Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 08-19-2013, 09:36 AM   #1
TheHawk
Member#: 242617
04' STI
JBP
Default Reverse lockout problems
Installed Kartboy front and rear shifter bushings yesterday. After I got everything snugged up I tested it out. 1-4 are fine. To go into 5th and 6th you have to hold the reverse lockout up. Shifting into reverse is like shifting into 6th normally. What the heck did I do? It was a pretty straight forward install. Took maybe an hour and a half. Went back underneath after and made sure everything was tightened up. All is good. The reverse cable isn't kinked or anything. Anyone have any suggestions? Anyone ever seen something like this? Did a quick google search and couldn't really find anything on it.
TheHawk is offline   Reply With Quote
Old 08-19-2013, 09:13 PM   #2
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
U need to re adjust the reverse lockout cable or when u put the front linkage bushing in u over tightened that bolt so hope this helps
It gets even more finicky when u install a short shifter so keep this in mind also if so choose to put one in.
trev762 is offline   Reply With Quote
Old 08-20-2013, 07:06 AM   #3
TheHawk
Member#: 242617
04' STI
JBP
I probably tightened it too much. I'll get under there and loosen it again and see if that helps. Thanks!
