twice, i'm in a rush
my car is doing something weird...
it was missing a little earlier (little sputter now and then), but then about 5 kms later... it was running worse and worse...it was hestitating, and then when i parked it, it idled really rough...the engine light has NOT come on so i'm ruling out O2 sensor....
any ideas?
please help, i have to get this fixed today!
bye
nav is offline   Reply With Quote
Old 04-14-2001, 06:06 AM   #2
Rick G
Member#: 3122
Post
? spark plug?
Rick G is offline   Reply With Quote
Old 04-14-2001, 07:45 AM   #3
v6scoobie
Member#: 1563
Post
With the warmer temps have you coverted your winter air to spring air in you carbon compound circular devices mounted on metallic rims Hope this helps
v6scoobie is offline   Reply With Quote
Old 04-14-2001, 07:47 AM   #4
v6scoobie
Member#: 1563
Post
Just kidding try a gas additive you may have water in the tank or try a different gasoline .
Old 04-14-2001, 08:00 AM   #5
pagemill
Member#: 5554
Post
Sounds kind like what happened to my forester
(twice)
Supposedly bad fuel injector #3
Was running on 3 cylinders ... barely
And the CEL never came on both times.
It lights up for loose gas caps but not
for this!
pagemill is offline   Reply With Quote
Old 04-14-2001, 08:02 AM   #6
pagemill
Member#: 5554
Post
Sorry forgot to mention it was also bad
O2 sensor too - anyway the dealer replaced
both.
Old 04-14-2001, 08:07 AM   #7
nick dickitt
Member#: 4532
Post
O2 sensor is my guess. CE lights DO NOT always come on.
nick dickitt is offline   Reply With Quote
Old 04-14-2001, 08:23 AM   #8
Sanguine
Member#: 5575
'02 Impreza WRX
Midnight Black Pearl
Post
Based on experience with other cars, my first guess would be a bad/clogged fuel injector or an alternator/wiring problem. Of course, take that with a grain of salt, as I'm a bit new to subies.
Sanguine is offline   Reply With Quote
Old 04-14-2001, 08:55 AM   #9
Dirt Man
Member#: 176
2011 Subaru Forester
Wink
Sounds like the symptoms of a bad ignition coil! I've had the same problem and so has SUV-ETR, all similar symptoms. After you get the problem fixed change to new spark plugs and possibly new wires! Could also be the O2 Sensor, the first sign would be if your fuel mileage has dropped recently.
Dirt Man is offline   Reply With Quote
Old 04-14-2001, 04:12 PM   #10
nav
Member#: 4966
99 2.5RS
Rally Blue
Post
I though hard and figured it wasn't getting spark... i knew that one of my wires was in rough shape, so i bought ngk blues and it cured my problem...i also assumed bad gas, or water, so i put some water remover and fresh gas before i did the wires....
but thanks anyway guys
Old 04-14-2001, 08:20 PM   #11
Dirt Man
Member#: 176
Post
Have you changed the plugs yet? If not you'll be amazed at the difference in performance! You'll also be amazed at the level of carbon & other crap on the plugs!
My car is running slower. Need help sleestak6326 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 03-08-2006 03:28 PM
running rough!! help! flabele Engine Management & Tuning 4 06-27-2005 04:57 PM
Car is running SUPER lean-any help?? gtwagon941 Legacy Forum 11 10-16-2004 03:36 PM
My car is running like butt, help me out here BrysImpreza New England Impreza Club Forum -- NESIC 10 11-27-2001 07:08 PM
car running rough...help quick nav Normally Aspirated Powertrain 3 04-14-2001 04:14 PM
